查看: 2208|回复: 0
[维修求助]
telnet和winscp 开SSH服务进入路由器命令行
发表于 2014-3-31 08:52:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 贵州贵阳 来自 贵州贵阳
BusyBox v0.60.0 (2010.07.24-08:33+0000) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
# help
Built-in commands:
        . : break cd continue eval exec exit export help login newgrp
        read readonly set shift times trap umask wait
# cd /tmp
# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00020000 00001000 "boot"
mtd1: 003a8000 00001000 "linux"
mtd2: 00317520 00001000 "rootfs"
mtd3: 00010000 00001000 "ML1"
mtd4: 00010000 00001000 "ML2"
mtd5: 00008000 00001000 "T_Meter1"
mtd6: 00008000 00001000 "T_Meter2"
mtd7: 00001000 00001000 "POT"
mtd8: 00001000 00001000 "board_data"
mtd9: 00006000 00001000 "nvram"
以上是614v10的telnet信息,用winscp连接拒绝,是路由ssh服务没开,那位大哥指教一二,小弟万分感谢!
