查看: 1057|回复: 17
大家看一下显卡感叹号是哪颗显存的问题
发表于 2024-3-24 15:15:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 泰国 来自 泰国
mats version 520.175.  Testing TU117 with 20 MB of memory starting with 0 MB.
Memory Errors on
Read    Error Count: 0
Write   Error Count: 1066402
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0            0            0            0
FBIOA1            0            0            0
FBIOB0            0      1066402            0
FBIOB1            0            0            0
Failing Bits:
B024 B025 B026 B027 B028 B029 B030 B031
Memory Errors on
Read    Error Count: 0
FBIOA0            0            0            0
FBIOA1            0            0            0
FBIOB0            0      1066402            0
FBIOB1            0            0            0
Failing Bits:
=== MEMORY ERRORS BY BIT ===
P : Partition (FBIO)
                                            READ 0  READ 1 READ ?
P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1  EXP. 0 EXP. ?
B 024           0      1320851            0    251 1320600      0
B 025           0      2122577            0    204 2122373      0
B 026           0      1320851            0    251 1320600      0
B 027           0      2122577            0    204 2122373      0
B 028           0      1320851            0    251 1320600      0
B 029           0      2122577            0    204 2122373      0
B 030           0      1320851            0    251 1320600      0
B 031           0      2122577            0    204 2122373      0
=== MEMORY ERRORS BY ADDRESS ===
ADDRESS : Failing memory address, or buffer offset if starting with 'X+'
T : Type of memory error: W = write, R = read
S : Subpartition
B : Bank
E : Beat
U : PseudoChannel
   ADDRESS EXPECTED   ACTUAL  REREAD1  REREAD2 FAILBITS TPSBEU SLICE  ROW COL                                  BIT(s)
000135fcbc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fcb8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fcb4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fcb0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fcac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fca8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fca4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135fca0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
000135bc9c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc98 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc94 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc90 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc8c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc88 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc84 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000135bc80 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001354cbc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354cb8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354cb4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354cb0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354cac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354ca8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354ca4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001354ca0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     1 004d 016 B024,B025,B026,B027,B028,B029,B030,B031
0001350c9c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c98 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c94 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c90 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c8c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c88 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c84 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
0001350c80 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     0 004d 002 B024,B025,B026,B027,B028,B029,B030,B031
000015c5fc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06e1     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5f8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06c1     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5f4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06a1     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5f0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0681     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5ec 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0661     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5e8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0641     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5e4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0621     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
000015c5e0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0601     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001585dc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06e1     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585d8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06c1     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585d4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06a1     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585d0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0681     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585cc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0661     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585c8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0641     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585c4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0621     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001585c0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0601     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001575fc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fe1     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575f8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fc1     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575f4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fa1     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575f0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f81     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575ec 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f61     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575e8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f41     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575e4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f21     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001575e0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f01     0 0005 013 B024,B025,B026,B027,B028,B029,B030,B031
00001535dc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fe1     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535d8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fc1     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535d4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fa1     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535d0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f81     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535cc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f61     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535c8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f41     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535c4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f21     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
00001535c0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f01     1 0005 007 B024,B025,B026,B027,B028,B029,B030,B031
000099f11c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07e1     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f118 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07c1     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f114 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07a1     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f110 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0781     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f10c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0761     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f108 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0741     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f104 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0721     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099f100 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0701     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099b13c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07e1     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b138 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07c1     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b134 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07a1     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b130 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0781     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b12c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0761     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b128 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0741     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b124 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0721     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099b120 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0701     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099411c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ee1     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
0000994118 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ec1     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
0000994114 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ea1     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
0000994110 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e81     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099410c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e61     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
0000994108 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e41     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
0000994104 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e21     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
0000994100 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e01     1 0026 014 B024,B025,B026,B027,B028,B029,B030,B031
000099013c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ee1     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
0000990138 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ec1     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
0000990134 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ea1     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
0000990130 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e81     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000099012c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e61     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
0000990128 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e41     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
0000990124 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e21     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
0000990120 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e01     0 0026 000 B024,B025,B026,B027,B028,B029,B030,B031
000123d0dc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0d8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0d4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0d0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0cc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0c8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0c4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
000123d0c0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012390fc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390f8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390f4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390f0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390ec 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390e8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390e4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012390e0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012360dc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360d8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360d4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360d0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360cc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360c8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360c4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012360c0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     1 0048 037 B024,B025,B026,B027,B028,B029,B030,B031
00012320fc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320f8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320f4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320f0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320ec 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320e8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320e4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
00012320e0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     0 0048 023 B024,B025,B026,B027,B028,B029,B030,B031
000070e97c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ce1     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e978 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0cc1     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e974 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ca1     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e970 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c81     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e96c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c61     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e968 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c41     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e964 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c21     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070e960 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c01     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070a95c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ce1     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a958 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0cc1     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a954 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ca1     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a950 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c81     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a94c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c61     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a948 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c41     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a944 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c21     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070a940 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c01     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070597c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05e1     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
0000705978 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05c1     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
0000705974 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05a1     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
0000705970 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0581     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070596c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0561     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
0000705968 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0541     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
0000705964 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0521     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
0000705960 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0501     1 001c 015 B024,B025,B026,B027,B028,B029,B030,B031
000070195c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05e1     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
0000701958 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05c1     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
0000701954 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05a1     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
0000701950 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0581     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
000070194c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0561     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
0000701948 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0541     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
0000701944 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0521     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
0000701940 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0501     0 001c 001 B024,B025,B026,B027,B028,B029,B030,B031
00012ac6bc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6b8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6b4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6b0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6ac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6a8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6a4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012ac6a0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a869c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a8698 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a8694 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a8690 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a868c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a8688 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a8684 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a8680 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a76bc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76b8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76b4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76b0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76ac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76a8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76a4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a76a0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     0 004a 03a B024,B025,B026,B027,B028,B029,B030,B031
00012a369c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a3698 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a3694 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a3690 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a368c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a3688 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a3684 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
00012a3680 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     1 004a 02e B024,B025,B026,B027,B028,B029,B030,B031
0000d1e71c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06e1     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e718 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06c1     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e714 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06a1     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e710 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0681     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e70c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0661     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e708 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0641     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e704 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0621     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1e700 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0601     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1a73c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06e1     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a738 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06c1     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a734 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB06a1     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a730 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0681     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a72c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0661     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a728 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0641     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a724 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0621     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1a720 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0601     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1571c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fe1     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d15718 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fc1     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d15714 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fa1     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d15710 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f81     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1570c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f61     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d15708 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f41     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d15704 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f21     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d15700 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f01     0 0034 018 B024,B025,B026,B027,B028,B029,B030,B031
