查看: 3609|回复: 5
[显卡维修]
七彩虹镭风X550 CF黄金版花屏
发表于 2012-1-31 18:23:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南商丘 来自 河南商丘
  前几天翻出来同片老卡。其中有几片小影霸6600LE 。主芯片坏。扔了。还有一片XFX 7300GT 加焊了显存OK了。今天又修了一片镭风X550 CF黄金版  双128M显卡。如图:
DDR 1 的。小花。用R3测试如下:
R3MEMID version 1.12, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
  errcount: 12582400
  MDA0: 16 23
Failing bits in test [2] Data line toggle (GUI)
  errcount: 6290688
  MDA0: 16 23
Failing bits in test [3] RW column (GUI)
  errcount: 4194304
  MDA0: 16 23
Failing bits in test [4] RW page (GUI)
  errcount: 4194176
  MDA0: 16 23
Failing bits in test [5] RW channel (GUI)
  errcount: 4194176
  MDA0: 16 23
Failing bits in test [6] Data mask
  errcount: 8388352
  MDA0: 16 23
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 2183168
  MDA0: 16 23
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 2183317
  MDA0: 16 23
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 12582912
  MDA0: 16 23
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 12582904
  MDA0: 16 23
Failing bits in test [11] Marco+Micro8x2 alignment write
  errcount: 37376
  MDA0: 23
Failing bits in test [12] Macro+Micro4x4 alignment read
  errcount: 37376
  MDA0: 23
TEST RESULT SUMMARY:
RV380/M24 A23 (0x3e50) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 16 23
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDA0 23
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
看不懂。刚想学修显卡。这个显存是elexir 公司的。正反一共8颗显存。。请指教下。最好给讲怎么看R3检测结果的。
按数字进入测试 测试完在发上来吧  发表于 2012-1-31 18:30
发表于 2012-2-1 13:05:26 | 只看该作者 来自: 河南商丘 来自 河南商丘
那片550测试软件。只有这样测试的我是全部测试。如何用数字测试。。
发表于 2012-2-1 17:34:13 | 只看该作者 来自: 广东 来自 广东
右边最下面的正面或者反面颗粒问题。
同意楼主: 5.0
同意楼主: 5
应该是正面右下角的那个芯片有问题  发表于 2012-2-2 10:35
发表于 2012-2-2 10:26:24 | 只看该作者 来自: 广西桂林 来自 广西桂林
想认真学下如何看测试结果
failing bit : MDA0 16 23  详情 回复 发表于 2012-2-2 11:25
发表于 2012-2-2 11:25:43 | 只看该作者 来自: 广东 来自 广东
多谢月饼老师。就是右下边的颗粒坏了。。换上正常了。。测试KO。。。多谢。了。  详情 回复 发表于 2012-2-3 12:15
发表于 2012-2-3 12:15:58 | 只看该作者 来自: 河南商丘 来自 河南商丘
