- 积分
- 2036
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2006-10-28
- 精华
发表于 2008-5-5 16:42:04
只看该作者
来自: 四川乐山 来自 四川乐山
T>N2,,22
T> VALID Cert Disk Code Detected - Revision # .088
Cert Table loaded
No valid SeaDex script in buffer.
Begin Test 02
ASCII logging on
Not Power Cycling
Temp Diode 008A
( 27 C )
Not Power Cycling
Zones 0-F, Heads 0-1, adaptives set to defaults
Preamp Sent Greater than Max Allowed Bias (09-08)
Head Mask FFFF -
Read Bias - Head 0 1 2 3
9 9
Head Mask FFFF - Switch to full int.
Spin Ready
ASCII logging off
(to0083F,00757,0000,00,31)$Head Mask FFFF - Switch to full int.
Spin Ready
ASCII logging on
(to0083F,00757,0000,00,4C)Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 19D6 servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 0080 servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0000 servo clocks.
Greycode Index Skew (h0) = 0000 servo sectors.
Greycode Index Skew (h1) = 0002 servo sectors.
Greycode Index Skew (h2) = 0000 servo sectors.
Greycode Index Skew (h3) = 0000 servo sectors.
ASCII logging off
Ref Trk Tan Timing Skew (h0 to h1) = 19CB servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 007E servo clocks.
(to04ED2,00757,0000,00,29)$Head Mask FFFF - Switch to full int.
Spin Ready
(to04ED2,00757,0000,00,83)Greycode Index Skew (h0) = 0000 servo sectors.
ASCII logging on
Calibrating Physical Track 0 on heads 0 thru 1
Finding Maximum Eccentricity ...
Calibrating Head 1 ...
DAC value = FF66
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
Calibrating Head 0 ...
Radial Offset Table:
Head 0 Offset = AAA
Head 1 Offset = A40
Head 2 Offset = 1388
Head 3 Offset = 1388
Radial ID Delta Offset Table - RPO:
Head 0 Offset = 0
Head 1 Offset = 25
Head 2 Offset = E769
Head 3 Offset = E769
Ref Trk Tan Timing Skew (h0 to h1) = 19CE servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 007F servo clocks.
Disk 00
RTE Amp = 009B servo clocks (div by 64). Sector = 008Fh. Trk/2 = B2BFh.
RTE Amp = 007C servo clocks (div by 64). Sector = 008Ah. Trk/2 = 8F02h.
RTE Amp = 006F servo clocks (div by 64). Sector = 0085h. Trk/2 = 6B44h.
RTE Amp = 005F servo clocks (div by 64). Sector = 0085h. Trk/2 = 4787h.
RTE Amp = 0059 servo clocks (div by 64). Sector = 0083h. Trk/2 = 23C9h.
RTE Amp = 005B servo clocks (div by 64). Sector = 007Dh. Trk/2 = 000Ch.
Disk 01
RTE Amp = 0000 servo clocks (div by 64). Sector = 0000h. Trk/2 = 0000h.
RPO Calibration!
