查看: 1905|回复: 4
[显卡维修]
【已修复】小影霸R550E花屏测试结果
 关闭 [复制链接]
发表于 2008-11-28 18:45:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 江苏淮安 来自 江苏淮安
如题:全面测试结果
RV370/M22 A12b (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 10 32 33 48 49 50 51 53 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDB0 8 9 10 11 12 13 14 15 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 8 9 10 11 12 13 14 15 ...
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 1 2 3 4 5 6 7 9 ... MDB0 8 9 10 11 12 13 14 15 ...
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 2 4 5 6 7 8 9 10 ... MDB0 8 9 10 11 12 13 14 15 ...
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 1 2 3 4 7 8 9 10 ... MDB0 8 9 10 11 12 13 14 15 ...
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
显存正反各四颗,哪颗坏了?
正面排列:U32   U35
                                    U34
                                    U33
反面排列:U36  U31
                                    U30
                                    U29
先换掉U35再测MDB 32 33 34 35 36 37 38 39 报错,又换掉U36再测MDB 48 50 ,加焊U36后OK
[ 本帖最后由 郭郭有志 于 2008-11-29 12:51 编辑 ]
参与人数 1下载分 +10 威望 +3 收起 理由
郭郭有志 + 10 + 3 原创内容
发表于 2008-11-28 22:10:51 | 只看该作者 来自: 上海 来自 上海
排列和料号
最好发个照片
发表于 2008-11-28 22:17:43 | 只看该作者 来自: 江苏淮安 来自 江苏淮安
把曾版点拨一下,测试结果中那么多,关键看哪些测试结果,再根据图纸看显存定位。
发表于 2008-11-30 11:11:56 | 只看该作者 来自: 福建福州 来自 福建福州
回复 #3 盱眙桂林 的帖子
是啊,哪位大哥能否讲讲每项测试都代表什么意思?
发表于 2008-12-10 23:05:06 | 只看该作者 来自: 福建福州 来自 福建福州
我快晕了,但是最后LZ说换掉了U36后还出错,加焊后就OK了,我觉得怎么怪怪的呀, 是因为什么呢
