ѸάÍø
²é¿´: 819|»Ø¸´: 9
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
[ÇóÖúÖÐ]
ȺÁªPS3111-S11-13¿ª¿¨×ÜÊdzö´íPretest Flash Timeout£¬Çó´óÀÐÖ¸µã
  [¸´ÖÆÁ´½Ó]
Ìøתµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2024-10-16 14:56:12 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º Öйú À´×Ô Öйú
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØȨÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
Ò»¸ö240GµÄ¹Ì̬£¬ËÀ»î¿ª²»³ö£¬Ò²ÕÒ²»³öÎÊÌ⣨³¢ÊÔ¹ý»»°æ±¾ 2.2.70£¬2.2.85£¬Ò²ÊÔ¹ýÓûªÀ½Î¢INIC6081µÄ¿ª¿¨Èí¼þ£¬Ò²ÊÔ¹ýÓõãÐòAS2258µÄ¿ª¿¨Èí¼þ£¬Õâ¸öÖ±½ÓÎÞ·¨Ê¶±ð£©
ÅäÖÃÐÅÏ¢ÈçÏ£¬Èç¹ûSATAËÙ¶ÈÑ¡µ½gen2¡¢gen3¶¼±¨ËٶȲ»¶Ô£¬interfaceÑ¡onfi3.0¡¢onfi2.0½á¹û¶¼Ò»Ñù£¬flashʱÖÓÑ¡200mhz¡¢100mhzÒ²Ò»Ñù¡£Åܵ½°Ù·ÖÖ®ÎåÊ®×óÓҾͳöÏÖ±¨´í
¸½ÉÏ¿ª¿¨´íÎóÈÕÖ¾
Day: (16 \ 10 \ 2024) Time: (14:22:34)  TesterNumber:1
[ConfigID]
ID=2C C4 18 32 A2 00-B27A
[SN Set]
SN_Set=0
SN_Type=3
SN_Len=12
SN_Start=000000000001
SN_End=999999999999
SN_Mask=############
[Other]
SATA_SSC_Enable=0
[StationName]
01=EraseAll
02=RDT
03=RDTResult
04=MP
05=ReMP
06=ICT
07=UpdateFW
08=ScanBad
[APSetting]
APVersion=v2.2.85
[General Info]
SlotNumber=8
TestStationSel=3
TestStation=F1
WorkingNo=SATA 240G
ModelName=SATA 240G
SerialNum=AA32432325
MaxCurrent=400
[Flash Info]
Flh_Type=TLC_16K
Flh_MakeCode=Micron
Flh_ID=2c c4 18 32 a2 00
Flh_Capacity=294912
Flh_CapacitySel=23
Flh_Number=4
Flh_NumberSel=4
Flash Clock=200
Flash Interface=5
[Options]
PadODTEnable=1
PadODT=1
DDRSize=32
SetSSDSize=240
Enable_Set_Custom_SMART_Temperature=1
Set_Custom_SMART_Temperature=42
Smart_Table=0
EnableSmartC3=1
SLCPoolSizeSel=1
SLCPoolSize=0
Disable_DIPM_Support=1
Put_Thermal_Sensor=0
Skip_Check_RDDebugPage=1
PretestType=0
PMASetting=42035
[Device Info]
SATASpeed=1
ControllerType=SSD-3111SB
ICFWVersion=SBFQJ1.3
3111SBISP_CodeVersion=QJ1.3
3111SBISP_MPBINCode=.\Bin\SBFQJ1.3.BIN
3111SBISP_RDTBINCode=.\Bin\SBSCJ1.2.BIN
SSD Size=2.5"
[InfoBlock]
Byte_136=00
Byte_137=00
Byte_138=40
Byte_139=00
Byte_203=01
Byte_290=E8
Byte_291=03
[EraseAll]
Do_Erase_First=1
Type=01
   [Log]
   Set_Custom_SMART_Temperature : 42 (dec)
[ Success ] Modify InfoBlock OK.
   [ Info ] MP AP: V2.06_x02(China), MAC Address: , ISP FW: SBFQJ1.3.BIN, Station:F1T
[ Success ] Check Device State OK.
[ Success ] Check IO State OK- Total take 0.056 sec.
[ Success ] Check ICVer. OK.
[ Success ] AES VUC Process OK.
[ Success ] ISP Program PRAM OK.
[ Success ] eFuse Info
       UART : Enable
       JTAG : Enable
       Trim good die : 01
   Get Controller ID : 1D_09_12_07_20_20_04
       Trim good die : 01
       Y Coordination : 1d
       X Coordination : 09
       Wafer ID : 12
       Lot ID 4 : 07
       Lot ID 3 : 20
       Lot ID 2 : 20
       Lot ID 1 : 04
       CTL Version : 03
[ Success ] Check eFuse OK.
[ Success ] Verify param.ini with Device Info OK.
