查看: 557|回复: 1
[显卡维修]
MATS测试4070TI显卡用那个模式?
发表于 2024-5-29 18:41:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广西桂林 来自 广西桂林
本人萌新,MATS测试4070TI显卡用那个模式?UEFI和LEGACY模式测试的结果不一样啊,UEFI模式无法通过,但是用LEGACY模式就能通过。到底该看那个结果?
这个是UEFI模式的结果:     GPU 0 [01:00.0]  dev.sub 0.0                              ----------------------------------------
DevInst        : 0
PCI Location   : 0x00, 0x01, 0x00, 0x00
GPU DID        : 0x2782
PDI            : 0xf2a81c945ce7d7fe
Raw ECID       : 0x011fc20000000004c0c40de1
Raw ECID (GHS) : 0x17804c0c40c00000008fe0200
ECID           : TSMC-U1C343-08_x-4_y8
Device Id      : AD104
Revision       : a1
Sub Revision   : 15
NV Base        : 0xa2000000
FB Base        : 0x90000000
IRQ            : 11
ERROR: bp @ <fileid:0x0001f0>:2702
ERROR: ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] ------------------------- BEGIN ASSERT INFO DUMP -------------------------
[  ] --->reghalconst.jse
[  ] Preprocessing reghalconst.jse.
[  ] Successfully opened /home/455.127/reghalconst.jse
[  ] Compiling reghalconst.jse.
[  ] Compiled reghalconst.jse, pScript = 0x0x10c27de0.
[  ] Executing reghalconst.jse.
[  ] reghalinternal.jse does not exist.
[  ] <---reghalconst.jse
[  ] pvstest.jse does not exist.
[  ] <gputest.jse
[  ] Done parsing args
[  ] >base.spc
[  ] Preprocessing base.spc.
[  ] Successfully opened /home/455.127/base.spc
[  ] Compiling base.spc.
[  ] Compiled base.spc, pScript = 0x0x10831250.
[  ] Executing base.spc.
[  ] <base.spc
[  ] Command Line : gputest.js -no_gold -test 275
[  ] CPU
[  ] Arch           : x86_64
[  ] Name           : Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
[  ] Cores          : 6
[  ] Version
[  ] MODS           : 520.112
[  ] System
[  ] OperatingSystem: Linux (x86_64)
[  ] Kernel         : 5.9.1-gentoo-x86_64
[  ] KernelDriver   : 4.00
[  ] SBIOS Version  : 1.C0
[  ] SBIOS Date     : 10/20/2022
[  ] HostName       : tinylinux
[  ] Available RAM  : 31717/32186 MB (Free/Size)
[  ] NUMA Node 0 RAM: 31717/32186 MB (Free/Size)
[  ] Hypervisor     : No
[  ] Sysmem page size is 4 KB
[  ] Smbios version [0x208] is not supported
[  ] Failed to Read system UUID, this requires root permissions to run
[  ] Sys-uuid       :
[  ] Failed to Read Hdisk Serial num, this requires root permissions to run
[  ] HDD-Serno      :
[  ] Turning off register exclusion regions.
[  ] >boards.jse
[  ] Preprocessing boards.jse.
[  ] Successfully opened /home/455.127/boards.jse
[  ] Compiling boards.jse.
[  ] Compiled boards.jse, pScript = 0x0x10761660.
[  ] Executing boards.jse.
