- 积分
- 339
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-10-6
- 精华
11#
发表于 2011-8-30 00:04:52
只看该作者
来自: 云南昆明 来自 云南昆明
iamqiaowei 发表于 2011-8-29 23:44
要是能把报错的英文字母弄上来就更好了 以后留个心眼看看
报错代码大概是以下内容:
stop:0x000000A5 (0X00000011,0X00000006,0X00000000,0X00000000)
the ACPI BIOS in this system is not fully compliant with the ACPI
specification.please read the readme.txt for possible workarounds you
can also contact your system's mamufacturer for an update BIOS,or vist
http://www.hardware-update.com to see if a new BIOS is aviailable.
the BIOS in this system is not fully ACPI compliant.please comtact your
system vendor or visit http://www.hardware-update.com for an updated BIOS
if you are unable to obtain an updated BIOS or the latest BIOS supplied by
your vendor is not ACPI compliant,you can turn off ACPI mode durring text
mode setup.to do this,simple press the F7 key when you are prompted to
install storage drivers.the system will not notify you that the F7 key
was pressed.it will silently disable ACPI and allow you to continue
your installation. |
