- 积分
- 380
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-4-3
- 精华
出泰克TAS485 200M模拟示波器,图片是网上的,和这个一样,机器没有质量问题。配原装探头一根。1650元
QQ:12262040
200MHz/1mv/2ns 四通道 CRT游标读出
厂家: 美国泰克
尺寸: 36x17x47cm
重量: 7.7kg
成色:8成新
- Store/Recall of 4 Setups
- Dual Time Base
- Trigger Level Indicator
- Auto Setup
- Video Triggering
- Measurement Cursors
- Ground Reference Indicator
- Combination menu/direct access controls.
Bandwidth | 200 MHz | Rise time | 1.8 ns | Number of Channels | 4 ch | Min. Vertical Sensitivity | 2 mV/div | Maximum Vertical Sensitivity | 5 V/div | Vertical(or Deflection Factor) Accuracy | 2.5 % | Input Coupling | AC,DC,GND | Input Impedance | 1 MOhm | Maximum Input Voltage | 400 V(dc+p | Main time base - lowest | 10 ns/div | Main time base - highest | 0.5 s/div | B Sweep Time Base (low) | 10 ns/div | B Sweep Time Base (high) | 5 ms/div | Time base Magnification factor | x10 | Timebase accuracy | 2 % | Trigger Source | External,Internal | Trigger Modes | Auto,Normal,TV | Trigger Sensitivity | 0.3 mV | Test Pattern Storage | 4 Patterns |
