查看: 3100|回复: 5
ST380011A盘的问题
发表于 2009-1-1 20:36:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东湛江 来自 广东湛江
ST380011A盘的问题
这个盘曾做了SF ,从F到T,做了N2,,22和N2,AA,22,格式化了,有太多的坏道,现在不知怎么办,另外录像中终端里的信息是什么意思?在读LDR时它的地址是如何填写的,读ROM时也是怎样填写的?这个盘出这个问题,我们应如何才能修好它?谢谢!!
ST380011A.rar
1.78 MB, 下载次数: 99, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2009-1-1 20:38:01 | 只看该作者 来自: 广东湛江 来自 广东湛江
AT Er 00 Nwt Er 47 RdWr 0018.00.0001
ATA St 50 Er 00 Op ec a,0000/0/00,00 00 00
Niwot:  4070f968  ff  0000f968.4070.000 00db 0000  e6b0 0001
AutoRd Err 47 at 000018.01.0045
CE Log EC=47  Rtype=25 OV=0 STStatus0
SCAN Error
AutoRd Err 47 at 000018.01.0046
(P)(H)PATA Reset
CE Log EC=0  Rtype=36 OV=0 STStatus0
Master
(S)PATA Reset
CE Log EC=0  Rtype=29 OV=0 STStatus0
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
(S)PATA Reset
Master
ATA St 50 Er 00 Op 42 e,  010ebae,ff00 0000 0000
Niwot:  0010ebae  ff  0000ebae.10.000 0000 8000  0700 033e
SCAN Error
AutoRd Err 47 at 000018.01.0047
SCAN Error
发表于 2009-1-24 23:05:36 | 只看该作者 来自: 山东淄博 来自 山东淄博
用的什么软件 是3000   还是效率源  是效率源 看看是不是写硬盘已加密 我这个也是   先砍头 改了型号 改了容量 后不死心 重写固件 不出现加密了 我这个是伺服没做完 出现的这种情况  现在还有少量的绿块 因为过年没修
发表于 2009-1-27 13:17:40 | 只看该作者 来自: 四川成都 来自 四川成都
固件区有坏道,并且伴随有个磁头快出问题了;建议砍头
发表于 2009-2-1 11:01:54 | 只看该作者 来自: 广东湛江 来自 广东湛江
我觉得可能也是头坏了,但不知是那个坏,另外,不知如何用指令来砍,可以说一下吗??谢谢!!
发表于 2009-2-2 21:29:32 | 只看该作者 来自: 广西南宁 来自 广西南宁
认同楼上的,肯定有一个头坏了