Head 0 Offset = AAA
Head 1 Offset = A40
Head 0 Offset = 0
Head 1 Offset = 28
Head 2 Offset = DE8B
Head 3 Offset = DE8B
Head 00
Zone 00: 00018 - 0132D 1100 (044C) 687.097
Zone 01: 0132E - 03BFE 1045 (0415) 663.594
Zone 02: 03BFF - 05D87 1012 (03F4) 644.516
Zone 03: 05D88 - 07831 990 (03DE) 627.097
Zone 04: 07832 - 09073 953 (03B9) 606.774
Zone 05: 09074 - 0A797 916 (0394) 585.484
Zone 06: 0A798 - 0C72C 880 (0370) 551.613
Zone 07: 0C72D - 0D653 836 (0344) 535.777
Zone 08: 0D654 - 0E8AC 806 (0326) 515.881
Zone 09: 0E8AD - 0FD7A 770 (0302) 491.129
Zone 0A: 0FD7B - 10DD3 733 (02DD) 471.216
Zone 0B: 10DD4 - 1204F 691 (02B3) 448.680
Zone 0C: 12050 - 137F9 660 (0294) 417.339
Zone 0D: 137FA - 145B5 616 (0268) 401.985
Zone 0E: 145B6 - 155F4 586 (024A) 381.567
Zone 0F: 155F5 - 164F8 550 (0226) 357.097
Head 01
Reserve: 0EBE4 - 0EC6A 640 (0280) 454.147
Total KBAs = 0957BB33
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
No entries in Log
All Hds 0-1, All Cyls 00018-164F8, Rnd data
Performing AFC Zone Cal
ACFC Calibration:
CRRO Orders Prior to Cal: (PES*2)^2
Cyl.Hd 2 3 4 5 6 7 8 12 24
00018.00 0091 0004 0001 0001 0019 0002 0004 0001 0001
02000.00 0090 0001 0004 0000 0014 0000 0004 0001 0001
04000.00 0079 0001 0004 0001 000a 0000 0004 0002 0001
06000.00 0064 0000 0001 0001 001d 0000 0004 0001 0001
08000.00 0052 0000 0000 0000 0011 0001 0004 0001 0000
0a000.00 0052 0000 0000 0001 0011 0001 0001 0001 0000
0e000.00 0044 0000 0000 0000 000a 0000 0004 0001 0000
10000.00 0052 0001 0001 0001 000a 0004 0004 0001 0000
12000.00 0051 0000 0001 0000 0004 0005 0004 0002 0000
14000.00 0044 0005 0001 0004 0001 0004 0004 0001 0000
16000.00 0065 0001 0001 0004 0001 000a 000a 0004 0000
00018.01 000a 0000 0001 0000 0022 0000 0001 0004 0001
02000.01 0011 0001 0001 0000 0014 0001 0001 0001 0001
04000.01 0010 0001 0001 0001 001a 0001 0000 0001 0000
06000.01 0010 0005 0001 0004 001d 0000 0004 0000 0000
08000.01 0019 0001 0000 0004 0025 0000 0005 0001 0000
0a000.01 0019 0001 0000 0009 0028 0000 0004 0000 0000
0e000.01 001a 0000 0001 0009 0028 0001 0005 0000 0000
10000.01 000a 0000 0009 0019 0035 0001 0001 0001 0000
12000.01 0008 0000 0004 0035 0049 0004 0001 0002 0001
14000.01 000a 0001 0010 0041 0055 0009 0000 0002 0000
16000.01 0012 0004 0019 006d 0068 0010 0000 000a 0000
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, NPML=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=1, ECC 1=1, ECC 0=1
Data=02, Write=40, ID=1E
Channel Srvo Table
Head Addr VGA SATT Tap5 Tap6 Tap3 Tap7 Tap2 Tap8 Tap9 XDC
00 A548 79 72 5E AF 4A 96 A3 84 8B 96
01 A552 88 72 55 B3 48 90 A2 87 86 96
Adapt Servo Zone 09
Adapt Servo 0000f313.00
Adapts Loaded
Rbck DATA load
NPML 00
Test 0000f313.00 0000a16f BER 00000001
Adjust ATTR 00 VGAS 6a VGAR 60 FREQR 80 within _ATT
