查看: 3420|回复: 8
西数家族Mariner,1672板号,部分日志
发表于 2015-10-31 14:25:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东深圳 来自 广东深圳
2015-10-26 12:20:00 Power On Reset Immediate - SUCCESS by
WD5000 FW:01.01A01 SN:1234567890 (ROYL selected) port 0xC800
Logical: Cyls 16383, Heads 16, Sectors 63, LBA 976773168, 500Gb
Controller Buffer Size: 8192Kb
Family: Mariner (Royl)
2015-10-26 12:20:11 FmtSelect Set DCM 1 - SUCCESS by
2015-10-26 12:20:14 All Steps: 46, Current: 1
2015-10-26 12:37:06 All Steps: 46, Current: 1
[J:\WDR5.3\固件自动备份目录\1425W\]
2015-10-26 12:37:39 All Steps: 46, Current: 1
2015-10-26 12:37:43 Clear SMART - SUCCESS by
2015-10-26 12:37:51 Clear IBI Abort Code - SUCCESS by
2015-10-26 12:37:52 Set SelfScan Step to 1 - OK
2015-10-26 12:37:52 Enable PST Mode - OK
2015-10-26 12:38:05 Power On Reset Immediate - SUCCESS by
2015-10-26 12:40:45 B1 - 快速扫描/测试用户区 - SUCCESS by
2015-10-26 12:40:45 C4 - 磁头读写参数/飞檐高度调整 - Start
2015-10-26 13:25:47 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015-10-26 13:25:47 C3 - 调整磁道密度 - Start
2015-10-26 15:15:12 C3 - 调整磁道密度 - SUCCESS by
2015-10-26 15:15:12 C8 - 调整扇区密度 - Start
2015-10-26 20:38:04 C8 - 调整扇区密度 - SUCCESS by
2015-10-26 20:38:04 B1 - 快速扫描/测试用户区 - Start
2015-10-26 20:45:09 B1 - 快速扫描/测试用户区 - SUCCESS by
2015-10-26 20:45:09 C4 - 磁头读写参数/飞檐高度调整 - Start
2015-10-26 23:18:22 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015-10-26 23:18:22 100B -  - Start
2015-10-26 23:18:54 100B -  - SUCCESS by
2015-10-26 23:18:54 1009 -  - Start
2015-10-26 23:22:00 1009 -  - SUCCESS by
2015-10-26 23:22:00 1008 -  - Start
2015-10-26 23:47:49 1008 -  - SUCCESS by
2015-10-26 23:47:49 1000 - Sector NULL - Start
2015-10-27 12:52:38 All Steps: 46, Current: 13
2015-10-27 12:52:46 Set SelfScan Step to 14 - OK
   Current Selection portion of the Field List
  format_version = 0x101
  DCM Selection = 0x1
  cur_stroke = 0x1
  phy_heads = 0x4
  used_heads = 0x4
  cur_capacity = 500.4Gb
  final_capacity_selection = 0x0
  max_fmt_LBAs = 0x3A461090 (977670288) 500Gb
  target_capacity_selection = 0x0
  target_max_fmt_LBAs = 0x0 (0) 0Gb
  hq_capacity_selection = 0x0
  HQ_max_fmt_LBAs = 0x3A461090 (977670288) 500Gb
  Zone 0 DTPI = 0x31926 (203046)
  Zone 0 KFCI = 0x5 (5)
  cur_svo_TPI = 0x38270 (230000)
  cur_data_TPI_0 = 0x3DDAF (253359)
  cur_data_TPI_1 = 0x38270 (230000)
  cur_data_TPI_2 = 0x39E83 (237187)
  cur_data_TPI_3 = 0x35F57 (221015)
  cur_data_TPI_4 = 0x0 (0)
  cur_data_TPI_5 = 0x0 (0)
  cur_data_TPI_6 = 0x0 (0)
  cur_data_TPI_7 = 0x0 (0)
  cur_KFCI_0 = 0x524 (131.6Gb)
  cur_KFCI_1 = 0x502 (128.2Gb)
  cur_KFCI_2 = 0x484 (115.6Gb)
  cur_KFCI_3 = 0x4E2 (125.0Gb)
  cur_KFCI_4 = 0x0 (0.0Gb)
  cur_KFCI_5 = 0x0 (0.0Gb)
  cur_KFCI_6 = 0x0 (0.0Gb)
  cur_KFCI_7 = 0x0 (0.0Gb)
  cur_KFCI_8 = 0x0 (0.0Gb)
  cur_KFCI_9 = 0x0 (0.0Gb)
  max_LBA_for_head_0 = 0xF5255A0 (257054112) 131Gb
  max_LBA_for_head_1 = 0xEEDF580 (250475904) 128Gb
  max_LBA_for_head_2 = 0xD76F550 (225899856) 115Gb
  max_LBA_for_head_3 = 0xE8ED020 (244240416) 125Gb
  max_LBA_for_head_4 = 0x0 (0) 0Gb
  max_LBA_for_head_5 = 0x0 (0) 0Gb
  max_LBA_for_head_6 = 0x0 (0) 0Gb
  max_LBA_for_head_7 = 0x0 (0) 0Gb
  max_user_cyls_for_head_0 = 0x0 (0)
  max_user_cyls_for_head_1 = 0x0 (0)
  max_user_cyls_for_head_2 = 0x0 (0)
  max_user_cyls_for_head_3 = 0x0 (0)
