查看: 319|回复: 1
PS3111+YMTC TLC识别SATAFIRM S11解决工具
发表于 2024-4-16 15:26:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 江苏苏州 来自 江苏苏州
硬盘信息如下:Model: SATAFIRM   S11
Fw   : SBFKP1W3
P/N  : 9283671
S11fw: SBFKP1A3, 2020Oct22
S11rv: KP1A3-82
Original Model: KINGSTON SA400S37240G
Bank00: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank01: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank02: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank03: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank08: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank09: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank10: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank11: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Controller    : PS3111
Flash CE      : 8
Flash Channel : 2
Dram Size,MB  : 32
谁有对应开卡工具发一下链接 看清楚是SBFKP1W固件没有找到
发表于 2024-4-17 10:41:55 | 只看该作者 来自: 广东深圳 来自 广东深圳
您好,欢迎加入迅维网,有你更精彩
请遵守论坛管理规则哦!
迅维网管理总则--新手必读http://www.chinafix.com/thread-5924-1-1.html
我这边还有一些我们迅维老师整理的维修视频资料,可以发给你免费学习  加我微信领取 xunwei16777
