神舟H600笔记本花屏,,,
这个机器是独显的,8400 256M的,有两个显存,不装显卡驱动可以用,不花,一装驱动,,重启电脑,进系统就花,一会就蓝屏,自动重启,内存也换过,现像还是一样的,,
我用MATS8测显卡结果如下,,
MATS version 4.100.3. Testing G86 with 256 MB of memory.
Errors found. Use .Status() or .PrintErrors() for more info.
This message will only appear once.
LANE EB0 READ ERR EB0 WRT ERR UNKNOWN ERR
INTERNAL MEMERROR PROBLEM PART=0 LANE=0
INTERNAL MEMERROR PROBLEM PART=0 LANE=1
FBC[31: 0] 0 0 0
FBC[63:32] 0 0 0
External Bank 0 Failing bits:
A00 A01 A02 A03 A04 A05 A06 A07 A08 A09 A10 A11 A12 A13 A14 A15
A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31
A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A47
A48 A49 A50 A51 A52 A53 A54 A55 A56 A57 A58 A59 A60 A61 A62 A63
Read Error Count: 0
Write Error Count: 73496
Unknown Error Count: 0 |
