Ñ¸Î¬Íø
²é¿´: 2942|»Ø¸´: 4
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
רҵÓÃÓï
[¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2011-6-4 21:20:53 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ÉϺ£ À´×Ô ÉϺ£
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØÈ¨ÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
ADIMM£¨advanced Dual In-line Memory Modules£¬¸ß¼¶Ë«ÖØÄÚǶʽÄÚ´æÄ£¿é£©
AMR£¨Audio£¯Modem Riser£»ÒôЧ£¯µ÷ÖÆ½âµ÷Æ÷Ö÷»ú°å¸½¼ÓÖ±Á¢²å¿¨£©
AHA£¨Accelerated Hub Architecture£¬¼ÓËÙÖÐÐļܹ¹£©
ASK IR£¨Amplitude Shift Keyed Infra-Red£¬³¤²¨ÐοÉÒÆ¶¯ÊäÈëºìÍâÏߣ©
ATX: AT Extend£¨À©Õ¹ÐÍAT£©
BIOS£¨Basic Input/Output System£¬»ù±¾ÊäÈë/Êä³öϵͳ£©
CSE£¨Configuration Space Enable£¬¿É·ÖÅä¿Õ¼ä£©
DB: Device Bay£¬É豸²å¼Ü
DMI£¨Desktop Management Interface£¬×ÀÃæ¹ÜÀí½Ó¿Ú£©
EB£¨Expansion Bus£¬À©Õ¹×ÜÏߣ©
EISA£¨Enhanced Industry Standard Architecture£¬ÔöÇ¿Ðι¤Òµ±ê×¼¼Ü¹¹£©
EMI£¨Electromagnetic Interference£¬µç´Å¸ÉÈÅ£©
ESCD£¨Extended System Configuration Data£¬¿ÉÀ©Õ¹ÏµÍ³ÅäÖÃÊý¾Ý£©
FBC£¨Frame Buffer Cache£¬Ö¡»º³å»º´æ£©
FireWire£¨»ðÏߣ¬¼´IEEE1394±ê×¼£©
FSB: Front Side Bus£¬Ç°ÖÃ×ÜÏߣ¬¼´Íⲿ×ÜÏß
FWH£¨ Firmware Hub£¬¹Ì¼þÖÐÐÄ£©
GMCH£¨Graphics & Memory Controller Hub£¬Í¼ÐκÍÄÚ´æ¿ØÖÆÖÐÐÄ£©
GPIs£¨General Purpose Inputs£¬ÆÕͨ²Ù×÷ÊäÈ룩
ICH£¨Input/Output Controller Hub£¬ÊäÈë/Êä³ö¿ØÖÆÖÐÐÄ£©
IR£¨infrared ray£¬ºìÍâÏߣ©
IrDA£¨infrared ray£¬ºìÍâÏßͨÐŽӿڿɽøÐоÖÓòÍø´æÈ¡ºÍÎļþ¹²Ïí£©
ISA: Industry Standard Architecture£¬¹¤Òµ±ê×¼¼Ü¹¹
ISA£¨instruction set architecture£¬¹¤ÒµÉèÖüܹ¹£©
MDC£¨Mobile Daughter Card£¬Òƶ¯Ê½×Ó¿¨£©
MRH-R£¨Memory Repeater Hub£¬ÄÚ´æÊý¾Ý´¦ÀíÖÐÐÄ£©
MRH-S£¨SDRAM Repeater Hub£¬SDRAMÊý¾Ý´¦ÀíÖÐÐÄ£©
MTH£¨Memory Transfer Hub£¬ÄÚ´æ×ª»»ÖÐÐÄ£©
NGIO£¨Next Generation Input/Output£¬ÐÂÒ»´úÊäÈë/Êä³ö±ê×¼£©
P64H£¨64-bit PCI Controller Hub£¬64λPCI¿ØÖÆÖÐÐÄ£©
PCB£¨printed circuit board£¬Ó¡Ë¢µç·°å£©
PCBA£¨Printed Circuit Board Assembly£¬Ó¡Ë¢µç·°å×°Å䣩
PCI: Peripheral Component Interconnect£¬»¥Á¬ÍâΧÉ豸
PCI SIG£¨Peripheral Component Interconnect Special Interest Group£¬»¥Á¬ÍâΧÉ豸רҵ×飩
POST£¨Power On Self Test,¼Óµç×Ô²âÊÔ£©
RNG£¨Random number Generator£¬Ëæ»úÊý×Ö·¢ÉúÆ÷£©
RTC: Real Time Clock£¨ÊµÊ±Ê±ÖÓ£©
KBC£¨KeyBroad Control£¬¼üÅÌ¿ØÖÆÆ÷£©