[  ] <boards.jse
[  ] CreateNvLinkLibInterface : Creating NvLink library interface NvLinkLibIfUser
[  ] CreateAllDevInterfaces : Created NvLink device interface NvSwitchDevIf
[  ] CreateAllDevInterfaces : Created NvLink device interface NvGpuDevIf
[  ] Warning: Can't find Pci device with class code 0x68000, index 0
[  ] Find NvSwitch ports
[  ] -------Finish NvSwitch detection-----
[  ] Physical Graphics controller at 0000:01:00.0
[  ] reg virtual base = 0x7f9a5dffe000
[  ] IOVA enabled
[  ] Detected 47 sysmem address bits for chip id 0xd04 at 0000:01:00.0, IOVA enabled
[  ] BAR0 base = 0x0_A2000000,
     size = 0x01000000
[  ] BAR1 base = 0x0_90000000,
     size = 0x10000000
[  ] BAR2 base = 0x0_A0000000,
     size = 0x02000000
[  ] Vendor ID = 0x10DE
[  ] Device ID = 0x2782
[  ] Chip ID   = 0x00000194
[  ] [0000:01:00.0] cap id 0x5 found at offs 0x68
[  ] [0000:01:00.0] cap id 0x11 not found
[  ] [0000:01:00.0] cap id 0x10 found at offs 0x78
[  ] [0000:01:00.0] extended cap id 0x1e found at offs 0x0258
[  ] Register manual file ad104_ref.txt not found
[  ] Warning: Can't find Pci device with class code 0x30000, index 1
[  ] Warning: Can't find Pci device with class code 0x30200, index 0
[  ] Found Test Devices :
[  ]    GPU 0 [01:00.0]
[  ] Find bridge ports
[  ] [0000:00:01.0] bridge sec=01 sub=01 vendor=8086 devid=1901 uniq_link_poll=true
[  ] [0000:00:1b.0] bridge sec=02 sub=02 vendor=8086 devid=a340 uniq_link_poll=false
[  ] Warning: Can't find Pci device with class code 0x60400, index 2
[  ] Warning: Can't find Pci device with class code 0x60401, index 3
[  ] Find siblings at 0000:00:xx.x
[  ]   Sibling found: domain=0000 sec=01 sub=01
[  ]   Sibling found: domain=0000 sec=02 sub=02
[  ]   Found chipset controller's port at 0000:00:01.0
[  ] mods [1]: set dma mask 47 for dev 0000:01:00.0
[  ] [0000:00:01.0] cap id 0x10 found at offs 0xa0
[  ] [0000:00:01.0] extended cap id 0x1 not found
[  ] [0000:00:1b.0] cap id 0x10 found at offs 0x40
[  ] [0000:00:1b.0] extended cap id 0x1d found at offs 0x0250
[  ] [0000:00:1b.0] extended cap id 0x1 found at offs 0x0100
[  ] Root check: 0000:00:01.0 IsRoot=true
[  ] Connecting ports for Chipset 0000:00:01.0:
[  ]   DP0 0000:00:01.0 connects to test device GPU 0 [01:00.0]
[  ] ------Finish bridge detection-----
[  ] Detected potential primary VGA device: GPU 0 [01:00.0]
[  ] Suspended Linux console
[  ] InitializeAllDevices : RM not initialized, skipping GPU nvlink device initialization
[  ]                  GPU 0 [01:00.0]  dev.sub 0.0
[  ] Console: switching consoles 1-1 to colour dummy device 80x25
[  ] DevInst        : 0
[  ] PCI Location   : 0x00, 0x01, 0x00, 0x00
[  ] GPU DID        : 0x2782
[  ] PDI            : 0xf2a81c945ce7d7fe
[  ] Raw ECID       : 0x011fc20000000004c0c40de1
[  ] Raw ECID (GHS) : 0x17804c0c40c00000008fe0200
[  ] ECID           : TSMC-U1C343-08_x-4_y8
[  ] Device Id      : AD104
[  ] Revision       : a1
[  ] Sub Revision   : 15
[  ] NV Base        : 0xa2000000
[  ] FB Base        : 0x90000000
[  ] IRQ            : 11
[  ] MSI-X not supported on GPU 0 [01:00.0], skipping
[  ] Detected supported interrupt types: legacy MSI
[  ] mods [1]: enabled dev 0000:01:00.0
[  ] Disabling interrupt tree 0
[  ] IRQ statistics:
[  ]   num IRQs:      10
[  ]   avg IRQ delay: 0us
[  ]   min IRQ delay: 0us
[  ]   max IRQ delay: 0us
[  ] Legacy interrupts verified OK
[  ] IRQ statistics:
[  ]   num IRQs:      10
[  ] MSI verified OK
[  ] Skipping MSI-X verification
[  ] Hooking MSI
[  ] Warning: Can't find Pci device with class code 0x40300, index 2
[  ] Bypassing unsupported vendor: 0x8086Device already uninitialized
[  ] AD104 Azalia: DeviceId: 0x22bc.
[  ] Found 1 controllers (DevId 127)
[  ] SetAspm on GPU: 0x11030042
[  ] Reset polled 2 times in 0 us on AzaRegWaitPoll and r
发表于 2024-5-30 11:05:27 | 只看该作者 来自: 广东深圳 来自 广东深圳
您好,欢迎加入迅维网,有你更精彩
请遵守论坛管理规则哦!
迅维网管理总则--新手必读http://www.chinafix.com/thread-5924-1-1.html
帮助中心:http://www.chinafix.com/misc.php?mod=faq
用户须知:https://www.chinafix.com/misc.ph ... ction=faq&id=62
操作中如有疑问可咨询迅维客服微信:XW4006631699帮您处理