  max_user_cyls_for_head_4 = 0x0 (0)
  max_user_cyls_for_head_5 = 0x0 (0)
  max_user_cyls_for_head_6 = 0x0 (0)
  max_user_cyls_for_head_7 = 0x0 (0)
  max_virt_cyls_for_head_0 = 0x2639E (156574)
  max_virt_cyls_for_head_1 = 0x23936 (145718)
  max_virt_cyls_for_head_2 = 0x24E0E (151054)
  max_virt_cyls_for_head_3 = 0x229E1 (141793)
  max_virt_cyls_for_head_4 = 0x0 (0)
  max_virt_cyls_for_head_5 = 0x0 (0)
  max_virt_cyls_for_head_6 = 0x0 (0)
  max_virt_cyls_for_head_7 = 0x0 (0)
  rsvd_svo_cyls = 0x200
  rsvd_data_cyls = 0x100
  trks_per_clstr_svo = 0x80
  trks_per_clstr_rsvd = 0x0
  trks_per_clstr_for_head_0 = 0x0
  trks_per_clstr_for_head_1 = 0x0
  trks_per_clstr_for_head_2 = 0x0
  trks_per_clstr_for_head_3 = 0x0
  trks_per_clstr_for_head_4 = 0x0
  trks_per_clstr_for_head_5 = 0x0
  trks_per_clstr_for_head_6 = 0x0
  trks_per_clstr_for_head_7 = 0x0
  stroke = 1
  DCM = 1
Hd0 TPI = 44
Hd1 TPI = 17
Hd2 TPI = 16
Hd3 TPI = 8
Hd4 TPI = 0
Hd5 TPI = 0
Hd6 TPI = 0
Hd7 TPI = 0
Hd0 Capacity = 2
Hd1 Capacity = 3
Hd2 Capacity = 7
Hd3 Capacity = 4
Hd4 Capacity = 0
Hd5 Capacity = 0
Hd6 Capacity = 0
Hd7 Capacity = 0
2015-10-27 12:53:10 Clear IBI Abort Code - SUCCESS by  - -
2015-10-27 12:53:10 Set SelfScan Step to 14 - OK
2015-10-27 12:53:11 Enable PST Mode - OK
2015-10-27 12:53:18 Power On Reset Immediate - SUCCESS by
2015-10-27 12:54:21 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015-10-27 12:54:21 B2 - 用户区优化 - Start
WD3200B FW:01.01A01 SN:1234567890 (ROYL selected) port 0xC800
Logical: Cyls 16383, Heads 16, Sectors 63, LBA 625142448, 320Gb
IBI Common Log:
Test Count 14 - 09:50:36
1    D8    D8     0   1   1  00:02:47  00:02:47
2    D1     0     0   1   1  03:17:06  03:17:06
3    DD    DD     0   1   1  00:00:20  00:00:20
4    DB    DB     0   1   1  01:47:18  01:47:18
5    D5    D5     0   1   1  00:00:54  00:00:54
6    D4    D4     0   3   3  00:01:32  00:00:27
7    D3    D3     0   1   1  00:00:04  00:00:04
8    D2    D2     0   1   1  00:06:34  00:06:34
9    BB    BB     0   2   2  00:02:02  00:01:51
10    B6    B6     0   1   1  00:00:19  00:00:19
11    B9    B9     0   1   1  03:08:36  03:08:36
12    BA    BA     0   1   1  01:16:44  01:16:44
13  3402     0     0   1   1  00:02:32  00:02:32
14    D7    D7     0   1   1  00:03:48  00:03:48
Abort Section:
Abort Code:      4, Test ID:    0, Test Status: 0
Current Test ID: 0, Abort Code: 0, Test Status: 0
Soft Error Counter:0, Soft Error Total:1028
SPT Defect Statistical Chart
Head 0 = 708     ( Tracks: 152    , Sectors: 556    , Max: 21842  )
Head 1 = 4093    ( Tracks: 685    , Sectors: 3408   , Max: 21842  )
Head 2 = 1206    ( Tracks: 163    , Sectors: 1043   , Max: 21842  )
Head 3 = 21842   ( Tracks: 7879   , Sectors: 13963  , Max: 21842  )
发表于 2015-11-2 13:55:18 | 只看该作者 来自: 广东潮州 来自 广东潮州
Head 3 = 21842   ( Tracks: 7879   , Sectors: 13963  , Max: 21842  )爆了
发表于 2015-11-18 21:26:08 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
如何处理,砍头3吧
发表于 2015-11-19 14:17:11 | 只看该作者 来自: 辽宁 来自 辽宁
PST流程PST流程PST流程
发表于 2015-11-26 13:22:57 | 只看该作者 来自: 中国 来自 中国
爆头了有用不了多久,换固件再跑吧.要不就只有砍头了
发表于 2015-11-26 13:24:22 | 只看该作者 来自: 中国 来自 中国
满容出盘问题不大
发表于 2015-12-5 12:36:48 | 只看该作者 来自: 河南鹤壁 来自 河南鹤壁
调整CAP重跑可出盘。
发表于 2015-12-9 16:08:18 | 只看该作者 来自: 广东广州 来自 广东广州
自动砍头了,成320G
发表于 2015-12-23 20:49:05 | 只看该作者 来自: 广东云浮 来自 广东云浮
有通刷固件吗?传个呗
