ѸάÍø
²é¿´: 1383|»Ø¸´: 0
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
±Ê¼Ç±¾¿ª»ú´íÎó´úÂë
[¸´ÖÆÁ´½Ó]
Í·Ïñ±»ÆÁ±Î
Ìøתµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2011-9-3 21:24:39 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ±±¾©º£µí À´×Ô ±±¾©º£µí
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØȨÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
±Ê¼Ç±¾bios
            Symptom / Error £¨¿ª»ú´íÎó´úÂ룩 FRU / Action in Sequence£¨¼ì²é·¶Î§¼°½â¾ö·½·¨£©
            10X
            101: Interrupt failure£»£¨ÖжϹÊÕÏ£©
            102: Timer failure£»£¨¼ÆʱÆ÷¹ÊÕÏ£©
            103: Timer interrupt failure£» £¨¼ÆʱÆ÷ÖжϹÊÕÏ£©
            104: Protected mode failure£» £¨±£»¤Ä£Ê½¹ÊÕÏ£©
            105: Last 8042 command not accepted£»
            107: NMI test failure£»£¨NMI ²âÊÔʧ°Ü£©
            108: Timer bus test failure.
            109: Low meg-chip select test. 1. System board. £¨Ö÷°åÎÊÌ⣩
            110 Planar parity.) £¨ÄÚ´æÆæżУÑé³ö´í£© 1. Go to Memory Checkout 2. DIMM
            card
            3. Detach the expansion unit if it is attached to the computer.4.
            System bo
            ard.
            111I/O parity.) 1. Go to Memory Checkout2. Expansion unit or port
            replicator.
            3. System board.
            11XX
            1101: Serial_A test failure.£¨A ´®ÐпڲâÊÔʧ°Ü£© 1. Serial device £¨´®ÐÐÉ豸£©
            2. Communication cable £¨Ïà¹ØͨѶµçÀ£©3. System board £¨Ö÷°å£©
            12XX
            1201: Serial_B test failure.£¨B ´®ÐпڲâÊÔʧ°Ü£© 1. System board (infrared)
£¨¼ì
            ²éÖ÷°å£ººìÍâÏß¿Ú£©
            158 Hard disk password was not set even though the supervisor
            password is set.
            ) £¨³¬
            ¼¶Óû§ÃÜÂëÒÑÉ裬µ«Ó²ÅÌÃÜÂëûÓÐÉèÖã© 1. Set the password for hard disk driv
            e.£¨ÉèÖÃÓ²ÅÌÃÜÂ룩
            159 :(Hard disk password is not set the same as the supervisor
            password.) £¨Ó²ÅÌ
            ÃÜÂëÓë
            ³¬¼¶Óû§ÃÜÂë²»Ò»Ñù£© 1. Set the correct password for hard disk drive.£¨ÉèÖÃ
            ÕýÈ·µÄÓ²ÅÌÃÜÂ룩
            161:(Dead battery.) £¨CMOS µç³Ø²»ÐУ© 1. Go to Checking the Backup Battery
            2. Backup battery.£¨CMOS ±¸·Ýµç³Ø£¬ÔÚÄÚ´æ²å²ÛÅԱߣ©3. System board. £¨Ö÷°å£©
            163:(Time and date were not set.) £¨ÏµÍ³Ê±¼äûÓÐÉèºÃ»ò»ìÂÒ£© 1. Set time and dat
            e.£¨ÉèÖÃÕýÈ·µÄϵ ͳʱ¼ä£© 2. System board. £¨Ö÷°åÎÊÌ⣩
            173:(Configuration data was lost.) £¨CMOS É豸ÅäÖÃÐÅÏ¢¶ªÊ§£© 1. Select OK in
            the
            err
            or screen; then set the time and date.£¨ÔÚ ¿ª»ú ERROR »­ÃæÉÏ°´OK£¬È»ºóÉèÖÃϵ
            Í³Ê±¼ä£©
            2. Backup battery. £¨CMOS µç³ØÐèÒª¸ü»»£©3. System board. £¨Ö÷°åÎÊÌ⣩
            174:(Configuration error: Perform Checking the Installed Devices
            List before cha
            ngin
            g any FRUs.) 1. Check device configuration.2. Hard disk drive
            assembly.
            3. System board.
            175
            177
            178175: EEPROM CRC #1 error.
            177: Supervisor password check sum error.