MRASYM 80 0000b444 BER 00000004
MRASYM 64 0000a372 BER 00000004 update 64 hold
Servo Zone 11, OD [0000D899.0,FC5D,025D,C0]
Left Bath = FEF9, Right Bath = FFB5 : Pick (FF57) ( Min/Max AGC 6CFF )
Servo Zone 11, ID [0000EDDE.0,FD09,0309,C0]
Left Bath = FF9B, Right Bath = 0076 : Pick (0008) ( Min/Max AGC 65FF )
Servo Zone 12, OD [0000EDEF.0,FD0A,030A,C0]
Left Bath = FF9E, Right Bath = 0079 : Pick (000B) ( Min/Max AGC 65FF )
Servo Zone 12, ID [000103BA.0,FDBF,03BF,C0]
Left Bath = 0059, Right Bath = 0126 : Pick (00BF) ( Min/Max AGC 70FF )
Test 0000f313.00 0000a232 BER 00000fff
Servo Zone 1, OD [00000067.0,F744,FD44,C0]
Left Bath = F96F, Right Bath = FA38 : Pick (F9D3) ( Min/Max AGC 5AFF )
Servo Zone 1, ID [00000748.0,F769,FD69,C0]
Left Bath = F99B, Right Bath = FA65 : Pick (FA00) ( Min/Max AGC 56FF )
Servo Zone 2, OD [00000759.0,F76A,FD6A,C0]
Left Bath = F998, Right Bath = FA67 : Pick (F9FF) ( Min/Max AGC 5AFF )
Servo Zone 2, ID [00000E41.0,F787,FD87,C0]
Left Bath = F9B8, Right Bath = FA8D : Pick (FA22) ( Min/Max AGC 59FF )
Servo Zone 3, OD [00000E52.0,F788,FD88,C0]
Left Bath = F9B6, Right Bath = FA84 : Pick (FA1D) ( Min/Max AGC 5AFF )
Servo Zone 3, ID [00001702.0,F7AF,FDAF,C0]
Left Bath = F9F1, Right Bath = FABA : Pick (FA55) ( Min/Max AGC 5AFF )
Test 0000130d.00 0000b44c BER 00000fff
Test 0000f313.00 00009b42 BER 00000fff
Adjust ATTR 00 VGAS 6b VGAR 65 FREQR 81 within _ATT
MRASYM 64 00009e92 BER 00000fff
MRASYM 60 0000a1c2 BER 00000fff hold
Default Tap Weight 00000000 Settle Tap Weight 00000154
XDCTAP 96 000087ee BER 00000000 adapt
XDCTAP 6a 00008b5a BER 00000000 hold
CUTOFF Lower 021b Upper 032f Step 0003 Right 17 Mask 00000008
Default 033a 00008ca8 BER 00000000
Floor 1 0c 00017811 000332bf
Left 1 031e 000115e3
Middle 0 0324 0000b109
Right 1 032f 000095c1
Lowest 1 032d 000095c1
Restore 033a 00008d10 BER 00000000
Update Default Servo Cutoff and Range 033A
SV TAP5 Lower 0020 Upper 00df Step 0006 Right 1f Mask 00001000
Default 0065 00008e7f BER 00000000
Floor 1 20 00009186 00009186
Left 1 002c 000081de
Middle 1 004c 00008683
Right 1 006d 00009080
Lowest 1 0032 00007bdb
Z = -A1/(2*A2) : 0000
X = Z + Xavg : 000F
Curve 007a 00009765
New 004c 00008bf4 BER 00000000
00008c84 BER 00000000 _ATT 01 VGAS 69 VGAR 4f FREQR 80 Taps frozen read adapt
Current Tap Weight 000051c6 diff ffffae3a tap limits
00008ca2 BER 00000000 _ATT 01 VGAS 6b VGAR 49 FREQR 81 Taps frozen read adapt
Current Tap Weight 00000014 diff 000051b2 tap limits
00008a72 BER 00000000 _ATT 01 VGAS 68 VGAR 4e FREQR 81 Taps frozen read adapt
Current Tap Weight 00000018 diff fffffffc Save servo Force servo update
Rbck Default DATA load
Test 0000f313.00 0000adb3 BER 00000fff
Adapt Servo 0000f313.01
Adapts Loaded
Rbck DATA load
