查看: 776|回复: 0
DS18B20测量温度数据传送
发表于 2016-2-25 12:34:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 山东青岛 来自 山东青岛
*  晶振:11.0592MHZ
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit DS=P2^2;           //define interface
uint temp;             // variable of temperature
uchar flag1;            // sign of the result positive or negative
sbit wela1=P2^4;                //段选信号的锁存器控制
sbit wela2=P2^5;
sbit wela3=P2^6;                //段选信号的锁存器控制
sbit wela4=P2^7;                //位选信号的锁存器控制
sbit beep=P2^3;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
                        0x87,0xff,0xef};
void delay(uint count)      //delay
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)       //send reset and initialization command
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)       //read a bit
   uint i;
   bit dat;
   DS=0;i++;          //i++ for delay
   DS=1;i++;i++;
   dat=DS;
   i=8;while(i>0)i--;
   return (dat);
uchar tmpread(void)   //read a byte date
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);
  return(dat);
void tmpwritebyte(uchar dat)   //write a byte to ds18b20
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)     //write 1
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
    else
      DS=0;       //write 0
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)  //DS18B20 begin change
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);  // address all drivers on bus
  tmpwritebyte(0x44);  //  initiates a single temperature conversion
uint tmp()               //get the temperature
  float tt;
  uchar a,b;
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0xbe);
  a=tmpread();
  b=tmpread();
  temp=b;
  temp<<=8;             //two byte  compose a int variable
  temp=temp|a;
  tt=temp*0.0625;
  temp=tt*10+0.5;
  return temp;
void display(uint temp)                        //显示程序
   uchar A1,A2,A2t,A3;
   A1=temp/100;
   A2t=temp%100;
   A2=A2t/10;
   A3=A2t%10;
   wela4=0;
   P0=table[A1];                //显示百位
   wela1=1;
   delay(2);
   wela1=0;
   delay(1);
   P0=table1[A2];                //显示十位
   wela2=1;
   delay(2);
   wela2=0;
   delay(1);
   P0=table[A3];                //显示个位
   wela3=1;
   delay(2);
   wela3=0;
   delay(1);
void main()
uchar a;
  do
    tmpchange();
        for(a=10;a>0;a--)
                  display(tmp());
        if(temp>=310)         //当温度超过31度,蜂鸣器便会报警。
                        P1=0x00;
                        beep=0;
                else
                        beep=1;
                        P1=0xff;
  } while(1);
