查看: 4410|回复: 6
[显卡维修]
七彩虹9550显卡花屏测试结果怎么判断显存坏了
 关闭 [复制链接]
发表于 2009-3-30 14:15:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 福建福州 来自 福建福州
七彩虹9550显卡花屏测试结果怎么判断显存坏了。。测试结果如下面
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
  errcount: 48505830
  MDA0: 16 17 18 19 20 21 22 23 24 25 27 28
  MDB0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 25 28 30 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [2] Data line toggle (GUI)
  errcount: 20271876
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 24 25 27 28
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [3] RW page (GUI)
  errcount: 25165056
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 36 37 38 39 48 49 50 51 52 54 55
Failing bits in test [4] RW channel (GUI)
  errcount: 25165056
Failing bits in test [5] Data mask
  errcount: 38819334
  MDB0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 25 28 30 36 37 38 39 48 49 50 51 52 54 55
Failing bits in test [6] Macro + Micro8x2 tiling read
  errcount: 7538152
  MDA0: 4 5 6 7 16 17 18 19 20 21 22 23 24 25
  MDB0: 1 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 25 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [7] Byte swap macro+micro8x2 read
  errcount: 58152249
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
    failing bit : MDA0 4 5 6 7 16 17 18 19 ... MDB0 1 3 4 5 6 7 8 9 ...
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
帮我判断下是哪里的显存坏了
发表于 2009-3-30 14:40:13 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
两个通道显存全部出错 先查A通道显存的地址线 !
发表于 2009-3-30 15:32:37 | 只看该作者 来自: 山东枣庄 来自 山东枣庄
是A卡的测试结果吧,看不太懂!!!
发表于 2009-5-19 15:45:53 | 只看该作者 来自: 江苏无锡 来自 江苏无锡
有时候好显卡也测试出好多问题  感觉不能 太相信软件的结果哦
发表于 2009-5-20 17:58:42 | 只看该作者 来自: 广东广州 来自 广东广州
是啊 ,修过一块9550也是
发表于 2009-5-21 11:49:22 | 只看该作者 来自: 海南琼海 来自 海南琼海
错太多了,不知道你的显卡花屏的程度怎么样,最好是先查供电,这样报错的有可能是你用的软件版本不对造成的,最好换一个软件试试
发表于 2009-5-21 15:46:26 | 只看该作者 来自: 江苏淮安 来自 江苏淮安
先加焊A区下面一组反面的那颗,不行再更换
