查看: 4357|回复: 12
▆▆◣泰克TDS 340A 二手数字示波器100M带宽 500M采样 9成新 自带3.5寸软驱存储设备
 关闭 [复制链接]
发表于 2007-12-30 22:34:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东广州 来自 广东广州
TDS340A 数字示波器  9成新   特价:3680元
产地: Tektronix(美国泰克)    型号: TDS340A
QQ:284568485
电话:020-32737479
Features
100 MHz Bandwidths (100M带宽)
500 MS/s  Sampling Rates (500M采样率)
Two Input Channels (双通道输入)
Built-In 3.5 in. Floppy Disk Drive (自带3.5寸软盘驱动器)
2 mV/div to 10 V/div
AutoSetup (自动设置)
Accumulate Display Modes
2% Vertical Accuracy (垂直精度2%)
1 K Record Length (1K存储深度)
Roll Mode (波形滚动模式)
21 Automatic Measurements (21项电气参数自动测量)
FFT Analysis (FFT分析)
10 ns Peak Detect for High-speed Glitch Capture (10ns高速捕捉)
Option 14 for GPIB, RS-232-C Programmability, Parallel Printer Interface, & VGA Monitor Output (GPIB接口,RS232接口,并行打印接口)
Tektronix Digital Real-Time
With the TDS 300 Series, Tektronix redefines the low-cost digital oscilloscope. No other digital scope offers as much bandwidth and sample rate for the price. By simultaneously sampling at up to five times their bandwidth on both channels, the TDS 300 Series assures you of true acquisitions, minimizing aliasing or other digital sampling effects. Unlike other DSOs, the TDS 300 Series easily gathers enough samples to display waveforms accurately at their full bandwidth. These are the only scopes in their class to reliably acquire high speed transient or single-shot events to their full bandwidth.
Many low-cost DSOs offer only dot displays, which can be hard to interpret, especially for those accustomed to analog oscilloscopes. The TDS 300 Series has Dot, Dot Accumulate, Vector, and Vector Accumulate displays. The Accumulate display modes gather multiple waveforms for a user-defined time (500 ms to infinity), after which the screen is erased. Vector Accumulate mode uses bright vectors to superimpose the current acquisition over the accumulated waveforms. The display is erased at the user-defined time or when the acquisition setting is changed. These modes are useful for doing worst case analysis or signal monitoring. Long term monitoring is easily accomplished by setting the erase time to infinity.
如需配原装泰克二手的探头
(400M,300M,200M,100M)价格面谈
400M泰克二手探头300元/根,其它类电议或加QQ
http://www.buydz.net/product_176.html
[ 本帖最后由 惠尔 于 2007-12-30 23:00 编辑 ]
发表于 2007-12-30 22:40:48 | 只看该作者 来自: 广东广州 来自 广东广州
▆▆◣出台 泰克2440数字存储示波器 300M带宽 500M采样 8成新
厂家:美国泰克
体积:338 x 190 x 479 mm
重量:12.8 kg
带宽 300MHz 双通道 采样500MSa/s 存储深度1k 接口GP-IB
http://www.buydz.net/product_103.html
頻寬/頻道 300MHz/2CH顯示方式 數位顯示數位讀出
量測方式 數位自動量測
采样率:500MS/s
介面 GPIB
功能正常,外观及保养良好
以上报价,全部包托运
产品标准附件
  电源线 x 1 ; 测棒 (10:1/1:1) x 2
3450元  包快递
有兴趣可联系我!
QQ:284568485
邮箱:yunsyan@163.com
手机:020-32737479
发表于 2007-12-30 22:50:18 | 只看该作者 来自: 广东广州 来自 广东广州
▆▆◣ 出台几乎全新的 固纬 GOS-658G 50M 低价卖了
http://www.buydz.net/product_133.html
游标直读式示波器 GOS-658G
成色:9.5成新 ,接近全新,只有一台,机会不多,末失良机!!
产品详细介绍
特点:
频宽50MHz,双频道
延迟扫描
内藏延迟线可轻易观测波形前缘
Z轴调变输入功能
TV分离同步
7项游标读值量测功能
ALT同步触发
Hold off功能
触发准位锁定功能
CH1信号输出
产品标准附件
有兴趣可联系我!
QQ:284568485
邮箱:yunsyan@163.com
手机:020-32737479
过年了,把这台机出了,2000元,不包运费,运费30元,发德绑物流(机子是马来西亚出产的)
发表于 2007-12-30 22:54:39 | 只看该作者 来自: 广西钦州 来自 广西钦州
功能很强的示波器。。。。。。。。
发表于 2007-12-30 22:57:29 | 只看该作者 来自: 广西钦州 来自 广西钦州
前段时间买了示波器,现在才上这么强的示波器
发表于 2007-12-30 23:18:53 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
东西看上去不错,价格也还可以。
如果是真实的,还可以购买
但由于仪器的内部构造精密,仅凭外观无法判断好坏。以及网络交易的风险性。
敬请各位会员考虑周全,尽量使用支付宝进行交易。
发表于 2007-12-31 09:02:46 | 只看该作者 来自: 广东广州 来自 广东广州
欢迎大家使用支付宝,广东省内可货到付款
发表于 2007-12-31 13:37:11 | 只看该作者 来自: 四川泸州 来自 四川泸州
修主板第一台还可以,第二台稍微低了点。成色看上去还可以。
发表于 2008-1-3 14:00:07 | 只看该作者 来自: 广东广州 来自 广东广州
这几台成色都不错的,50M的就适合修家电,那两台泰克的修主板手机都没问题,呵呵
发表于 2008-1-3 20:27:38 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
楼主有没有TES1012B
发表于 2008-1-3 21:08:40 | 只看该作者 来自: 广东广州 来自 广东广州
呵呵,没有,你给出的型号是不是不误,网上也搜不到啊
发表于 2008-2-15 19:45:40 | 只看该作者 来自: 吉林通化 来自 吉林通化
确实不错,有兴趣考虑. :)
发表于 2008-2-19 13:28:13 | 只看该作者 来自: 湖北天门 来自 湖北天门
这些东西一个字,就是"贵 ''.真比其他商家卖的贵一些.
