查看: 6978|回复: 0
[其他]
HTC刷机错误代码含义查询及解决办法
发表于 2010-4-21 21:34:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 意大利 来自 意大利
ERROR [202, 204] : CONNECTION *连接错误 This error message will appear when the device is not connected to ActiveSync correctly. Make sure you properly connect the device to the PC through ActiveSync before running RUU. 这个错误信息将出现在设没有正确的连接,请在运行升级程序之前确定您的设备已经连接好。
ERROR [206] : MEMORY ALLOCATION*内存分配 您的内存不够 ERROR [280] : UPDATE ERROR*更新错误 When you see any of these error messages, close other running programs on the computer and run RUU again. 当您看到这条信息,清关闭您计算机上运行的其他程序,然后再尝试RUU更新程序
ERROR [208] : FILE OPEN*文件打开错误(?) ERROR [210] : FIE READ*文件读取错误(?) These error messages indicate that RUU lacks certain important files and cannot continue with the ***e. Please get the complete RUU package again. 这些错误信息表明, RUU 缺乏某些重要文件, 无法继续通过更新。再请得到完全RUU刷机包。
ERROR [212] : FILE CREATE*文件创建错误(?)
ERROR [214] : FILE WRITE*文件写入错误(?)
ERROR [222, 224]: DEVICE NOT RESPONDING*设备无反应 These error messages will appear when remote access control has failed. Check the ActiveSync connection and try running RUU again. 这些错误信息将出现远程存取控制失败了。检查同步连接和设法再运行RUU 。
ERROR [220] : MAIN BATTERY POWER*主要电池功率 This error message will appear when the device’s battery poweris not sufficient. Although RUU will instruct you to plug in the AC adapter, it still has to make sure that your device has enough power to upgrade the radio. (Even when you plug in the AC adapter, the device is unable to ***ge the battery when it is upgrading the radio). 这个错误信息将出现设备的电池功率不是充足的。请确定你手机有足够的电量一遍运行升级程序。 意思就是你少于50电量了
ERROR [238] : FILE READ*文件读取错误 This error message may appear when, for some unknown reason, the ROM image on the phone is corrupt. Download the whole RUU and try again. 这个错误信息意味着由于未知的错误您的ROM镜像无法在手机上读取运行。请下载全部RUU程序 并再尝试。
ERROR [240] : FILE OPEN*文件打开错误 When this error mesage appears, check whether the downloaded image is placed in the directory of RUU. If, for some unknown reason, you find that the ROM image is not located in the RUU folder, you have to download the RUU and retry again. 当这个错误信息出现, 请证实被下载的镜像是否被安置在RUU 目录。如果由于一些未知的原因, 您发现ROM 镜像不设置RUU 文件夹, 您必须下载RUU 并且重新刷机。
ERROR [242] : INVALID LANGUAGE*无效语言错误
ERROR [244] : INVALID MODEL ID*无效模拟身份错误
ERROR [294] : INVALID VENDER ID*无效销售商身份错误
ERROR [296] : UPGRADE ONLY*升级唯一(?) One of these error messages will appear when you use the wrong RUU to do the upgrade. RUU will check if the Model ID and Language ID are ompatible with the device. Make sure you use the appropriate RUU tool to upgrade. 这些错误信息的当中一个将出现您使用错误RUU程序 做升级。RUU 将检查如果模型身份证和语言身份证是否与设备兼容。确定您使用适当的RUU 工具升级。(RUU版本过低造成,比如用RUU2.0.2刷G4机时)
ERROR [246] : DEVICE NOT RESPONDING*设备无反应 This error message indicates that RUU cannot start the ***e process. Plase contact your service provider for assistance. 这个错误信息表明, RUU 无法开始更新过程。请与您的服务提供者联系以便获得协助。(RUU程序错误)
ERROR [248~260] : UPDATE ERROR*更新错误错误 This error occurs when there is an “open port error” before upgrading the CE ROM image. 这个错误信息表明 当有 “开放端口错误” 在升级ROM之前。 Solution: You can reset the device and runRUU again. If you still en***er an “OPEN PORT ERROR” again, reset your computer and try again. 解决方法: 请重新设置设备并运行RUU 。如果您仍然遇到”开放端口错误”, 请重新设置您的计算机并再次尝试。
ERROR [262] : UPDATE ERROR*更新错误错误 This error occurs during the CE ROM code upgrade process. 这个错误发生在 ROM 升级过程期间。 Solution: If this happens, you can jst soft-reset the device and run RUU again. The ***e process will then continue. 解决方法: 如果这种情况发生,软启动设备(手机)并运行RUU 升级程序。之后升级程序将继续运行。 Note: At this stage, the Wince is destroyed; instead, it is in upgrade mode. 注: 在这个状况下, 已写入设备的内容被毁坏(?); 反之, 它是在正常的升级方式下运行。
ERROR [264, 274] : CONNECTION*连接错误
ERROR [302,318]: UPDATE ERROR*升级错误 经过实验 是跳级刷ROM 时候显示的
ERROR [320~328] : INVALID COMMAND*无效命令 These errors seldom occur. However, if one of these errors occur, it could not be recovered and the device had to be sent back to the customer service center. In this case, you have to flash a new ROM code. 这些错误很少发生。但, 如果这些错误的当中一个发生, 它将不能恢复并且设备必须被送回到客户服务中心。在这种情况下, 您必须换一个新ROM代码。
ERROR [300] : INVALID UPDATE TOOL*无效更新工具
This error message will appear when you use the incorrect RUU version to upgrade.
这个错误信息将出现您使用不正确RUU版本(连接软件?)升级。
ERROR [330] : ROM IMAGE ERROR ROM*镜像错误
This error message will appear when you use the incorrect RUU to upgrade and the
image file size is larger than the Flash ROM size. In this case, download the
这个错误信息将出现您使用不正确RUU升级,并且镜像文件大小超过Flash ROM的容量(意思就是ROM太大了 手机容量太小了)。在这种情况下, 请下载正确RUU 版本升级
