- 积分
- 8289
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2007-3-24
- 精华
发表于 2007-5-2 22:29:35
只看该作者
来自: 江苏苏州 来自 江苏苏州
Important info concerning VLDT:
VLDT is directly dependant on VChipset! That means VLDT can never exceed VChipset. For example for a VLDT of 1.5V you would need to set VChipset to at least 1.55V. And so on...
The higher you set VChipset, the higher the range of adjustable VLDT voltages.
关于VLDT的重要信息:
VLDT直接依赖于VChipset!即VLDT永远不可能超过VChipset。例如要获得1.5V 的VLDT你至少需要设定VChipset为1.55V。等等。
设定的VChipset电压越高VLDT的电压调整范围越大。
VLDT Measure
Please have a look at the next page. The picture which shows the VChipset measuring points, also shows the measuring points for VLDT as they are located directly next to eachother.
VLDT 测量
请看一下下一页。图上给出VChipset的测量点,也给出了VLDT的测量点,它们的位置相邻。
在图中: 红色标记=VChipset 蓝色标记=VLDT
[ 本帖最后由 张先生 于 2007-5-3 00:10 编辑 ] |