NPML 00
Test 0000f313.01 0001bb29 BER 00000033
Adjust ATTR 00 VGAS 86 VGAR 78 FREQR 7d within _ATT
MRASYM 80 0001bdac BER 00000035
MRASYM c4 000112e7 BER 00000012 update c4 hold
Servo Zone 11, OD [0000D903.1,FC5D,025D,C0]
Left Bath = FF13, Right Bath = FFB9 : Pick (FF66) ( Min/Max AGC 83FF )
Servo Zone 11, ID [0000EE48.1,FD09,0309,C0]
Left Bath = FFC9, Right Bath = 0073 : Pick (001E) ( Min/Max AGC 81FF )
Servo Zone 12, OD [0000EE59.1,FD0A,030A,C0]
Left Bath = FFCF, Right Bath = 006E : Pick (001E) ( Min/Max AGC 83FF )
Servo Zone 12, ID [00010424.1,FDBF,03BF,C0]
Left Bath = 008D, Right Bath = 012C : Pick (00DC) ( Min/Max AGC 83FF )
Test 0000f313.01 0000db92 BER 00000fff
Servo Zone 0, OD [00000020.1,F70A,FD0A,C0]
Left Bath = F961, Right Bath = FA13 : Pick (F9BA) ( Min/Max AGC 72FF )
Servo Zone 0, ID [000000C0.1,F73C,FD3C,C0]
Left Bath = F968, Right Bath = FA15 : Pick (F9BE) ( Min/Max AGC 73FF )
Servo Zone 1, OD [000000D1.1,F744,FD44,C0]
Left Bath = F962, Right Bath = FA0B : Pick (F9B6) ( Min/Max AGC 70FF )
Servo Zone 1, ID [000007B2.1,F769,FD69,C0]
Left Bath = F9A1, Right Bath = FA49 : Pick (F9F5) ( Min/Max AGC 72FF )
Servo Zone 2, OD [000007C3.1,F76A,FD6A,C0]
Left Bath = F989, Right Bath = FA37 : Pick (F9E0) ( Min/Max AGC 74FF )
Servo Zone 2, ID [00000EAB.1,F787,FD87,C0]
Left Bath = F9BA, Right Bath = FA62 : Pick (FA0E) ( Min/Max AGC 76FF )
Servo Zone 3, OD [00000EBC.1,F788,FD88,C0]
Left Bath = F9A7, Right Bath = FA54 : Pick (F9FD) ( Min/Max AGC 74FF )
Servo Zone 3, ID [0000176C.1,F7AF,FDAF,C0]
Left Bath = F9E3, Right Bath = FA90 : Pick (FA39) ( Min/Max AGC 74FF )
Test 0000130d.01 00012e87 BER 00000fff
Test 0000f313.01 0000d51c BER 00000fff
Adjust ATTR 00 VGAS 85 VGAR 81 FREQR 83 Read 0043 within _ATT
MRASYM c4 0000d6a4 BER 00000fff
MRASYM be 0000d838 BER 00000fff hold
XDCTAP 96 0000c42b BER 00000000 adapt
XDCTAP 67 0000c974 BER 00000000 hold
Default 033a 0000cbf8 BER 00000000
Floor 1 0c 0001e420 0003765d
Left 1 031e 00015e70
Middle 0 0324 0000fdb3
Right 1 032f 0000d0cf
Lowest 1 032d 0000d0cf
Restore 033a 0000cb53 BER 00000000
Default 0065 0000cb98 BER 00000000
Floor 1 20 0000b8a3 0000d20c
Left 1 0020 0000b8a3
Middle 1 002b 0000b901
Right 1 0037 0000b4d8
Lowest 1 0032 0000b4d8
X = Z + Xavg : 000F
Curve 007a 0000d7eb
New 002b 0000b8dd BER 00000000
0000bb75 BER 00000000 _ATT 01 VGAS 87 VGAR 69 FREQR 81 Taps frozen read adapt
Current Tap Weight 0000662d diff ffff99d3 tap limits
0000b5e8 BER 00000000 _ATT 01 VGAS 84 VGAR 6d FREQR 7f Taps frozen read adapt
Current Tap Weight 00000034 diff 000065f9 tap limits
0000b828 BER 00000000 _ATT 01 VGAS 88 VGAR 6c FREQR 81 Taps frozen read adapt
Current Tap Weight 00000026 diff 0000000e Save servo Force servo update
Test 0000f313.01 00014a75 BER 00000fff
