查看: 144|回复: 0
[笔记本电脑]
联想V460不通电即不触发小修
发表于 2025-1-2 13:13:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 浙江 来自 浙江
品牌:LENOVO
型号:V460 I3 380独显
板号:LA46 MB DIS(纬创资通)
故障现象:插上适配器无待机电流,按下开关不通电!
故障分析:针对I3 380的设计来判断,待机时无电流也是正常的,但触发无任何反应,即没亮灯指示!说明前面没有起来:
解决过程:首先查保护隔离电路:如图1
从适配器接口4 5 6脚出来一路经过滤波电容、防静电二极管,到达带有体二极客的场效应管U50S极,然后从D极输出20V电压,实测D极为19.36V;由此说明公共点AD+正常!
然后AD+再过U47R407产生DCBATOUT ,最后过U49产生BT+,实测DCBATOUT19.36VBT+0.45V
DCBATOUT做为待机芯片TPS51123的主供电,由此芯片产生3D3V_AUX_S55V_AUX_S55V_PWR3D3V_PWR四个电压,前两个是待机便有,而后两个是触发后才有;实测TPS51123的主供电VIN19.36VEN05.06VVREF0.98VVREG33.3VVREG55VENC0V5V_PWR3D3V_PWR没出来!
在这里要说明下,ENC5V_PWR3D3V_PWR此两个电压的开启控制信号脚,应该为高电平!而实测确为低电平,查其来源:如图4:
实测S5_ENABLE输出电压为0V,那它为什么没有电压呢?查EC的供电、时钟、复位;供电正常、复位也正常,唯独测不到时钟,如图5
weibo.com/ttarticle/p/show?id=2309405118332578955448
weibo.com/ttarticle/p/show?id=2309405118333262626882
weibo.com/ttarticle/p/show?id=2309405118334269259873
weibo.com/ttarticle/p/show?id=2309405118335049400640
weibo.com/ttarticle/p/show?id=2309405118335816958196
weibo.com/ttarticle/p/show?id=2309405118336320274466
weibo.com/ttarticle/p/show?id=2309405118336802619568
weibo.com/ttarticle/p/show?id=2309405118337494679567
weibo.com/ttarticle/p/show?id=2309405118338048327688
weibo.com/ttarticle/p/show?id=2309405118338593587469
weibo.com/ttarticle/p/show?id=2309405118339008823540
weibo.com/ttarticle/p/show?id=2309405118339604152353
weibo.com/ttarticle/p/show?id=2309405118340451663961
weibo.com/ttarticle/p/show?id=2309405118341122752774
weibo.com/ttarticle/p/show?id=2309405118342003556432
weibo.com/ttarticle/p/show?id=2309405118330536329479
weibo.com/ttarticle/p/show?id=2309405118330603438279
weibo.com/ttarticle/p/show?id=2309405118330838056985
weibo.com/ttarticle/p/show?id=2309405118330951565410
weibo.com/ttarticle/p/show?id=2309405118331228389469
weibo.com/ttarticle/p/show?id=2309405118331383578910
weibo.com/ttarticle/p/show?id=2309405118331513602378
weibo.com/ttarticle/p/show?id=2309405118346558570608
weibo.com/ttarticle/p/show?id=2309405118346663166002
weibo.com/ttarticle/p/show?id=2309405118346730274834
weibo.com/ttarticle/p/show?id=2309405118346801578030
weibo.com/ttarticle/p/show?id=2309405118346868686875
