- 积分
- 13
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2007-8-26
- 精华
铭瑄X800XL白金版128M/256位
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
R430 A11 (0x554f) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : PASS
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDD0 60 61
[3 ] RW column (GUI) : PASS
[4 ] RW page (GUI) : PASS
[5 ] RW channel (GUI) : PASS
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
[7 ] Macro + Micro8x2 tiling read : PASS
[8 ] Macro + Micro4x4 tiling write : PASS
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : PASS
[12 ] Macro+Micro4x4 alignment read : PASS
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST PASSED
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST PASSED
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST PASSED
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
error : R051A.15 not found
error : R052A.15 not found
error : R053A.15 not found
error : R061A.15 not found
error : R062A.15 not found
error : R063A.15 not found
error : R071A.15 not found
error : R072A.15 not found
error : R073A.15 not found
Failure detected.
正面是 U1 U2
U4
U10
反面是 SU2 SU1
SU3
SU7 |
