查看: 1944|回复: 0
[显卡维修]
镭风X550 CH黄金版 256M DDR测试结果,大家进来帮忙看一下
发表于 2010-9-13 15:17:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 湖南衡阳 来自 湖南衡阳
R3MEMID version 1.12, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
  errcount: 8388472
  MDB0: 18
  errcount: 8388480
  MDB0: 18
Failing bits in test [2] Data line toggle (GUI)
  errcount: 4193792
  MDB0: 18
Failing bits in test [3] RW column (GUI)
  errcount: 8403286
  MDB0: 18 48 49 50 51 52 53 54 55
Failing bits in test [4] RW page (GUI)
  errcount: 8620296
Failing bits in test [5] RW channel (GUI)
  errcount: 4245528
Failing bits in test [6] Data mask
  errcount: 12588565
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 1186925
  errcount: 1075961
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 1386954
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 5455830
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 2558326
Failing bits in test [11] Marco+Micro8x2 alignment write
  errcount: 104
  MDB0: 48
Failing bits in test [12] Macro+Micro4x4 alignment read
  errcount: 94
  MDB0: 18 48
TEST RESULT SUMMARY:
RV370/M22 A13 (0x5b63) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 18
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
    failing bit : MDB0 18 48 49 50 51 52 53 54 ...
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDB0 48
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
显卡是非常花
正面 U2   U1                                    反面SU3     SU2
                     U8                                                       Su5
                     U12                                                     Su7
U2对面就是SU3    U8对面是SU5  大家帮忙分析一下
