Ñ¸Î¬Íø
²é¿´: 1797|»Ø¸´: 4
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
IBM±Ê¼Ç±¾´íÎó´úÂë
[¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2009-8-25 16:27:31 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ºÓ±±±£¶¨ À´×Ô ºÓ±±±£¶¨
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØÈ¨ÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
¿ª»ú´íÎó´úÂë¼ì²é·¶Î§¼°½â¾ö·½·¨
            10X
            101:£¨ÖжϹÊÕÏ£©
            102:£¨¼ÆÊ±Æ÷¹ÊÕÏ£©
            103:£¨¼ÆÊ±Æ÷ÖжϹÊÕÏ£©
            104:£¨±£»¤Ä£Ê½¹ÊÕÏ£©
            105: Last 8042 command not accepted£»
            107:£¨NMI ²âÊÔʧ°Ü£©
            108: Timer bus test failure.
            109:£¨Ö÷°åÎÊÌ⣩
            110 :£¨ÄÚ´æÆæÅ¼Ð£Ñé³ö´í£©
            111: (I/O parity.)
            1101:£¨A ´®ÐпڲâÊÔʧ°Ü£©
            1201:£¨B ´®Ðпڡ¢ºìÍâÏ߿ڲâÊÔʧ°Ü£©
            158 :£¨³¬¼¶Óû§ÃÜÂëÒÑÉ裬µ«Ó²ÅÌÃÜÂëûÓÐÉèÖã©
            159 :£¨Ó²ÅÌÃÜÂëÓ볬¼¶Óû§ÃÜÂë²»Ò»Ñù£©
            161:£¨CMOS µç³Ø²»ÐУ©
            163:£¨ÏµÍ³Ê±¼äûÓÐÉèºÃ»ò»ìÂÒ£©
            173:£¨CMOS É豸ÅäÖÃÐÅÏ¢¶ªÊ§£©
            175¡¢178: EEPROM CRC #1 error.
            177: Supervisor password check sum error.
            178: EEPROM is not functional. 1. System board. £¨¼ì²éÖ÷°å£©
            1701:£¨Ó²ÅÌ¿ØÖÆÆ÷¹ÊÕÏ£©
            1780, 1790:£¨Ö÷Ó²ÅÌÓÐÎÊÌ⣩
            1781, 1791:£¨´ÓÓ²ÅÌÓÐÎÊÌ⣩
            183 :£¨³¬¼¶Óû§¿ª»úÃÜÂë²»¶Ô£©
            184:£¨Power-on ÃÜÂëÓÐÎ󣩠  password in Easy-Setup.£¨ÖØÉèPower-on ÃÜÂ룩
            185:£¨ÏµÍ³Æô¶¯Ë³ÐòÎÞЧ£¬»³ÒÉÊǸüÐÂÆô¶¯Ë³ÐòʱµçÔ´¹Øµô£©
            186 :£¨¼ì²éÖ÷°å£©
            190:£¨¿ª»úʱ£¬»úÄڱʼDZ¾µç³ØÒÑ¿ìºÄ¾¡ÁË£©
            191XX: £¨PM ³õʼ»¯´íÎ󣬼ì²éÖ÷°å£©
            192:£¨CPU É¢ÈÈ·çÉȹÊÕÏ£¬¼ì²éCMOS ±¸·Ýµç³ØµÄµçѹ£¬µçѹ²»ÐÐʱ¸ü»»µç³Ø»òÒª¸ü»»CPU·çÉÈ×îºó¾ÍÊÇÖ÷°åÎÊÌ⣩
            195:£¨ÏµÍ³ÅäÖÃÐÅÏ¢Óëʵ¼ÊÅäÖò»Í¬£¬¼ì²éÅäÖÃÊÇ·ñ¸Ä¶¯£¬ÄÚ´æÓÐÎÞÔö¼ÓµÈ£©
            196:£¨ ´ÓÓ²Å̵ÄÐÝÃßÇøÓòÖжÁдʱ£¬·¢Éú´íÎ󣬼ì²éÓ²ÅÌ¡¢Äڴ棩
            201: Memory data error.
            202: Memory line error 00-15.203: Memory line error 16-23.
            205: Memory test failure on on-boardmemory.
            221: ROM to RAM remap error. 1. Go to Memory Checkout.2. DIMM card.
              3. System board. 225
              (Unsupported memory module.) 1. Check if the supported DIMM is
            installed.
