Ñ¸Î¬Íø
²é¿´: 2000|»Ø¸´: 11
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
[ÏÔ¿¨Î¬ÐÞ]
9550µÄ½á¹ûÇë¸ßÊÖ¸ø¿´Ò»ÏÂ
[¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2009-10-21 16:01:27 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ºÓ±±±£¶¨ À´×Ô ºÓ±±±£¶¨
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØÈ¨ÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
ÏÖÏóÊÇ»¨ÆÁ
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 32 33 34 35 36 37 38 39 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
Failure detected.
·¢±íÓÚ 2009-10-21 16:42:18 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓÄÏÐí²ý À´×Ô ºÓÄÏÐí²ý
R3MEMID°æ±¾1.07£¬£¨c£©°æÈ¨ËùÓÐATI¼¼Êõ¹«Ë¾£¬2003
ÈÕÖ¾ÎļþÉú³ÉÆôÓá£\ R3MEMID.LOG ...
²Î¿¼Êý¾ÝÎļþ£¨RDF£©µÄÔØÈëÖнûÓÃ...
²âÊÔ½á¹ûÕªÒª£º
Rv350£¨0x4153£©¼ì²â¡£
128MµÄÏÔ´æ¡£
²âÊÔÌ×¼þÔËÐÐ1 1´Î¡£
¼ì²é²âÊÔ״̬ÕóÁÐ...
[1]Ìîд£ºÊ§°Ü
´íÎóID 0VB001
1024 ¡Á 768 - 32É«£¨60ºÕ×È£©£º²âÊÔʧ°Ü
ʧ°Üλ£ºMDA0 0 1 2 3 4 5 6 7 ... MDB0 32 33 34 35 36 37 38 39 ...
[2]Êý¾ÝÏßÇл»£¨GUI£©µÄ£ºÊ§°Ü
´íÎóID 0VB023
[3] RWÒ³£¨GUI£©µÄ£ºÊ§°Ü
´íÎóID 0VB025
[4] RWͨµÀ£¨GUI£©µÄ£ºÊ§°Ü
´íÎóID 0VB028
[5]Êý¾ÝÑÚÂ룺ʧ°Ü
´íÎóID 0VB006
[6]ºê+ Micro8x2Í߯¬ÈçÏ£ºÊ§°Ü
´íÎóID 0VC006
[7]×Ö½Ú½»»»ºê¹Û+ micro8x2ÈçÏ£ºÊ§°Ü
´íÎóID 0VC018
[8] HOST_DATA / <f,b> / M2L£ºÊ§°Ü
´íÎóID 0TR014
640 ¡Á 480 - 8 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
640 ¡Á 480 - 15 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
640 ¡Á 480 - 16 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
640 ¡Á 480 - 32É«£¨75ºÕ×È£©£º²âÊÔʧ°Ü
800 ¡Á 600 - 8 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
800 ¡Á 600 - 15 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
800 ¡Á 600 - 16 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
800 ¡Á 600 - 32É«£¨75ºÕ×È£©£º²âÊÔʧ°Ü
1024 ¡Á 768 - 8 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
1024 ¡Á 768 - 15 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
1024 ¡Á 768 - 16 bppµÄ£¨75ºÕ×È£©£º²âÊÔʧ°Ü
1024 ¡Á 768 - 32É«£¨75ºÕ×È£©£º²âÊÔʧ°Ü
[9]ÐÐбÆÂ/Êð³¤/Ò³/¹ÌÌ壺ʧ°Ü
´íÎóID 0TR010
ʧ°Üλ£ºMDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
¹ÊÕϼì²â¡£
Äã¿´ÏÂRV350Õâ¸öÕý³£Âð£¿
3#
·¢±íÓÚ 2009-10-21 21:02:11 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓ±±±£¶¨ À´×Ô ºÓ±±±£¶¨
±¾Ìû×îºóÓÉ ºìµÆÁý ÓÚ 2009-10-21 21:04 ±à¼­
ÉÏ´Îû²âºÃ£¬ÓÖ²âÁËһϣ¬¾ÍÊǽá¹ûÄÚÈÝÌ«³¤°Ñºó±ßɾȥÁËÒ»²¿·Ö
Extended logging enabled ...
