查看: 1036|回复: 1
can小板的程序
发表于 2016-7-24 07:58:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 山西运城 来自 山西运城
  * ÎļtÃû£o
  * ×÷Õߣo  huang_4115@126.com
  * °æ±¾£o  V1.0.0
  * èÕÆú£o  2013-
  * Õaòa£o  èÎÎñoˉêy
  * ËμÃ÷£o
#include "includes.h"
OS_STK task_demo_stk[TASK_DEMO_STK_SIZE];                  //¶¨òåÕ»
OS_STK task_cmd_stk[TASK_CMD_STK_SIZE];
OS_EVENT *Mbox_Can1;
u8 UM = 2;
  *    ËμÃ÷£o
  *    êäèë£o
  *    êä3ö£o
void Task_Start(void *p_arg)
        OSTaskCreate(Task_Demo, (void *)0, &task_demo_stk[TASK_DEMO_STK_SIZE-1], TASK_DEMO_PRIO);
        OSTaskCreate(Task_CMD, (void *)0, &task_cmd_stk[TASK_CMD_STK_SIZE-1], TASK_CMD_PRIO);
    Mbox_Can1 = OSMboxCreate((void *)0);
    LED3_ON;               //Ïèμãááled3
    OSTimeDly(300);        //μè′yelmoíêè«1¤×÷
    printf("MO=0;");
    printf("UM=%d;",UM);   //ĬèÏê1óÃËù¶èÄ£ê½ á¢¿ì¼óÔØËù¶è
    printf("M=1;");
    printf("AC=2000000;");
    printf("DC=2000000;");
    printf("MO=1;");
    printf("EC;");         //èç1ûᬽóÎTÎó£¬′Ë걻Ὣled3ϨÃe
    while (1)
        IWDG_Init(IWDG_Prescaler_4,1000);     //3¬ê±100ms¸′λ
        OSTaskSuspend(STARTUP_TASK_PRIO);
  *    ËμÃ÷£o
  *    êäèë£o
  *    êä3ö£o
void Task_Demo(void *p_arg)
    u16 temp;
    u32 err_code=0,*perr_code;
    s32 speed;
    s32 position;
    while(1)
        if(CAN_ReadCnt!=CAN_WriteCnt)
            temp = CAN_ReadCnt%CAN1_BUF_SIZE;
            switch(RxMessage[temp].Data[0])
                case 'v':                 //Ëù¶èÄ£ê½
                case 'V':
                        speed = (s16)((RxMessage[temp].Data[1]<<8)|RxMessage[temp].Data[2])*RPM2CPS;
                        if(UM != 2)
                            UM = 2;            //ê1óÃËù¶èÄ£ê½ á¢¿ì¼óÔØËù¶è
                            printf("MO=0;");
                            printf("MO=1;");
                        printf("JV=%d;BG;",speed);
                        break;
                case 'p':                //λÖÃÄ£ê½
                case 'P':
                        if((RxMessage[temp].Data[1] == 'R')||(RxMessage[temp].Data[1] == 'r'))
                            speed = (s16)((RxMessage[temp].Data[2]<<8)|RxMessage[temp].Data[3])*RPM2CPS;
                            position = (RxMessage[temp].Data[4]<<24)|(RxMessage[temp].Data[5]<<16)|      \
                                        (RxMessage[temp].Data[6]<<8)|(RxMessage[temp].Data[7]);
                            if(UM != 5)
                                UM = 5;            //ê1óÃλÖÃģ꽣¬Ïè¼óÔØλÖã¬Ôù¼óÔØËù¶è
                                printf("MO=0;");
                                printf("MO=1;");
                            printf("SP=%dR=%d;BG;",speed,position);
                        else
                        if((RxMessage[temp].Data[1] == 'A')||(RxMessage[temp].Data[1] == 'a'))
                            if(UM != 5)
                                printf("MO=0;");
                                printf("MO=1;");
                            printf("SP=%dA=%d;BG;",speed,position);
                        break;
                 case 'm':                  //ê1Äü¡¢ê§Äüμç»ú
                 case 'M':
                        if((RxMessage[temp].Data[1] == 'O')||(RxMessage[temp].Data[1] == 'o'))
                            if(RxMessage[temp].Data[3] == '0')
                                printf("MO=0;");
                            else
                                printf("MO=1;");
                        if((RxMessage[temp].Data[1] == 'F')||(RxMessage[temp].Data[1] == 'f'))  //μç»úê§ÄüDÅÏ¢
                            USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
                            printf("MF;");     //»ñè¡μç»úê§Äü′íÎóÂë
                        break;
                 case 'e':                  //2éÑˉ′íÎó
                 case 'E':
                        if((RxMessage[temp].Data[1] == 'C')||(RxMessage[temp].Data[1] == 'c'))
                            printf("MO=1;");   //Ïè·¢ò»¸öÃüáî2úéú×îDÂ′íÎóÂë
                            printf("EC;");     //»ñè¡′íÎóÂë
                        break;
                 case 'r':                //èí¼t¸′λ
                 case 'R':
                        if((RxMessage[temp].Data[1] == 'B')||(RxMessage[temp].Data[1] == 'b'))
                            SoftReset();
                        break;
                        /*ÆäËû1|Äü¿é×ÔDDà©Õ1*/
                 default:
                        break;
            CAN_ReadCnt++;
        perr_code = OSMboxAccept(Mbox_Can1);
        if(perr_code!=0)            //¸øÖ÷¿Ø·¢Ëí′íÎóÂë
            err_code = *perr_code;
            TxMessage.DLC=4;                                //Ö¡3¤¶è 0~8
            TxMessage.Data[0]=(err_code) >>24;
            TxMessage.Data[1]=(err_code) >>16;
            TxMessage.Data[2]=(err_code) >>8;
            TxMessage.Data[3]=(err_code) ;
            CAN1_SendMsg();
        IWDG_Feed();
  *    ËμÃ÷£o
  *    êäèë£o
  *    êä3ö£o
void Task_CMD(void *p_arg)
    while (1)
        CPL_LED1;
        OSTimeDly(500);
发表于 2016-7-24 12:27:22 | 只看该作者 来自: 陕西西安 来自 陕西西安
我表示看不懂,这个为什么中间还有几个表情图像?楼主解释一下。
