查看: 2923|回复: 0
在ST_MEM软件中回写ATA的指令
发表于 2008-6-9 14:12:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 安徽合肥 来自 安徽合肥
Try this now, it SDLD supports. Malformed tracks, so long
Sozdash file with the extension. Cmd
inside it is this
STR/e0, 0 / 0
SLEEP/2000
SEND_FILE/512/overlay.trk / <0 / <5D / 1
should be.
In this example, the file name for example, can call as you want. Before this cook image of the file. Opens NEH-editor and cut off from the end of last FF (they are usually several rows). All that remained from the beginning - and it will overlay your image. Pre-check the image size, it must be a multiple of 512! The image put in a folder with ST-Mem, but not in a folder CMD (it only batch files).
When zalesh ST-Mem 'box in memory of those komandnikom, need to write it on pancakes, that is
T> c.
Fse It takes 15-20 minutes total-something.
Good luck!
