- 积分
- 10
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2011-12-23
- 精华
26#
发表于 2012-1-22 17:54:00
只看该作者
来自: 马来西亚 来自 马来西亚
卖家提供的SMD
Suit for welding, remove or repair packaged devices such as
BGA,PBGA,CSP,multi-layer substrates , EMI metallic shield
product and solder/lead free Rework 、welding
要点
1. Upper Heater (German infrared heater)
2. Highly Sensitive K-temperature sensor
3. PCB Table
4. Power Switch
5. Bottom Temperature Control
6. Cooling Switch
7. Lighting Switch
8. Stop Switch
9. Start Switch
10. Upper Programmable Temperature Control(USB connection notebook computer,
carries on the curve control)
11. Bottom Heater (German infrared heater 900W)
12. LED lamp(Import LED lamp, long service life, the luminosity high)
13. X-Y Lifting Regulator
14. Upper FAN (Taiwan imports fan, cooling fast)
15. Bottom FAN (Taiwan imports fan, cooling fast,Within the machine accessories heat
dissipation, security)
16. Above section connection mouth(The Upper heating, fan)
17. Temperature probe connection mouth (Upper)
18. 220V power
19. Connect computers serial interface(IR9000 support USB connection, using a laptop
computer) |