   Scan_Flash_SDLL:
   DiePerFlash=1, SectorPerPage=32
   Ch=0~1, Bank=0~1
   FlashMode : 5 FlashClock : 7 FlashODT : 0 Flash(NAND)Drive : 0 PadODTEnable : 1 PadODT : 1
   PADDriveEnable : 0 ALEPads : 0 CLEPads : 0 WEPads : 0 REPads : 0 FRDYPads : 0
   WPPads : 0 DQSPads : 0 DataPads : 0 CEPads : 0 ScanRound : 0 Scan Interval : 50
   Scan_LDPC_Error_Bit : 0x03FF
   BitMask : 0 SlewRateEnable : 0 SlewRate : 0  EnableOverClocking : 0
   Set Scan Window Criteria : 50
   Duty Range : 0~0
   Duty : 0 Bank : 0  Die : 0
   CH 0 Read-Min : 0 Read-Max : 143 Write-Min : 0 Write-Max : 147
   CH 1 Read-Min : 1 Read-Max : 143 Write-Min : 0 Write-Max : 137
   Duty : 0 Bank : 1  Die : 0
   CH 1 Read-Min : 0 Read-Max : 144 Write-Min : 0 Write-Max : 137
   CH0 Read :
     Duty_0: CH_0: Read_Min : 0 Read_Max : 143 (Range : 144)
   CH1 Read :
     Duty_0: CH_1: Read_Min : 1 Read_Max : 143 (Range : 143)
   CH0 Write :
     Duty_0: CH_0: Write_Min : 0 Write_Max : 147 (Range : 148)
   CH1 Write :
     Duty_0: CH_1: Write_Min : 0 Write_Max : 137 (Range : 138)
   Find Read Max Duty :Ch_0 Duty_0 Ch_1 Duty_0
   [Windows]:
   Duty_0 CH_0: Read Window=0x47, Write Window=0x49
   Duty_0 CH_0: HW_Rd=0x46, HW_Wr=0x46
   ScanValueRe[0] = 0x1  ScanValueWr[0] = 0x3
        Duty_0: Bank_0: Die_0: Read Win=0x47(Min=0x0, Max=0x8f)
                         Write_Win=0x49(Min=0x0, Max=0x93)
        Duty_0: Bank_1: Die_0: Read Win=0x47(Min=0x0, Max=0x8f)
   Duty_0 CH_1: Read Window=0x48, Write Window=0x44
   Duty_0 CH_1: HW_Rd=0x46, HW_Wr=0x46
   ScanValueRe[1] = 0x2  ScanValueWr[1] = 0x8002
        Duty_0: Bank_0: Die_0: Read Win=0x48(Min=0x1, Max=0x8f)
                         Write_Win=0x44(Min=0x0, Max=0x89)
        Duty_0: Bank_1: Die_0: Read Win=0x48(Min=0x0, Max=0x90)
[ Success ] Scan Window Process OK- Total take 4.149 sec.
[ Fail ]  Error Message : Not Running on Flash Code now- SBRM02.0
             Error Code : I_B67
             AP Command : [a1]-[8]-[e]-[0]-[1]-[0]-[0]-[0]-[e0]-[ec]-[0]-[0]
             OS LastError : [ 0 ]
             ATA Reg:[0][0][e][c][0][1]
[ Error End ] Time: (14:22:46)
   Do SDR Write/Read Test, SDR Size= 32 MB
[ Fail ]  Error Message :      DMA_Write_DDR on 0x0 Failed !!
             Error Code : I_S30
             AP Command : [a1]-[16]-[6]-[0]-[80]-[0]-[0]-[0]-[e0]-[ca]-[0]-[0]
             OS LastError : [ 121 ]
[ Error End ] Time: (14:36: 8)
Í·Ïñ±»ÆÁ±Î
·¢±íÓÚ 2024-10-16 22:03:20 | Ö»¿´¸Ã×÷Õß À´×Ô£º Öйú À´×Ô Öйú
·Ç³£¸Ðл¥Ö÷,ѧϰÁË.
3#
·¢±íÓÚ 2024-10-24 00:11:03 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºþÄϳ¤É³ À´×Ô ºþÄϳ¤É³
PS3111ÕÒ²»µ½BICS4µÄ¹Ì¼þ£¬Í·´ó
4#
·¢±íÓÚ 2024-10-30 09:13:14 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ãÎ÷ÄÏÄþ À´×Ô ¹ãÎ÷ÄÏÄþ
ÓÃinitio6081_2.09.36_2.02.23_IMÕâ¸öÈí¼þ£¬³öÏÖI_B67 ,Not Running on Flash Code now¡­
ÕâÑùµÄÌáʾºóÖØвå°Î´ÅÅÌ£¬È»ºó¸ñʽ»¯¾Í¿ÉÒÔÀ²¡£
5#
·¢±íÓÚ 2024-11-27 18:12:01 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÖØÇì À´×Ô ÖØÇì
ÉÁ´æ¹Ì¼þ²»¶Ô
6#
·¢±íÓÚ 2024-12-27 16:49:04 | Ö»¿´¸Ã×÷Õß À´×Ô£º Öйú À´×Ô Öйú
ȺÁªÈºÁªÈºÁªÈºÁª
7#
·¢±íÓÚ 2024-12-27 21:35:28 | Ö»¿´¸Ã×÷Õß À´×Ô£º ±±¾© À´×Ô ±±¾©
ÓÃinitio6081¹¤¾ß
8#
·¢±íÓÚ 2025-1-6 13:19:35 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºþ±± À´×Ô ºþ±±
ÈÝÁ¿ÒªÑ¡×Ô¶¯
9#
·¢±íÓÚ 2025-1-8 13:15:51 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓ±±ÕÅ¼Ò¿Ú À´×Ô ºÓ±±ÕżҿÚ
л¥Ö÷·ÖÏí
10#
·¢±íÓÚ 2025-1-14 11:11:54 | Ö»¿´¸Ã×÷Õß À´×Ô£º °²»Õ¸·Ñô À´×Ô °²»Õ¸·Ñô
³öVB³öVB³öVBv³Ô°É
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ AIάÐÞ
ÖúÊÖ
оƬËÑË÷
¿ìËٻظ´