HiTemp Bias BackOff Head 0 1 2 3
9 9
Media 0000
Adapt Data Zone 00
Test 000009a2.00 0000ed0d BER 00000004
Test 000009a2.00 0000dfdd BER 00000006
Adapt Data 000009a2.00
Rbck DATA load
NPML 00
Test 000009a2.00 0000d2e8 BER 00000000
Adjust ATTR 00 VGAS 7e VGAR 4f FREQR 83 SRVTEST 10
Adjust ATTR 01 VGAS 7f VGAR 7b FREQR 81 within _ATT VGAR FREQR
MRASYM 80 0000daf0 BER 00000000
MRASYM 5e 0000c9fd BER 00000002 update 5e hold
Test 00000067.00 0000c0d8 BER 00000001
Servo Zone 01 OD OFST Lower f973 Upper fa32 Step 0006 Right 1f Mask 00004340
Default f9d3 0000b7d9 BER 00000000
Floor 1 19 00028292 00028292
Left 1 f9b5 00020e40
Middle 1 f9e7 0000b3a6
Right 1 fa1a 000232a1
Lowest 1 f9eb 0000b0e9
X = Z + Xavg : 000F
Curve f9cd 0000dca5
New f9e7 0000b6dd BER 00000000 AUTO
Test 00000748.00 0000c1cd BER 00000003
Servo Zone 01 ID OFST Lower f9a0 Upper fa5f Step 0006 Right 1f Mask 00008340
Default fa00 0000cc02 BER 00000001
Floor 1 1b 000350d6 000350d6
Left 1 f9dc 0002d0e9
Middle 1 fa14 0000af20
Right 1 fa4d 00034f4d
Lowest 1 fa12 0000af20
X = Z + Xavg : 000F
Curve f9fa 0000eda0
New fa14 0000b074 BER 00000001 AUTO
Test 00000759.00 0000b57d BER 00000000
Servo Zone 02 OD OFST Lower f99f Upper fa5e Step 0006 Right 1f Mask 00004340
Default f9ff 0000c2d5 BER 00000001
Floor 1 1a 0002d694 0002d694
Left 1 f9db 00029888
Middle 1 fa0d 0000b236
Right 1 fa40 000239b0
Lowest 1 fa0b 0000b236
X = Z + Xavg : 000F
Curve f9f9 0000da79
New fa0d 0000b696 BER 00000001 AUTO
Test 00000e41.00 0000bad1 BER 00000001
Servo Zone 02 ID OFST Lower f9c2 Upper fa81 Step 0006 Right 1f Mask 00008340
Default fa22 0000b6f1 BER 00000000
Floor 1 1b 00036b81 00036b81
Left 1 fa04 00026591
Middle 1 fa3c 0000bb3f
Right 1 fa75 00035d34
Lowest 1 fa2e 0000af71
X = Z + Xavg : 000F
Curve fa1c 0000dec1
New fa3c 0000c513 BER 00000000
Test 00000e52.00 0000bf46 BER 00000003
Servo Zone 03 OD OFST Lower f9bd Upper fa7c Step 0006 Right 1f Mask 00004340
Default fa1d 0000b9bd BER 00000000
Floor 1 1a 0003745c 0003745c
Left 1 f9ff 0002cee8
Middle 1 fa31 0000b57e
Right 1 fa64 0002c167
Lowest 1 fa2f 0000b57e
X = Z + Xavg : 000F
Curve fa17 0000e13d
New fa31 0000bc77 BER 00000000
Adjust ATTR 01 VGAS 7d VGAR 7b FREQR 80 within _ATT VGAR FREQR
Test 000009a2.00 0000bba5 BER 00000000
Noise target 00000000
Rbck Noise OFF
Rbck DATA save
WRITE_I Lower 0003 Upper 001b Step 0001 Right 18 Mask 00000342
Default 000e 0000c7ad BER 00000000
Floor 1 13 0000cf50 0000d498
Left 1 000b 0000ce19
Middle 1 0012 0000d0fc
Right 1 0019 0000ce2f
Lowest 1 0014 0000c913
Z = -A1/(2*A2) : 0004
X = Z + Xavg : 0010
Curve 0013 0000c941
New 0012 0000c3f2 BER 00000002 AUTO
Test 000009a2.00 0000b0ec BER 00000000
MRASYM 5e 0000abb1 BER 00000001
MRASYM 59 0000aadb BER 00000000 update 59 hold
