查看: 1969|回复: 2
鼠标也搞DIY
发表于 2015-5-22 19:35:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 中国 来自 中国
鼠标也搞DIY
不太喜欢底下发光,
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
1.                             先叉掉。。。。file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg
2.                             搞个内部图file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg
3.                             主板整出来file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image018.jpg
4.                             找到发光管file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image020.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image022.jpg
5.                             拆下来file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image024.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image026.jpg
6.                             找一个,红外发射管,遥控器上的也可以,注意正负,我这里取得是红外触摸屏上的file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image028.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image030.jpg
7.                             安装上file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image032.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image034.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image036.jpg
8.                             把电路板放回鼠标中,准备试机。。。file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image038.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image040.jpg
9.                             file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image042.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image044.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image046.jpg
10.                         搞成。。。没事你也折腾一下啦。。。。。。试用一下还可以,没有任何变化,灵敏度一样,底下美光,,电池要比以前耐用一点。。。
参与人数 1下载分 +2 收起 理由
fsh + 2 三分天注定七分靠打拼,爱拼才会赢两分
发表于 2015-5-26 14:07:58 | 只看该作者 来自: 山东 来自 山东
这鼠标可真够脏滴
呵呵,习惯就好。。  详情 回复 发表于 2015-5-26 21:52
发表于 2015-5-26 21:52:42 | 只看该作者 来自: 广东广州 来自 广东广州
呵呵,习惯就好。。
