- 积分
- 1
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2024-10-29
- 精华
小坤0 发表于 2024-10-30 15:52
你试一下看下行不行
NVIDIA Firmware Update Utility (Version 5.780.0)
Copyright (C) 1993-2022, NVIDIA Corporation. Veii Extreme Edition
Adapter not accessible or supported EEPROM not found, skipping
ERROR: A system restart might be required before running the utility.
c:\123>nvflash -6 N3070_B.ROM
Checking for matches between display adapter(s) and image(s)...
NOTE: Exception caught.
Results:
Index | Match | Flash | Name
<00> GeForce RTX 3070 (10DE,2484,1462,3909) S:00, B:01
Nothing changed!
ERROR: Detecting GPU failed.提示这样 |