PRECOMP Lower 0000 Upper 000a Step 0001 Right 0a Mask 00000004
Default 0003 0000aa67 BER 00000000
Floor 1 0b 0000a983 0000bef4
Left 1 0000 0000a983
Middle 1 0002 0000b110
Right 1 0004 0000a8cd
Lowest 1 0003 0000a7e5
Z = -A1/(2*A2) : FFFE
X = Z + Xavg : 0003
Curve 0003 0000a7e5
New 0002 0000a854 BER 00000000
Test 000009a2.00 0000ac39 BER 00000000
XDCTAP 96 0000a0a3 BER 00000000 adapt
XDCTAP 52 0000a2be BER 00000000 hold
CUTOFF Lower 0514 Upper 0538 Step 0002 Right 12 Mask 00000348
Default 052c 0004ca36 BER 00000000
Floor 1 0d 0004ed2a 00053994
Left 1 0524 0004e86c
Middle 1 052c 000502bc
Right 1 0534 0004e9a8
Lowest 1 052a 0004b88c
New 052c 0004e269 BER 00000000
BOOST Lower 0000 Upper 0016 Step 0001 Right 16 Mask 00000360
Default 000b 0004f3e1 BER 00000000
Floor 1 17 0005b29f 0005b29f
Left 1 0002 00059b9b
Middle 1 0009 00051271
Right 1 0011 000596f0
Lowest 1 000c 0004d46b
Z = -A1/(2*A2) : FFFF
X = Z + Xavg : 000A
Curve 000a 0004e56c
New 0009 0004e312 BER 00000000 AUTO
TAPDELT Lower 0000 Upper 000f Step 0001 Right 0f Mask 00000350
Default 000b 0004efb7 BER 00000000
Floor 1 10 000588a0 00067ff6
Left 1 0007 000565b6
Middle 1 000b 0004df3f
Right 1 000f 000588a0
Lowest 1 000c 0004d86c
X = Z + Xavg : 000B
Curve 000b 0004df3f
New 000b 0004e50f BER 00000000 AUTO
Servo Zone 01 OD OFST Lower f987 Upper fa46 Step 0006 Right 1f Mask 00004340
Default f9e7 0000b49f BER 00000000
Floor 1 19 000293c5 000293c5
Left 1 f9b7 0001d320
Middle 1 f9e6 0000b68b
Right 1 fa16 0001cdb1
Lowest 1 f9e1 0000b68b
X = Z + Xavg : 000F
Curve f9e1 0000b68b
New f9e6 0000b77f BER 00000000
Servo Zone 01 ID OFST Lower f9b4 Upper fa73 Step 0006 Right 1f Mask 00008340
Default fa14 0000b704 BER 00000001
Floor 1 1e 00047c5e 00047c5e
Left 1 f9d8 0003cf02
Middle 1 fa13 0000b77a
Right 1 fa4f 0003e3a1
Lowest 1 fa0e 0000b77a
X = Z + Xavg : 000E
Curve fa08 0000bc5e
New fa13 0000b53f BER 00000000 AUTO
Servo Zone 02 OD OFST Lower f9ad Upper fa6c Step 0006 Right 1f Mask 00004340
Default fa0d 0000b9cf BER 00000000
Floor 1 1b 0003871f 0003871f
Left 1 f9dd 00028cd0
Middle 1 fa12 0000b3b6
Right 1 fa48 00035ba9
Lowest 1 fa0d 0000b3b6
Z = -A1/(2*A2) : 07C8
X = Z + Xavg : 07D7
Curve fa61 0092aef1
New fa12 0000bdfe BER 00000001
Servo Zone 02 ID OFST Lower f9dc Upper fa9b Step 0006 Right 1f Mask 00008340
Default fa3c 0000c3c4 BER 00000000
Floor 1 1d 0003e964 0003e964
Left 1 fa00 0003b769
Middle 1 fa3b 0000b932
Right 1 fa77 0003936e
Lowest 1 fa30 0000b846
X = Z + Xavg : 000F
Curve fa36 0000b932
New fa3b 0000c12f BER 00000000 AUTO
Servo Zone 03 OD OFST Lower f9d1 Upper fa90 Step 0006 Right 1f Mask 00004340
Default fa31 0000c045 BER 00000001
Floor 1 1c 0003e924 0003e924
Left 1 f9fb 00033c24
Middle 1 fa30 0000b8dc
Right 1 fa66 0002db61
Lowest 1 fa2b 0000b8dc
X = Z + Xavg : 000F
Curve fa2b 0000b8dc
