5720| 29
Thinkpad E40 待机电流0.005电压低 有3V 5V 不触发 |
该主题被收录于: 笔记本cpu风扇 https://www.chinafix.com/zt/18248-1.html 有待机不触发 https://www.chinafix.com/zt/69882-1.html 不上电池不触发 https://www.chinafix.com/zt/1577-1.html 电池开机掉电 https://www.chinafix.com/zt/31951-1.html 无待机电压 https://www.chinafix.com/zt/14806-1.html 待机电压 高 https://www.chinafix.com/zt/100153-1.html 无待机电流 https://www.chinafix.com/zt/40740-1.html 待机电流大 https://www.chinafix.com/zt/83631-1.html | ||
相关帖子 |
