查看: 9724|回复: 51
测试主板各关键点来判断主板问题
 关闭 [复制链接]
发表于 2006-9-14 18:57:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 辽宁沈阳 来自 辽宁沈阳
北桥的工作电压 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 南桥工作电压 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;时钟<br/>+3.3v &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;+3.3V &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32.768 南桥 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;<br/>+1.5V &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; +5V &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 14.318 基本时钟<br/>+1.0v Vtt参考电压 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;+1.8V &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 33mhz &nbsp;pci<br/>+1.8V hub link线 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; +0.9V &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 66mhz &nbsp;总线 &nbsp; &nbsp; &nbsp; &nbsp;<br/>+0.9v 不要忽视 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; +2v(有的有) &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 48mhz &nbsp;usb<br/>+.25V 负载电压 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; +1.75V(核心电压)<br/>+0.5V 参考<br/>+1.75V<br/>测量NB &nbsp;SB旁或背面的电容....<br/><br/>bios:方BIOS只针对intel的芯片 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 长bios(只针对via,sis方形的bios按长bios看待)<br/>1,25,27脚 &nbsp; &nbsp;vcc +3.3v &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 1pin &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 编程脚<br/>2pin &nbsp; &nbsp; &nbsp; &nbsp; 复位 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2pin-12pin,23,25pin-30pin &nbsp;地址线<br/>31pin &nbsp; &nbsp; &nbsp; &nbsp;时钟 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 13pin-15pin 17pin-21pin &nbsp; &nbsp;数据线<br/>13,14,15,17 &nbsp;4条AD线 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;16pin &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;接地<br/>23pin &nbsp; &nbsp; &nbsp; &nbsp;片选 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 22pin &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;片选<br/>24pin &nbsp; &nbsp; &nbsp; &nbsp;初始化脚 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 24pin &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;内存读<br/>16pin &nbsp; &nbsp; &nbsp; &nbsp;接地 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 21pin &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;内存写<br/>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32pin &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;vcc+5V供电<br/><br/>pci的关键点<br/>1,供电 &nbsp;A2 +12V &nbsp; &nbsp;A62 +5v &nbsp; &nbsp;B2 -12V &nbsp; A53 +3.3v<br/>2,时钟 &nbsp;B16 &nbsp;33Mhz &nbsp;由时钟IC发出<br/>3,复位 &nbsp;A15 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;由南桥发出<br/>4,Frame A34 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;帧信号,表示允许总线传输和片选一样在触发和复位瞬间可测<br/>5,32条AD线 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; A &nbsp;20,22,23,25,28,29,31,32,44,46,47,49,54,55,57,58<br/>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;B &nbsp;20,21,23,24,27,29,30,45,47,48,52,53,55,56,58(各对地阻值电压要基本一至)<br/><br/>AGP的关键点<br/>1,供电 &nbsp;A1 &nbsp;+12V &nbsp;B2 &nbsp;+5V &nbsp;A9 &nbsp;+3.3v &nbsp; B24 &nbsp;+3.3v<br/>2,vddQ &nbsp;B40 A40 &nbsp;既AGP槽的到数第二脚
[此贴子已经被心在飞翔于2006-9-15 21:03:33编辑过]
发表于 2006-9-14 22:45:54 | 只看该作者 来自: 天津武清区 来自 天津武清区
辛苦了,!
发表于 2006-9-15 01:33:46 | 只看该作者 来自: 江西南昌 来自 江西南昌
是不是原创
发表于 2006-9-15 09:36:06 | 只看该作者 来自: 黑龙江哈尔滨 来自 黑龙江哈尔滨
看看
发表于 2006-9-15 15:46:18 | 只看该作者 来自: 福建福州 来自 福建福州
楼主辛苦啦<br/>
发表于 2006-9-15 17:04:30 | 只看该作者 来自: 广东茂名 来自 广东茂名
<strong>测试主板各关键点来判断主板问题</strong>
发表于 2006-9-15 17:22:03 | 只看该作者 来自: 广西南宁 来自 广西南宁
干嘛非要回复才能看?
发表于 2006-9-15 22:26:50 | 只看该作者 来自: 浙江温州 来自 浙江温州
习学了
会员12 该用户已被删除
9#
发表于 2006-9-17 04:32:52 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
<p>不对吧南桥有5V供电吗? PCI的AD线只有31呀?</p>
发表于 2006-10-1 02:51:02 | 只看该作者 来自: 广东肇庆 来自 广东肇庆
楼主辛苦啦<br/>
发表于 2006-10-1 18:41:07 | 只看该作者 来自: 辽宁辽阳 来自 辽宁辽阳
谢谢
发表于 2006-10-8 20:16:50 | 只看该作者 来自: 河南平顶山 来自 河南平顶山
谢谢
发表于 2006-10-18 05:44:38 | 只看该作者 来自: 北京丰台 来自 北京丰台
<p>学习学习中</p><p>辛苦了LZ</p>
发表于 2006-10-24 00:26:38 | 只看该作者 来自: 北京海淀 来自 北京海淀
谢谢&nbsp; 辛苦了
发表于 2006-10-29 00:43:25 | 只看该作者 来自: 湖北荆门 来自 湖北荆门
<p>楼主,那么多点你对都量过吗?我最多知道里面的1/4</p>
发表于 2006-10-29 20:20:35 | 只看该作者 来自: 四川成都 来自 四川成都
还有,知道了有什么用对会修的人可能有点用.对我这样的人,没有用,SB,NB的点在板上那里我不知道!
发表于 2006-11-21 23:18:27 | 只看该作者 来自: 广西钦州 来自 广西钦州
虽然,现在的维修只停留在换电容上面,但无论如何还是要帮你顶的.
发表于 2006-11-29 22:38:55 | 只看该作者 来自: 广东广州 来自 广东广州
这么多的,看来要慢慢记下了
发表于 2006-11-30 19:24:49 | 只看该作者 来自: 江西南昌 来自 江西南昌
刚刚开始搞维修,谢谢了
发表于 2006-11-30 21:03:16 | 只看该作者 来自: 吉林长春 来自 吉林长春
能不能把显卡的测试点还有显存排列啥的发一下
