- 积分
- 1359
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2014-7-4
- 精华
13#
发表于 2015-7-10 18:32:10
只看该作者
来自: 广东广州 来自 广东广州
1, S5_ON added to the NPN tube PQ18 B conduction, low P p-channel PQ17 G tube, PQ17 conduction. VIN_SRC19V flows through the PQ17 to the 8 leg of the operational amplifier.
2, standby chip of linear voltage VL = 5V, after the PR84/PR86 is about 2.5V to PU5A 3 feet.
3, S5_ON added to the N channel PQ19, VL=5V PR83 and negative temperature coefficient resistance PR41, PR41 at room temperature for 10K, the voltage is about to get 4.46V PU5A 2.
3, 4 foot positive = 2.5V less than 2 feet negative = 4.46V. OP 1 foot open drain output low level, low level signal to the N channel PQ15 tube G, PQ15 cutoff. So far SYS_SHDN# will not be right. |
