Ñ¸Î¬Íø
²é¿´: 2099|»Ø¸´: 8
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
[ÏÔ¿¨Î¬ÐÞ]
9550»¨ÆÁ
[¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2010-6-23 22:50:38 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ¹ãÎ÷ÄÏÄþ À´×Ô ¹ãÎ÷ÄÏÄþ
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØÈ¨ÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
±¾Ìû×îºóÓÉ ÂíÈÎÖª ÓÚ 2010-6-24 09:55 ±à¼­
9550 128M 128BIT»¨ÆÁ,ÊÇÄĸöÏÔ´æÐ¾Æ¬»µÁË.
R3²â½á¹û£º
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 8 MDB0 24 25 26 28 29 30 31 36 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
    failing bit : MDA0 8 MDB0 24 25 26 27 28 29 30 31 ...
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
    failing bit : MDA0 8 MDB0 24 25 34 35 36 37 38 39 ...
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDB0 25 26 27 28 29 30 31 33 ...
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 8 MDB0 24 25 26 27 28 29 30 34 ...
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 8 MDB0 33 34 35 36 39 40 41 42 ...
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
    failing bit : MDA0 8 MDB0 32 33 34 35 36 37 38 39 ...
    failing bit : MDA0 8 MDB0 32 33 34 35 36 37 39 40 ...
Failure detected.
·¢±íÓÚ 2010-6-23 23:02:22 | Ö»¿´¸Ã×÷Õß À´×Ô£º Õã½­º¼ÖÝ À´×Ô Õã½­º¼ÖÝ
ÄãÕâÊDzâ¶àÉٴεĽá¹ûѽ£¬ÎÒÃǵͼÊDzâÒ»´ÎÖ»³öÒ»Ðнá¹û£¬ÕâÑù¿´²»Ã÷°×
Í·Ïñ±»ÆÁ±Î
3#
·¢±íÓÚ 2010-6-23 23:10:58 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«ÉîÛÚ À´×Ô ¹ã¶«ÉîÛÚ
ʲôÀ´µÄ£¿
Í·Ïñ±»ÆÁ±Î
4#
·¢±íÓÚ 2010-6-23 23:11:19 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«ÉîÛÚ À´×Ô ¹ã¶«ÉîÛÚ
¸ãµÄÄÇô¸´ÔÓ£¿
5#
·¢±íÓÚ 2010-6-23 23:56:11 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÁÉÄþÉòÑô À´×Ô ÁÉÄþÉòÑô
ÏȲéU8ºÍU13£¬È»ºóÔÙ²âÊÔÒ»ÏÂ
6#
·¢±íÓÚ 2010-6-23 23:56:36 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÁÉÄþÉòÑô À´×Ô ÁÉÄþÉòÑô
²éÒ»ÏÂU13 U14
7#
·¢±íÓÚ 2010-6-24 10:59:38 | Ö»¿´¸Ã×÷Õß À´×Ô£º ɽ¶«Î«·» À´×Ô É½¶«Î«·»
ÄĸöÅÆ×ӵģ¿
8#
·¢±íÓÚ 2010-6-24 11:52:20 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ãÎ÷ÄÏÄþ À´×Ô ¹ãÎ÷ÄÏÄþ
ÏèÉýµÄÏÔ¿¨
9#
·¢±íÓÚ 2010-6-24 12:06:27 | Ö»¿´¸Ã×÷Õß À´×Ô£º ½­ËÕÄÏͨ À´×Ô ½­ËÕÄÏͨ
±¾Ìû×îºóÓÉ Ê®ÔÂ÷»¨¿ª ÓÚ 2010-6-24 12:07 ±à¼­
MDA0 8   ÊÇ U7£¬¿´¿´ÊDz»ÊÇÓÐÒ»¸öÅÅ×軵£¬
MDB0 24ÖÁ40ºóÃæ....ÕâЩµã¶¼ÊÇÓлµÊý¾Ýλ£¬Ó¦¸ÃU13 U14 Á©¸ö¶¼»µ
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ AIάÐÞ
ÖúÊÖ
оƬËÑË÷
¿ìËٻظ´