            178: EEPROM is not functional. 1. System board. £¨¼ì²éÖ÷°å£©
            17XX
            1701: Hard disk controller failure. £¨Ó²ÅÌ¿ØÖÆÆ÷¹ÊÕÏ£©
            1780, 1790: Hard disk 0 error. £¨Ö÷Ó²ÅÌÓÐÎÊÌ⣩
            1781, 1791: Hard disk 1 error.£¨´ÓÓ²ÅÌÓÐÎÊÌ⣩ 1. Hard disk drive £¨¼ì²éÓ²ÅÌ£©
            2. System board £¨¼ì²éÖ÷°å£©
            183 :(Incorrect password entered at the supervisor password prompt.)
            £¨³¬¼¶Óû§¿ª
            »úÃÜÂë²»¶Ô£© 1. Have the user examine the password.£¨ÇëÓû§¼ì²éÃÜÂ룩
            184:(Power-on password check sum error.) £¨Power-on ÃÜÂëÓÐÎó£© 1. Reset
            the powe
            r-on
            password in Easy-Setup.£¨ÖØÉèPower-on ÃÜÂ룩
            185:(The startup sequence is not valid. Suspect that power was off
            when the star
            tup
            sequence was being updated.) £¨ÏµÍ³Æô¶¯Ë³ÐòÎÞЧ£¬»³ÒÉÊǸüÐÂÆô¶¯Ë³ÐòʱµçÔ´¹Øµô
            £© 1
            . Reset the startup sequence in Easy-Setup.£¨ÔÚEasy-Setup ÖØÉèÆô¶¯Ë³Ðò£©
            186 :1. System board. £¨¼ì²éÖ÷°å£©
            190:(A depleted battery pack was installed when the power was on.)
            £¨¿ª»úʱ£¬»úÄڱʼDZ¾µç³ØÒÑ¿ìºÄ¾¡ÁË£© 1. Go to Checking the Battery Pack.£¨¸ü
            »»»úÄڱʼDZ¾µç³Ø £©
            191XX:(PM initialization error.) £¨PM ³õʼ»¯´íÎó£© 1. System board. £¨¼ì²éÖ÷°å£©
            192:(Fan error.) £¨CPU É¢ÈÈ·çÉȹÊÕÏ£© 1. Measure the voltage of the backup
            batte
            ry. If the
            voltage is not correct, replace the backup battery.£¨¼ì²éCMOS ±¸·Ýµç³ØµÄµçѹ
            £¬µçѹ²»ÐÐʱ¸ü»» µç³Ø£© 2. Fan £¨Òª¸ü»»CPU·çÉÈ£©3. System board £¨Ö÷°åÎÊÌ⣩
            195:(The configuration read from the hibernation area does not match
            the actual
            conf
            iguration.) £¨´ÓÐÝÃßÇøÓò¶Áµ½µÄϵͳÅäÖÃÐÅÏ¢Óëʵ¼ÊÅäÖò»Í¬£© 1. Check if the c
            onfig
            uration was changed. For example, check if the DIMM card is added.
            £¨¼ì²éÅäÖÃÊÇ·ñ¸Ä¶¯£¬ÄÚ´æÓÐÎÞÔö¼ÓµÈ£©
            196:(A read error occurred in the hibernation area of the hard disk
            drive.)
            £¨ ´ÓÓ²Å̵ÄÐÝÃßÇøÓòÖжÁдʱ£¬·¢Éú´íÎó£© 1. Run the hard disk drive test. £¨²â
            ÊÔÓ²ÅÌ£©
            2. Hard disk drive.£¨¼ì²éÓ²ÅÌ£© 199XX(Resume error.) 1. System board.
            1XX 1. System board. 2XX £¨ÄÚ´æÎÊÌ⣩201: Memory data error.
            202: Memory line error 00-15.203: Memory line error 16-23.
            205: Memory test failure on on-boardmemory.
            221: ROM to RAM remap error. 1. Go to Memory Checkout.2. DIMM card.
            3. System board. 225
            (Unsupported memory module.) 1. Check if the supported DIMM is
            installed.
            2. DIMM card.3. System board.
            301, 303, 304, 305, 3XX
            (301: Keyboard error.) £¨±Ê¼Ç±¾¼üÅ̹ÊÕÏ£¬301Õâ¸ö¹ÊÕϾ­³£³öÏÖ£¬ÍùÍùÊDZʼDZ¾¸Õ¿ª»ú
            Ê±£¬²»Ð¡ÐÄ
            °´×¡¼üÅÌËùÔì³ÉµÄ£¬Ò»°ãÖ»ÒªÖØÆôµçÄÔ¼´¿É£»£© 1. Go to Keyboard or Auxiliary I
            nput Device Checkout
            2. Keyboard.3. External numeric keypad.4. External keyboard.
            5. Keyboard/mouse cable.6. System board.
            601, 6XX
            (601: Diskette drive or controller error.)
