A卡ASUS9550测试结果,其它都解决,只差一个问题
,结果如下
RV350/M10 (0x4150) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : PASS
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
1280 x 1024 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 0 1
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
[4 ] RW page (GUI) : PASS
[5 ] RW channel (GUI) : PASS
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
