查看: 1822|回复: 0
[显卡维修]
在线求助显卡R3测试结果判断
发表于 2013-4-1 16:32:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 湖北武汉 来自 湖北武汉
各位朋友大家好,小弟才刚刚接触到显卡维修,有个测试结果看不懂 希望大家能指教一下
显卡七彩虹X550CF黄金版
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1  ] Fill                                                : PASS
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[3  ] RW column (GUI)                                     : PASS
[4  ] RW page (GUI)                                       : PASS
[5  ] RW channel (GUI)                                    : PASS
[6  ] Data mask                                           : PASS
[7  ] Macro + Micro8x2 tiling read                        : PASS
[8  ] Macro + Micro4x4 tiling write                       : PASS
[9  ] Byte swap macro+micro8x2 read                       : PASS
[10 ] Byte swap macro+micro4x4 write                      : PASS
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : PASS
[15 ] Line slopes/dir/P/solid                             : PASS
TEST RESULT SUMMARY:
RV370/M22 A13 (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : PASS
    Error ID G0VB023
    Error ID G0TR055
Failure detected.
