查看: 1969|回复: 0
ST340015A跑SF不过。
发表于 2008-11-23 22:06:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 吉林四平 来自 吉林四平
就几秒钟就停这了,这是为什么呢?
Interface task reset
Ref 01EA - Hd Msk 0A00 - Switch to full int.
                   Ready
C2 - ST340015A(S) Grand 2A3, Head 12
ROM.02.03
Key 29h Ld, Rev 00.00.0000.11
Key 01h Ld, Rev 03.01.0082.19
Key 11h Ld, Rev 03.01.0082.19
Key 03h Ld, Rev 03.01.0082.19
Key 0Ch Ld, Rev 6E.C2.06.13
Key 09h Ld, Rev 12.F2
Key 0Eh Ld, Rev 74.00
N50,,22
T>N4,,22
T>Key 03h Ld, Rev 03.01.0082.19
Begin Test 04
UStack=AE00
Goodcopy=03 KEY 01
KEY 01h Valid
MR=0 TA=0 FcFb=0 OTRd=0 EarlyRd=0 Splash=0 Rload=0 VGA=0
ForcedSync=0 Burnish=0 FIR=0 RunOut=0 MaxECC=0 ECC2=0 ECC1=0 ECC0=0
Data=00 Write=00 GlobalData=00 RetryMode=00
Single trk - Hd 0, 2EE0 mS cmd timeout
Write unsafe is now disabled.
Write unsafe is now enabled.
UStack=AE00
OkEnd Test 04
Begin Test 07
UStack=AE00
HEAD  1x WEIGHTS      2x WEIGHTS       3x WEIGHTS       24x WEIGHTS
00    -0503  6E79*     034E -0042     -0112 -0402      000A -05E4
The AFC  1x sum of squares weight limit is HEX 2710
The AFC  2x sum of squares weight limit is HEX 1388
The AFC  3x sum of squares weight limit is HEX 1388
The AFC 24x sum of squares weight limit is HEX 1388
UStack=AE00
AbEnd Test 07
Begin Test 4E
UStack=AE00
TLog 07 - Health 0200 - Time = 00:00:00 - Sns = 00000000 - Spdn=00
Log4E - Cert Summary:ROM.02.03.090.19
Ovly - 03.01.0082.19
(DSN: 5LA0XLAH)
MSN 51A5309750W3061D48X
TLog 04 - Health 0000 - Time = 00:00:08 - Sns = 00000000 - Spdn=00
TLog 0C - Health 0000 - Time = 00:08:34 - Sns = 00000000 - Spdn=00
TLog 10 - Health 0000 - Time = 00:36:02 - Sns = 00000000 - Spdn=00
TLog 08 - Health 0000 - Time = 04:17:38 - Sns = 00000000 - Spdn=00
TLog 33 - Health 0000 - Time = 00:00:12 - Sns = 00000000 - Spdn=00
TLog 12 - Health 0000 - Time = 00:00:58 - Sns = 00000000 - Spdn=00
TLog 15 - Health 0000 - Time = 00:02:49 - Sns = 00000000 - Spdn=00
TLog 1A - Health 0000 - Time = 00:18:56 - Sns = 00000000 - Spdn=00
TLog 13 - Health 0000 - Time = 00:04:14 - Sns = 00000000 - Spdn=00
TLog 1D - Health 0000 - Time = 00:25:15 - Sns = 00000000 - Spdn=00
TLog 0E - Health 0000 - Time = 00:00:10 - Sns = 00000000 - Spdn=00
TLog 18 - Health 0000 - Time = 00:01:32 - Sns = 00000000 - Spdn=00
TLog 1E - Health 0000 - Time = 00:02:48 - Sns = 00000000 - Spdn=00
TLog 1F - Health 0000 - Time = 00:03:05 - Sns = 00000000 - Spdn=00
TLog 0A - Health 0000 - Time = 00:06:27 - Sns = 00000000 - Spdn=00
TLog 30 - Health 0000 - Time = 00:00:08 - Sns = 00000000 - Spdn=00
TLog 36 - Health 0000 - Time = 00:00:12 - Sns = 00000000 - Spdn=00
TLog 20 - Health 0000 - Time = 00:02:12 - Sns = 00000000 - Spdn=00
TLog 29 - Health 0000 - Time = 00:44:59 - Sns = 00000000 - Spdn=00
TLog 39 - Health 0000 - Time = 01:12:16 - Sns = 00000000 - Spdn=00
TLog 34 - Health 0000 - Time = 00:00:14 - Sns = 00000000 - Spdn=00
TLog 3B - Health 0000 - Time = 00:00:07 - Sns = 00000000 - Spdn=00
TLog 32 - Health 0000 - Time = 00:57:38 - Sns = 00000000 - Spdn=00
TLog 35 - Health 0000 - Time = 00:00:13 - Sns = 00000000 - Spdn=00
TLog 3C - Health 0000 - Time = 00:00:03 - Sns = 00000000 - Spdn=00
TLog 38 - Health 0000 - Time = 00:00:01 - Sns = 00000000 - Spdn=00
TLog 3D - Health 0000 - Time = 00:00:02 - Sns = 00000000 - Spdn=00
TLog 37 - Health 0000 - Time = 00:05:54 - Sns = 00000000 - Spdn=00
TLog 3E - Health 0000 - Time = 00:00:33 - Sns = 00000000 - Spdn=00
TLog 23 - Health 0000 - Time = 00:20:28 - Sns = 00000000 - Spdn=00
TLog 19 - Health 0000 - Time = 00:23:24 - Sns = 00000000 - Spdn=00
TLog 21 - Health 0000 - Time = 00:03:46 - Sns = 00000000 - Spdn=00
TLog 14 - Health 0000 - Time = 00:00:20 - Sns = 00000000 - Spdn=00
TLog 26 - Health 0000 - Time = 00:03:00 - Sns = 00000000 - Spdn=00
TLog 22 - Health 0000 - Time = 00:06:56 - Sns = 00000000 - Spdn=00
TLog 40 - Health 0000 - Time = 00:00:00 - Sns = 00000000 - Spdn=00
TLog 4A - Health 0000 - Time = 00:04:13 - Sns = 00000000 - Spdn=00
TLog 42 - Health 0000 - Time = 00:48:45 - Sns = 00000000 - Spdn=00
TLog 45 - Health 0000 - Time = 00:03:40 - Sns = 00000000 - Spdn=00
TLog 43 - Health 0000 - Time = 00:00:07 - Sns = 00000000 - Spdn=00
TLog 49 - Health 0000 - Time = 00:00:38 - Sns = 00000000 - Spdn=00
TLog 46 - Health 0000 - Time = 00:19:13 - Sns = 01000283 - Spdn=00
TLog 47 - Health 0000 - Time = 00:19:14 - Sns = 00000000 - Spdn=00
TLog 4D - Health 0000 - Time = 00:11:10 - Sns = 00000000 - Spdn=00
TLog 4C - Health 0000 - Time = 00:18:43 - Sns = 00000000 - Spdn=00
TLog 4B - Health 0000 - Time = 00:00:04 - Sns = 00000000 - Spdn=00
Total Time = 12:17:01
UStack=AE00
UStack=AE00
AbEnd Test 4F
T>