New fa30 0000c177 BER 00000002
CUTOFF Lower 0524 Upper 0534 Step 0001 Right 10 Mask 00000348
Default 052c 0004d53f BER 00000000
Floor 1 0a 0004f35f 000502aa
Left 1 0529 0004e54b
Middle 1 052a 0004f3d0
Right 1 052c 0004ed2a
Lowest 1 052b 0004d97d
New 052a 0004f619 BER 00000000
BOOST Lower 0001 Upper 0012 Step 0001 Right 11 Mask 00000360
Default 0009 00052415 BER 00000002
Floor 1 12 00058a63 00058a63
Left 1 0007 0005665e
Middle 1 000b 00050158
Right 1 000f 00057b4b
Lowest 1 000b 00050158
X = Z + Xavg : 0008
Curve 0009 00052d5f
New 000b 0004d929 BER 00000000 AUTO
Default 000b 00050323 BER 00000000
Floor 1 10 0005d471 0006524c
Left 1 0006 00055899
Middle 1 000a 00050e56
Right 1 000f 0005d471
Lowest 1 000b 0004e0b4
Z = -A1/(2*A2) : 0003
X = Z + Xavg : 000A
Curve 000a 00050e56
New 000a 00052c1f BER 00000000
Rbck Noise OFF
Adjust ATTR 01 VGAS 7f VGAR 76 FREQR 81 within _ATT VGAR FREQR
MRASYM 59 0000c173 BER 00000000
MRASYM 5e 0000c075 BER 00000001 update 5e adapt
Test 000009a2.00 0000b12c BER 00000001
MRASYM 5e 0000ba87 BER 00000002
MRASYM 69 0000b77c BER 00000000 update 69 hold
NPML 03 0000ba4a BER 00000000 NPML update
NPML 03 00020c27 BER 00000000
MRASYM 69 00020b42 BER 00000000
MRASYM 68 000209aa BER 00000000 update 68 adapt
BETTER UPDATE TAPS Rbck DATA save
Media 0000
Test 000009a2.01 0001003e BER 00000004
Test 000009a2.01 0000fa2c BER 00000000
Adapt Data 000009a2.01
Rbck DATA load
NPML 00
Test 000009a2.01 0000ff58 BER 00000000
Adjust ATTR 00 VGAS 97 VGAR 66 FREQR 81 within _ATT VGAR FREQR
MRASYM 80 00019e47 BER 0000000c
MRASYM d7 0000fbf5 BER 00000002 update d7 hold
Test 00000020.01 0000e5df BER 00000006
Servo Zone 00 OD OFST Lower f95a Upper fa19 Step 0006 Right 1f Mask 00004340
Default f9ba 0000e407 BER 00000001
Floor 1 1d 0004500a 0004500a
Left 1 f98a 0003e240
Middle 1 f9c2 0000eebc
Right 1 f9fb 00034ea1
Lowest 1 f9c0 0000eebc
X = Z + Xavg : 000F
Curve f9b4 0000fc73
New f9c2 0000ebdb BER 00000003
Test 000000c0.01 0000e42d BER 00000002
Servo Zone 00 ID OFST Lower f95e Upper fa1d Step 0006 Right 1f Mask 00008340
Default f9be 0000db72 BER 00000005
Floor 1 1d 0004433a 0004433a
Left 1 f98e 000350e9
Middle 1 f9c6 0000eb15
Right 1 f9ff 00034aac
Lowest 1 f9c4 0000eb15
X = Z + Xavg : 000F
Curve f9b8 0000f5fa
New f9c6 0000ea82 BER 00000005
Test 000000d1.01 0000e8f7 BER 00000002
Servo Zone 01 OD OFST Lower f956 Upper fa15 Step 0006 Right 1f Mask 00004340
Default f9b6 0000e08a BER 00000001
Floor 1 1b 000441c6 000441c6
Left 1 f98c 00037f18
Middle 1 f9c1 0000e6eb
Right 1 f9f7 0003e088
Lowest 1 f9bc 0000e6eb
X = Z + Xavg : 000F
Curve f9b0 0000f822
New f9c1 0000f02e BER 00000000
Test 000007b2.01 0000f70b BER 00000006
Servo Zone 01 ID OFST Lower f995 Upper fa54 Step 0006 Right 1f Mask 00008340