            £¨ ÈíÇý»òÈíÇý¿ØÖÆÆ÷¹ÊÕÏ£© 1. Go to Diskette Drive Checkout.
            2. Diskette drive assembly. £¨ÈíÇýÓÐûÓÐ×°ÅäºÃ£¿£©3. Diskette. 4. System b
            oard. £¨¼ì²éÖ÷°å £©
            602:(Diskette read error.)£» £¨ÈíÇý¶Á¹ÊÕÏ£© 1. Go to Diskette Drive
            Checkout2. D
            iskette.
            3. Diskette drive assembly.£¨ÈíÇýÓÐûÓÐ×°ÅäºÃ£¿£©
            604:(Unacceptable ID was read from the diskette drive.)£» 1. Go to
            Diskette Driv
            e Ch
            eckout2. Diskette drive assembly.3. System board.
            2402 1. TV Out Card 24XX
            (2401: System board video error.) £»£¨Ö÷°åÏÔʾ²¿·ÖÓÐÎÊÌ⣩ 1. System board.
            £¨¼ì²éÖ÷°åÏà¹Ø²¿ ·Ö£© 808X
            8081: PCMCIA presence test failure.(PCMCIA revision number also
            checked.)
            8082: PCMCIA register test failure. 1. PC Card slot assembly.2.
            PCMCIA device.
            3. System board. 860X(Pointing device error when TrackPoint is
            disabled.)
            £¨µ±Ö¸µã¸Ë½ûÓÃʱ£¬Íâ½ÓµÄÖ¸µãÉ豸ÓйÊÕÏ£©£»8601: System bus error-8042 mouse
            interface.
            8602: External mouse error.£¨Íâ½ÓÊó±ê¹ÊÕÏ£©£»
            8603: System bus error or mouse error. £¨×ÜÏß»òÊó±ê¹ÊÕÏ£©£» 1. External mouse.
            ¼ì²éÍâ½ÓÊó±ê£©£»
            2. External keyboard. £¨¼ì²éÍâ½Ó¼üÅÌ£©£»3. System board.£¨¼ì²éÖ÷°å£©£»
            861X
            (Pointing device error when TrackPoint is enabled.)£¨µ±Ö¸µã¸ËÆôÓÃʱ£¬Íâ½ÓµÄÖ¸µãÉè
            ±¸ÓйÊÕÏ£©£»
            8611: System bus error-I/F between 8042 and IPDC.
            8612: TrackPoint error.
            8613: System board or TrackPoint error. 1. Reseat the keyboard cable
            on the sub
            card.£¨°Ñ¼üÅÌÁ¬½ÓÖ÷°åµÄÏߣ¬Öزå°Îһϣ©£»2. Keyboard £¨¼ì²é¼üÅÌ£©£»3. Exte
            rnal mouse £¨¼ì²é Íâ½ÓÊó±ê£©£»
            4. Sub card £¨Ö÷°åÉÏÁ¬½Ó¼üÅ̵Ä×Ó¿¨£©£»5. System board £¨Ö÷°å£©£» I9990301I
            9990302I9990305
            I9990301: Hard disk error. £¨Ó²ÅÌÓйÊÕÏ£©£»
            I9990302: Invalid hard disk boot record. £¨ÎÞЧµÄÓ²ÅÌÒýµ¼¼Í¼£©£»
            I9990305: No bootable device. £¨ÎÞ¿ÉÓõÄÆô¶¯Òýµ¼É豸£©£» 1. Check that the opera
            ting system is installed in the hard disk drive. If not, install the
            opera
            ting sy
            stem.£¨¼ì²éÓ²ÅÌÉÏÓзñ°²×°²Ù×÷ϵͳ£©£»2. Reseat the boot device.£¨ÖØÐÂÉèÖÿÉ
            Æô¶¯µÄÉ豸£©£»
            3. Check the startup sequence for the correct boot device.£¨¼ì²éÆô¶¯Ë³ÐòÊÇ
            ·ñ¸úÉ豸ÕýÈ·¶ÔÓ¦ £©£»
            4. Check that the operating system has no failure and is installed
            correct
            ly.£¨¼ì²éµçÄԵIJ٠×÷ϵͳÊÇ·ñ°²×°ÕýÈ·£©£»
            I9990303(Bank-2 flash ROM check sum error.) 1. System board.
            Other codes not listed above. 1. Go to Undetermined
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ AIάÐÞ
ÖúÊÖ
оƬËÑË÷
¿ìËٻظ´
