查看: 1943|回复: 4
[显卡维修]
r3memid结果求助
发表于 2009-2-21 13:47:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东潮州 来自 广东潮州
昂达显卡,
参数如下:型号 雷霆X550 256M
芯片厂方 ATI
芯片型号 ATi RADEON X550
芯片代号 RV370XT
制作工艺 0.11um
核心位宽 256bit
显卡接口标准 支持PCI Express
输出接口 1*VGA接口,TV-OUT接口,1*DVI-I接口
性能参数我要挑错,赢积分,取大奖
显存容量 256M
显存类型 DDR
显存位宽 128bit
显存速度 5ns
显存封装 TSOP
核心频率 400MHz
显存频率 400MHz
象素渲染管线 4管
顶点着色引擎数 2个
3D API 支持DirectX 9.0
r3测试结果如下:
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Fill
Failing bits in test [1] Fill
  errcount: 2
  MDB0: 16 32 33 38 48 49 54
Failing bits in test [2] Data line toggle (GUI)
  errcount: 12057536
  MDB0: 16 32 33 34 35 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [3] RW column (GUI)
  errcount: 25162752
  MDB0: 1 5 16 17 32 33 34 35 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [4] RW page (GUI)
  errcount: 25165056
  MDB0: 16 17 32 33 34 35 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [5] RW channel (GUI)
  errcount: 12582720
Failing bits in test [6] Data mask
  errcount: 28292888
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 4195670
  errcount: 4195670
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 4196011
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 25165388
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 25165560
Failing bits in test [11] Marco+Micro8x2 alignment write
  errcount: 74752
Failing bits in test [12] Macro+Micro4x4 alignment read
  errcount: 74752
TEST RESULT SUMMARY:
RV370/M22 A13 (0x5b63) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1280 x 1024 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 16 32 33 38 48 49 54
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDB0 16 32 33 34 35 36 37 38 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
    failing bit : MDB0 1 5 16 17 32 33 34 35 ...
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
    failing bit : MDB0 16 17 32 33 34 35 36 37 ...
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
求高手帮忙分析是哪里坏了
发表于 2009-2-21 14:15:31 | 只看该作者 来自: 广东潮州 来自 广东潮州
怎么没人帮忙分析看看啊。
发表于 2009-2-21 18:48:52 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
先查B通道显存 从第一颗开始查起有显存损坏
发表于 2009-2-22 01:10:53 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
记住  以后你只需跑5、6、7项  即可
你先观察  显卡朝上摆正  核心方晶上面两个边有无崩边
有的话  不用动烙铁  了  刷入蓝宝石 x550   64bit128m  的bios  下面网址  正数第四个http://www.techpowerup.com/vgabi ... face=&memSize=0
如果没有崩边的话
按  新诚达版主的办
你如果想省事的话  也可 刷入  以上bios  变成128m  的  记得备份原bios
参与人数 1下载分 +10 收起 理由
新诚达 + 10 热心会员!
发表于 2009-2-25 10:40:00 | 只看该作者 来自: 广东潮州 来自 广东潮州
4# 显卡修好了
出差几天回来。刚看到。谢谢。说得很清楚。找时间我试试。