Default f9f5 0000f00f BER 00000001
Floor 1 1a 0003ec1d 0003ec1d
Left 1 f9cb 0003d74c
Middle 1 f9fd 0000f2f4
Right 1 fa30 00032803
Lowest 1 fa01 0000f1fa
X = Z + Xavg : 000F
Curve f9ef 00011053
New f9fd 0000f666 BER 00000000
Test 000007c3.01 0000e5df BER 00000004
Servo Zone 02 OD OFST Lower f980 Upper fa3f Step 0006 Right 1f Mask 00004340
Default f9e0 0000eff8 BER 00000000
Floor 1 1b 0004095e 0004095e
Left 1 f9b6 0003489e
Middle 1 f9eb 0000eae7
Right 1 fa21 0003c12c
Lowest 1 f9e6 0000eae7
X = Z + Xavg : 000F
Curve f9da 000102d7
New f9eb 0000eeb8 BER 00000000 AUTO
Test 00000eab.01 0000fc42 BER 00000004
Servo Zone 02 ID OFST Lower f9ae Upper fa6d Step 0006 Right 1f Mask 00008340
Default fa0e 0000f66c BER 00000002
Floor 1 1a 0003b09d 0003b09d
Left 1 f9ea 0002e96b
Middle 1 fa1c 0000f088
Right 1 fa4f 0003325f
Lowest 1 fa1a 0000f088
X = Z + Xavg : 000F
Curve fa08 00011851
New fa1c 0000fd5e BER 00000002
Test 00000ebc.01 0000f644 BER 00000000
Servo Zone 03 OD OFST Lower f99d Upper fa5c Step 0006 Right 1f Mask 00004340
Default f9fd 0000f739 BER 00000002
Floor 1 1b 0004184a 0004184a
Left 1 f9d3 0003c5b2
Middle 1 fa08 0000f54e
Right 1 fa3e 0003b477
Lowest 1 fa03 0000f54e
X = Z + Xavg : 000F
Curve f9f7 000112ea
New fa08 0000f4d3 BER 00000002 AUTO
Adjust ATTR 00 VGAS 97 VGAR 69 FREQR 82 within _ATT VGAR FREQR
Test 000009a2.01 0000fa84 BER 00000000
Rbck Noise OFF
Rbck DATA save
Default 000e 00010fff BER 00000008
Floor 1 10 00010b35 00011642
Left 1 0013 00010ad2
Middle 1 0017 0001051e
Right 1 001b 0001083b
Lowest 1 0019 000104e5
Z = -A1/(2*A2) : 0007
X = Z + Xavg : 0013
Curve 0016 000107d8
New 0017 00010879 BER 00000003 AUTO
Test 000009a2.01 0000f691 BER 00000004
MRASYM d7 0000f46a BER 00000001
MRASYM d2 0000f746 BER 00000003 hold
Default 0003 0000fb54 BER 00000005
Floor 1 0b 000108c8 00010a96
Left 1 0000 000108c8
Middle 1 0003 0000ff87
Right 1 0006 00010114
Lowest 1 0002 0000efb9
X = Z + Xavg : 0003
Curve 0003 0000ff87
New 0003 0000fd8c BER 00000008
Test 000009a2.01 0000fdd2 BER 00000001
XDCTAP 96 0000fc11 BER 00000007 adapt
XDCTAP 5c 00010228 BER 00000002 hold
Default 052c 0005c450 BER 00000000
Floor 1 0b 0005d594 000661d9
Left 1 0528 0005d2e1
Middle 1 0530 0005dfe4
Right 1 0538 0005c180
Lowest 1 052a 0005b8d6
New 0530 0005b3c6 BER 00000000 AUTO
Default 000b 0005c623 BER 00000000
Floor 1 17 00064e40 0006ad83
Left 1 0000 00064e40
Middle 1 0007 0005fd78
Right 1 000e 000619d1
Lowest 1 0008 0005d59a
X = Z + Xavg : 0009
Curve 0009 0005de85
New 0007 0005bd1e BER 00000000 AUTO
Default 000b 0005ec72 BER 00000000
Floor 1 10 00066c1c 0007dbf3
Left 1 0008 00065bad
Middle 1 000b 0005d552
Right 1 000f 00066c1c
Lowest 1 000c 0005d4d5
Z = -A1/(2*A2) : 0005
X = Z + Xavg : 000C
Curve 000c 0005d4d5
New 000b 0005e0fd BER 00000000 AUTO |