SAP£¨Sideband Address Port£¬±ß´øÑ°Ö·¶Ë¿Ú£©
SBA£¨Side Band Addressing£¬±ß´øÑ°Ö·£©
SMA: Share Memory Architecture£¬¹²ÏíÄÚ´æ½á¹¹
STD£¨Suspend To Disk£¬´ÅÅÌ»½ÐÑ£©
STR£¨Suspend To RAM£¬Äڴ滽ÐÑ£©
SVR: Switching Voltage Regulator£¨½»»»Ê½µçѹµ÷½Ú£©
USB£¨Universal Serial Bus£¬Í¨Óô®ÐÐ×ÜÏߣ©
USDM£¨Unified System Diagnostic Manager£¬Í³Ò»ÏµÍ³¼à²â¹ÜÀíÆ÷£©
VID£¨Voltage Identification Definition£¬µçѹʶ±ðÈÏÖ¤£©
VRM £¨Voltage Regulator Module£¬µçѹµ÷ÕûÄ£¿é£©
ZIF: Zero Insertion Force, Áã²åÁ¦
Ö÷°å¼¼Êõ
Gigabyte
ACOPS: Automatic CPU OverHeat Prevention System£¨CPU¹ýÈÈ****ϵͳ£©
SIV: System Information Viewer£¨ÏµÍ³ÐÅÏ¢¹Û²ì£©
ÅÍÓ¢
ESDJ£¨Easy Setting Dual Jumper£¬¼ò»¯CPUË«ÖØÌøÏß·¨£©
ºÆöÎ
UPT£¨USB¡¢PANEL¡¢LINK¡¢TV-OUTËÄÖØ½Ó¿Ú£©
оƬ×é
ACPI£¨Advanced Configuration and Power Interface£¬ÏȽøÉèÖú͵çÔ´¹ÜÀí£©
AGP£¨Accelerated Graphics Port£¬Í¼ÐμÓËÙ½Ó¿Ú£©
I/O£¨Input/Output£¬ÊäÈë/Êä³ö£©
MIOC: Memory and I/O Bridge Controller£¬ÄÚ´æºÍI/OÇÅ¿ØÖÆÆ÷
NBC: North Bridge Chip£¨±±ÇÅоƬ£©
PIIX: PCI ISA/IDE Accelerator£¨¼ÓËÙÆ÷£©
PSE36: Page Size Extension 36£­bit£¬36Î»Ò³Ãæ³ß´çÀ©Õ¹Ä£Ê½
PXB: PCI Expander Bridge£¬PCIÔöÇ¿ÇÅ
RCG: RAS/CAS Generator£¬RAS/CAS·¢ÉúÆ÷
SBC: South Bridge Chip£¨ÄÏÇÅоƬ£©
SMB: System Management Bus£¨È«ÏµÍ³¹ÜÀí×ÜÏߣ©
SPD£¨Serial Presence Detect£¬ÄÚ´æÄÚ²¿ÐòºÅ¼ì²â×°Öã©
SSB: Super South Bridge£¬³¬¼¶ÄÏÇÅоƬ
TDP: Triton Data Path£¨Êý¾Ý·¾¶£©
TSC: Triton System Controller£¨ÏµÍ³¿ØÖÆÆ÷£©
QPA: Quad Port Acceleration£¨ËĽӿڼÓËÙ£©
Í·Ïñ±»ÆÁ±Î
·¢±íÓÚ 2011-6-9 22:17:39 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«ÉîÛÚ À´×Ô ¹ã¶«ÉîÛÚ
лл¥Ö÷·ÖÏí ѧϰÁË
3#
·¢±íÓÚ 2011-6-9 22:47:54 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÉÂÎ÷Î÷°² À´×Ô ÉÂÎ÷Î÷°²
лл  Ñ§Ï°ÁË
4#
·¢±íÓÚ 2011-6-10 13:49:46 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«¹ãÖÝ À´×Ô ¹ã¶«¹ãÖÝ
ÊÕ¹ºÈÈÏߣº13682233126 QQ£º120971967
ÊÕ¹ºÈ«ººµçÔ´ÊÊÅäÆ÷ÐͺţºFSP036-1AD101C(12V3A36W£©£¬FSP048-1AD101C £¨12V4A48W) ,FSP060-1AD101C (12v5A60W),ÒÔÉÏÐͺÅÓжàÉÙÊÕ¶àÉÙ£¬ÒªÇóÈ«ÐÂ¿â´æ»õ£¬·ÇÔ­×°ÇëÎðÈÅ¡£
5#
·¢±íÓÚ 2011-6-10 15:56:18 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓÄÏÄÏÑô À´×Ô ºÓÄÏÄÏÑô
лл¥Ö÷£¬Ñ§Ï°ÁË¡£
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ AIάÐÞ
ÖúÊÖ
оƬËÑË÷
¿ìËٻظ´
