查看: 2021|回复: 1
场管参数
发表于 2012-6-11 14:05:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 中国 来自 中国
型 号材料管脚用 途参 数
   3DJ6NJ低频放大20V0.35MA0.1W
   4405/R9524
   2E3CNMOSGDS开 关600V11A150W0.36
   2SJ117PMOSGDS音频功放开关400V2A40W
   2SJ118PMOSGDS高速功放开关140V8A100W50/70nS0.5
   2SJ122PMOSGDS高速功放开关60V10A50W60/100nS0.15
   2SJ136PMOSGDS高速功放开关60V12A40W 70/165nS0.3
   2SJ143PMOSGDS功放开关-60V16A35W90/180nS0.035
   2SJ172PMOSGDS激 励-60V10A40W73/275nS0.18
   2SJ175PMOSGDS激 励-60V10A25W73/275nS0.18
   2SJ177PMOSGDS激 励-60V20A35W140/580nS0.085
   2SJ201PMOSn
   2SJ306PMOSGDS激 励???60V14A40W30/120nS0.12
   2SJ312PMOSGDS激 励60V14A40W30/120nS0.12
   2SK30NJSDG低放音频-50V0.5mA0.1W0.5dB
   2SK30ANJSDG低放低噪音频-50V0.3-6.5mA0.1W0.5dB
   2SK108NJSGD音频激励开关50V1-12mA0.3W70 1DB
   2SK118NJSGD音频话筒放大-50V0.01A0.1W0.5dB
   2SK168NJGSD高频放大-30V0.01A0.2W100MHz1.7dB
   2SK192NJDSG高频低噪放大18V12-24mA0.2W100MHz1.8dB
   2SK193NJGSD高频低噪放大20V0.5-8mA0.25W100MHz3dB
   2SK214NMOSGSD高频高速开关160V0.5A30W
   2SK241NMOSDSG高频放大-20V0.03A0.2W100MHz1.7dB
   2SK304NJGSD音频功放30V0.6-12mA0.15W
   2SK385NMOSGDS高速开关400V10A120W100/140nS0.6
   2SK386NMOSGDS高速开关450V10A120W100/140nS0.7
   2SK413NMOSGDS高速功放开关140V8A100W0.5 (2SJ118)
   2SK423NMOSSDG高速开关100V0.5A0.9W4.5
   2SK428NMOSGDS高速开关60V10A50W45/65NS0.15
   2SK447NMOSSDG高速低噪开关250V15A150W0.24可驱电机
   2SK511NMOSSDG高速功放开关250V0.3A8W5.0
   2SK534NMOSGDS高速开关800V5A100W4.0
   2SK539NMOSGDS开关900V5A150W2.5
   2SK560NMOSGDS高速开关500V15A100W0.4
   2SK623NMOSGDS高速开关250V20A120W0.15
   2SK727NMOSGDS电源开关-900V5A125W110/420nS2.5
   2SK734NMOSGDS电源开关450V15A150W160/250nS0.52
   2SK785NMOSGDS电源开关500V20A150W105/240nS0.4
   2SK787NMOSGDS高速开关900V8A150W95/240nS1.6
   2SK790NMOSGDS高速功放开关500V15A150W0.4 可驱电机
   2SK791NMOSGDS电源功放开关850V3A100W4.5 可驱电机
   2SK794NMOSGDS电源开关900V5A150W2.5 可驱电机
   2SK817NMOSGDS电源开关60V26A35W40/230nS0.055
   2SK832NMOSGDS高速开关900V4A85W55/100nS4.0
   2SK899NMOSGDS功放开关500V18A125W130/440nS0.33
   2SK962NMOSGDS电源开关900V8A150W280/460nS2.0
   2SK940NMOSSDG激励.驱动60V0.8A0.9W0.55螺线管驱动
   2SK1007NMOSGDS功放开关450V5A60W60/130nS1.6
   2SK1010NMOSGDS高速开关500V6A80W70/130nS1.6
   2SK1011NMOSGDS高速开关450V10A100W110/240nS0.65
   2SK1012NMOSGDS高速开关500V10A100W110/240nS0.9
   2SK1015NMOSGDS功放开关450V18A125W170/230nS0.45
   2SK1016NMOSGDS电源开关500V15A125W170/230nS0.55
   2SK1017NMOSGDS电源开关500V20A150W250/490nS0.35
   2SK1019NMOSGDS电源开关450V35A300W360/900nS0.2
   2SK1020NMOSGDS电源开关500V30A300W360/900nS0.25
   2SK1060NMOSGDS功放开关100V5A20W50/140nS0.27
   2SK1081NMOSGDS激励,驱动800V7A125W 145/250nS2.2
   2SK1082NMOSGDS激励,驱动900V8A125W 145/250nS2.8
   2SK1094NMOSGDS激励,驱动60V15A25W80/300nS0.065
   2SK1101NMOSGDS功放开关450V10A50W165/360nS0.65
   2SK1117NMOSGDS电源开关-600V6A100W1.25
   2SK1118NMOSGDS电源开关-600V6A45W65/105nSD1.25
   2SK1119NMOSGDS电源开关-1000V4A100W3.8
   2SK1120NMOSGDS电源开关-1000V8A150W1.8
   2SK1161NMOSGDS电源开关450V10A100W75/135nS0.8
   2SK1170NMOSGDS电源开关
发表于 2015-8-1 14:45:00 | 只看该作者 来自: 广东东莞 来自 广东东莞
楼主是修电视的。。以前