              2. DIMM card.3. System board.
            301, 303, 304, 305, 3XX£¨±Ê¼Ç±¾¼üÅ̹ÊÕÏ£¬301Õâ¸ö¹ÊÕϾ­³£³öÏÖ£¬ÍùÍùÊDZʼDZ¾¸Õ¿ª»ú
                ʱ£¬²»Ð¡Ðݴס¼üÅÌËùÔì³ÉµÄ£¬Ò»°ãÖ»ÒªÖØÆôµçÄÔ¼´¿É£©
            601, 6XX £¨ÈíÇý»òÈíÇý¿ØÖÆÆ÷¹ÊÕÏ£¬ÈíÇýÓÐûÓÐ×°ÅäºÃ£¿ÔÙ¼ì²éÖ÷°å£©
            2402 1. TV Out Card 24XX£¨Ö÷°åÏÔʾ²¿·ÖÓÐÎÊÌ⣬¼ì²éÖ÷°åÏà¹Ø²¿·Ö£©
            8081: PCMCIA presence test failure.(PCMCIA revision number also
            checked.)
            8082: £¨µ±Ö¸µã¸Ë½ûÓÃʱ£¬Íâ½ÓµÄÖ¸µãÉ豸ÓйÊÕÏ£©£»
            8601: System bus error-8042 mouse interface.
            8602:£¨Íâ½ÓÊó±ê¹ÊÕÏ£©£»
            8603:£¨×ÜÏß»òÊó±ê¹ÊÕÏ£¬¼ì²éÍâ½ÓÊó±ê¡¢¼ì²éÍâ½Ó¼üÅÌ¡¢¼ì²éÖ÷°å£©£»
            861X£¨µ±Ö¸µã¸ËÆôÓÃʱ£¬Íâ½ÓµÄÖ¸µãÉ豸ÓйÊÕÏ£©£»
            8611: System bus error-I/F between 8042 and IPDC.
            8612: TrackPoint error.
            8613:£¨°Ñ¼üÅÌÁ¬½ÓÖ÷°åµÄÏߣ¬Öزå°Îһϡ¢¼ì²é¼üÅÌ¡¢¼ì²éÍâ½ÓÊó±ê¡¢Ö÷°åÉÏÁ¬½Ó¼üÅ̵Ä×Ó¿¨×îºó¼ì²éÖ÷°å£©
            I9990301:£¨Ó²ÅÌÓйÊÕÏ£©£»
            I9990302:£¨ÎÞЧµÄÓ²ÅÌÒýµ¼¼Ç¼£¬ÎÞÒýµ¼ÏµÍ³Îļþ£©£»
            I9990305:£¨ÎÞ¿ÉÓÃµÄÆô¶¯Òýµ¼É豸¡£¼ì²éÓ²ÅÌÉÏÓзñ°²×°²Ù×÷ϵͳ£¬ÔÚBIOSÖØÐÂÉèÖÿÉ
            Æô¶¯µÄÉ豸¡¢¼ì²éÆô¶¯Ë³ÐòÊÇ·ñ¸úÉ豸ÕýÈ·¶ÔÓ¦¡¢¼ì²éµçÄԵIJÙ×÷ϵͳÊÇ·ñ°²×°ÕýÈ·£©£»
            I9990303 £¨ÄÚ´æ´íÎ󣬼ì²éÀ©Õ¹ÄÚ´æ¡¢¼ì²éÖ÷°åÄÚ´æ¡££©
·¢±íÓÚ 2009-8-30 21:51:42 | Ö»¿´¸Ã×÷Õß À´×Ô£º ½­ËÕËÕÖÝ À´×Ô ½­ËÕËÕÖÝ
Õâ¸öºÃѽ,ÎÒÕýÔÚÕÒÄØ
3#
·¢±íÓÚ 2009-9-1 08:18:44 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓ±± À´×Ô ºÓ±±
ºÃ¶«Î÷Èôó¼ÒÒ»ÆðÏíÓá£
Í·Ïñ±»ÆÁ±Î
4#
·¢±íÓÚ 2009-9-1 11:05:46 | Ö»¿´¸Ã×÷Õß À´×Ô£º ɽ¶«Çൺ À´×Ô É½¶«Çൺ
ºÃ¶«Î÷Ò»ÆðÏíÓÃ
5#
·¢±íÓÚ 2009-9-1 13:19:44 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«»ÝÖÝ À´×Ô ¹ã¶«»ÝÖÝ
Õâ¸öÓÐÓÃŶ£¡£¡ÎÒ¸ÕÓö¹ý£¬¸úÕâ¸öÄܶÔÉϺÅ
¹ûÕæÓ²ÅÌ88ÁË
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ AIάÐÞ
ÖúÊÖ
оƬËÑË÷
¿ìËٻظ´