Failing bits in test [1] Fill
  errcount: 30281386
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23
  MDB0: 32 33 34 35 36 37 38 39 48 49 50 51 52 53 54 55
Failing bits in test [2] Data line toggle (GUI)
  errcount: 10199958
Failing bits in test [3] RW page (GUI)
  errcount: 15821675
Failing bits in test [4] RW channel (GUI)
  errcount: 13671657
Failing bits in test [5] Data mask
  errcount: 24410388
Failing bits in test [6] Macro + Micro8x2 tiling read
  errcount: 5122315
Failing bits in test [7] Byte swap macro+micro8x2 read
  errcount: 32777836
Failing bits in test [8] HOST_DATA/<f,b>/M2L
  errcount: 35217
  errcount: 68679
  errcount: 67790
  errcount: 130673
  errcount: 52617
  errcount: 107133
  errcount: 108226
  errcount: 199692
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 40 41 42 43 44 45 46 47
  MDB0: 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  errcount: 89576
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 41 42 43 44 45 46 47
  MDB0: 32 33 34 35 36 37 38 39 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  errcount: 175769
  errcount: 171557
  errcount: 327885
Failing bits in test [9] Line slopes/dir/P/solid
  errcount: 35452
  errcount: 70219
  errcount: 71980
  errcount: 141192
  errcount: 56034
  errcount: 107178
  errcount: 108922
  errcount: 223689
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 40 41 42 43 44 45 47
  MDB0: 32 33 34 35 36 37 38 39 40 41 42 43 44 46 47 48 49 50 51 52 53 54 55
  errcount: 92510
  errcount: 179346
  errcount: 180060
  errcount: 784770
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 25 27 28 30 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 57 59
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
128M video memory.
[1  ] Fill                                                : FAIL
    Error ID 0VB001
    Error ID 0VB023
    Error ID 0VB025
    Error ID 0VB028
    Error ID 0VB006
    Error ID 0VC006
    Error ID 0VC018
    Error ID 0TR014
4#
·¢±íÓÚ 2009-10-22 16:05:13 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÉϺ£Ëɽ­Çø À´×Ô ÉϺ£Ëɽ­Çø
ÄãʲôÒÇÆ÷²âÊԵģ¿
5#
·¢±íÓÚ 2009-10-22 19:46:31 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«½ÒÑô À´×Ô ¹ã¶«½ÒÑô
²âÊÔÒ»¶¨ÒªÔÚ´¿dosϲ⣬ÏÈ¿´¿´ÊDz»ÊÇÔÚ´¿dosϲâ
6#
·¢±íÓÚ 2009-10-22 19:47:55 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«½ÒÑô À´×Ô ¹ã¶«½ÒÑô
9550ÏԴ滵µÄ¶à£¬ÏÈÐÞºÃ×ʼµÄÄǸöλµÄÄǸö¿ÅÁ££¬È»ºóÔÙÐÞÆäËûµÄ
7#
·¢±íÓÚ 2009-10-22 22:34:04 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«·ðɽ À´×Ô ¹ã¶«·ðɽ
ÏÈ»»Í¼ÖÐȦסµÄÕâ¸öÏÔ´æ  Ôٲ⠠ÂÛ̳µÄR3 ¿ÉÒÔ²âµÄ ...
8#
·¢±íÓÚ 2009-10-23 10:04:26 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓ±±±£¶¨ À´×Ô ºÓ±±±£¶¨
ÖªµÀÁË£¬ÊÇSU1,SU6»µÁË£¬ÏÔ´æÊÇelixirµÄÐͺÅÊÇN2DS12H16BT-5TµÄ£¬ÕÒ²»µ½»»ÉÏÁËÁ½Æ¬HY5DU281622BT-4»¹ÊÇ»¨
¾ÍÊÇÕâÁ½¸ö
9#
·¢±íÓÚ 2009-10-23 23:22:58 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«Õ¿½­ À´×Ô ¹ã¶«Õ¿½­
dosÓõIJâÊÔÈí¼þ£¬ÄãÃÇÔõô±£´æ²âÊÔ½á¹ûµÄ£¿£¿
10#
·¢±íÓÚ 2009-10-24 09:03:37 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓ±±±£¶¨ À´×Ô ºÓ±±±£¶¨
atiflash -nocfg * -logext
Í·Ïñ±»ÆÁ±Î
11#
·¢±íÓÚ 2009-11-23 14:07:39 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ãÎ÷°ÙÉ« À´×Ô ¹ãÎ÷°ÙÉ«
´¿Êô·¹ý£¬ÈçÓдòÈÅ£¬°üº­¡£
12#
·¢±íÓÚ 2009-12-2 22:30:10 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«¹ãÖÝ À´×Ô ¹ã¶«¹ãÖÝ
ÕâôÀ÷º¦µÄ°¡¡¤¡¤¡¤ÎÒÔõô¿´¾ÍÊÇ¿´²»Ã÷°×µÄ¡£ÓÐʲô˵Ã÷˵Â𣿡¤¡¤¡¤¡¤¼ÓQQ£º262827592¸æËßÎÒºÃÂð£¿Ð»Ð»
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ AIάÐÞ
ÖúÊÖ
оƬËÑË÷
¿ìËٻظ´
