- 积分
- 5
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2015-12-23
- 精华
LED:00000047 希捷F3 MCMT报错不识别恢复数据-1
同时指令无响应
ST1000DM003 FW:CC4G
终端报错如下。
Boot 0x40M
Spin Up
TCC-001D[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001D
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00545CBF
[RSRS] 05E4
ProcessRWError -Read- at LBA 000000000004C393 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000004C393!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001D
LED:00000047 FAddr:FFFFFFFE
解决方法:
Rst 0x40M
Spin Up
TCC-0024 (看这里,读固件自检完成再短路)板号:100664987-REV B
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) Requesting File Save
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
Starting LBA of RW Request=0000000000087B14 Length=00000174
ProcessRWError -Read- at LBA 0000000000087B14 Sense Code=43110081
Total AC8, Head AA0, Tail 28 Retry 0 Status 0
Total AC8, Head AA0, Tail 28 Retry 1 Status 0
Total AC8, Head AA0, Tail 28 Retry 2 Status 0
Starting LBA of RW Request=0000000000087B18 Length=00000170
ProcessRWError -Read- at LBA 0000000000087B18 Sense Code=43110081
Starting LBA of RW Request=0000000000087B1C Length=0000016C
ProcessRWError -Read- at LBA 0000000000087B1C Sense Code=43110081
Starting LBA of RW Request=0000000000087B20 Length=00000168
ProcessRWError -Read- at LBA 0000000000087B20 Sense Code=43110081
Starting LBA of RW Request=0000000000087B24 Length=00000164
ProcessRWError -Read- at LBA 0000000000087B24 Sense Code=43110081
Starting LBA of RW Request=0000000000087B28 Length=00000160
ProcessRWError -Read- at LBA 0000000000087B28 Sense Code=43110081
Starting LBA of RW Request=0000000000087B2C Length=0000015C
ProcessRWError -Read- at LBA 0000000000087B2C Sense Code=43110081
Starting LBA of RW Request=0000000000A9C053 Length=00000001
ProcessRWError -Read- at LBA 0000000000A9C053 Sense Code=C4090082
Starting LBA of RW Request=0000000000A9C054 Length=00000001
ProcessRWError -Read- at LBA 0000000000A9C054 Sense Code=C4090082
Total AC8, Head AA0, Tail 28 Retry 2 Status 0[0000000000A9C053]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ProcessRWError -Write- at LBA 0000000000A9C053 Sense Code=C4090081[0000000000A9C054]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ProcessRWError -Write- at LBA 0000000000A9C054 Sense Code=C4090081[0000000000087B14]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ProcessRWError -Write- at LBA 0000000000087B14 Sense Code=C4090081[000000000E993B4C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q[000000000E993B4D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q[000000000E993B4E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
FAILED to spare00000903
Device Fault is set!
No HOST FIS-ReadyStatusFlags 0002A1A5
ASCII Diag mode
F3 T>
ASCII Diag mode
出现指令后。写 系统文件: 03 346 .COPY1 写到COPY0.
断电上电后,指令有反应,不再锁定。
F3 T>
Boot 0x40M
Spin Up
TCC-0023[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
Spin Up
TCC-0023
SIM Error 2040 LBA 000000000008E913 FD FC351028
RW Error 00000080
MCMainPOR: Feature Disabled... PASS
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22 (执行重建编译器)
Max Wr Retries = 00, Max Rd Retries = 00, Max Iterations = 01, Max Certify Rewrite Retries = 000C
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
断电上电。硬盘可以识别并读取数据。
Boot 0x40M
Spin Up
Trans.
Rst 0x40M
Spin Up
TCC-0023
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Factory Init
MCInitialize: Start: Buffer Words VBM: 00000210
ClearMC: Start Full Media Cache size in host blks 00432380.....
ClearMC: Completed, Last LBA 00432380
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS]
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000041
MCMainPOR: Feature Enabled...
(DOS)STE OGHT: 0x00000000000E8BD6 - 0x00000000000EB55E - 0x000004F0 - 0x0000050E Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000AAD22F - 0x0000000000AB06BC - 0x00003594 - 0x000035B2 Count 0049
(DOS)CMP Count 0049
(DOS)STE OGHT: 0x0000000000AAD07D - 0x0000000000AB050A - 0x00003593 - 0x000035B1 Count 004F
(DOS)CMP Count 004F
(DOS)STE OGHT: 0x00000000000E8E84 - 0x00000000000EB80C - 0x000004F2 - 0x00000510 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000000E8FDB - 0x00000000000EB963 - 0x000004F3 - 0x00000511 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x00000000000D7130 - 0x00000000000D9E98 - 0x0000050A - 0x00000528 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000AA566D - 0x0000000000AA8AFA - 0x0000354B - 0x00003569 Count 0040
(DOS)CMP Count 0040
PowerState = IDLE1
硬盘可以识别并提取数据。