0000d1173c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fe1     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d11738 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fc1     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d11734 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0fa1     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d11730 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f81     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d1172c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f61     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d11728 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f41     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d11724 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f21     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
0000d11720 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0f01     1 0034 00c B024,B025,B026,B027,B028,B029,B030,B031
000006fd9c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04e1     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd98 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04c1     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd94 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04a1     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd90 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0481     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd8c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0461     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd88 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0441     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd84 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0421     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006fd80 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0401     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
000006bdbc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04e1     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bdb8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04c1     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bdb4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04a1     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bdb0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0481     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bdac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0461     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bda8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0441     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bda4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0421     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
000006bda0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0401     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000064d9c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0de1     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d98 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0dc1     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d94 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0da1     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d90 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d81     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d8c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d61     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d88 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d41     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d84 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d21     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000064d80 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d01     0 0001 032 B024,B025,B026,B027,B028,B029,B030,B031
0000060dbc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0de1     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060db8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0dc1     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060db4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0da1     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060db0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d81     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060dac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d61     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060da8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d41     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060da4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d21     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000060da0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d01     1 0001 026 B024,B025,B026,B027,B028,B029,B030,B031
0000a3df5c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0be1     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df58 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0bc1     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df54 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ba1     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df50 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b81     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df4c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b61     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df48 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b41     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df44 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b21     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a3df40 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b01     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a39f7c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0be1     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f78 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0bc1     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f74 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ba1     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f70 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b81     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f6c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b61     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f68 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b41     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f64 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b21     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a39f60 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0b01     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a36f5c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB02e1     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f58 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB02c1     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f54 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB02a1     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f50 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0281     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f4c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0261     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f48 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0241     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f44 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0221     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a36f40 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0201     1 0028 03d B024,B025,B026,B027,B028,B029,B030,B031
0000a32f7c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB02e1     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f78 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB02c1     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f74 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB02a1     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f70 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0281     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f6c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0261     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f68 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0241     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f64 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0221     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
0000a32f60 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0201     0 0028 029 B024,B025,B026,B027,B028,B029,B030,B031
000040fc3c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ae1     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc38 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ac1     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc34 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0aa1     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc30 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a81     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc2c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a61     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc28 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a41     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc24 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a21     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040fc20 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a01     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
000040bc1c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ae1     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc18 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ac1     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc14 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0aa1     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc10 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a81     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc0c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a61     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc08 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a41     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc04 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a21     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
000040bc00 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0a01     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000404c3c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB03e1     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c38 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB03c1     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c34 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB03a1     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c30 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0381     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c2c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0361     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c28 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0341     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c24 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0321     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000404c20 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0301     0 0010 010 B024,B025,B026,B027,B028,B029,B030,B031
0000400c1c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB03e1     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c18 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB03c1     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c14 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB03a1     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c10 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0381     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c0c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0361     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c08 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0341     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c04 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0321     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
0000400c00 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0301     1 0010 004 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcdc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB00e1     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcd8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB00c1     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcd4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB00a1     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcd0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0081     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfccc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0061     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcc8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0041     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcc4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0021     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cfcc0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0001     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012cbcfc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB00e1     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbcf8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB00c1     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbcf4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB00a1     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbcf0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0081     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbcec 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0061     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbce8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0041     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbce4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0021     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012cbce0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0001     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cdc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB09e1     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cd8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB09c1     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cd4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB09a1     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cd0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0981     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4ccc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0961     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cc8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0941     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cc4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0921     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c4cc0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0901     1 004b 017 B024,B025,B026,B027,B028,B029,B030,B031
00012c0cfc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB09e1     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0cf8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB09c1     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0cf4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB09a1     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0cf0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0981     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0cec 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0961     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0ce8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0941     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0ce4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0921     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
00012c0ce0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0901     0 004b 003 B024,B025,B026,B027,B028,B029,B030,B031
000041c73c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04e1     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c738 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04c1     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c734 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04a1     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c730 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0481     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c72c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0461     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c728 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0441     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c724 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0421     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041c720 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0401     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041871c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04e1     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000418718 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04c1     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000418714 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB04a1     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000418710 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0481     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
000041870c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0461     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000418708 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0441     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000418704 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0421     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000418700 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0401     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
000041773c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0de1     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
0000417738 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0dc1     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
0000417734 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0da1     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
0000417730 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d81     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041772c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d61     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
0000417728 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d41     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
0000417724 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d21     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
0000417720 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d01     1 0010 01c B024,B025,B026,B027,B028,B029,B030,B031
000041371c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0de1     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000413718 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0dc1     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000413714 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0da1     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000413710 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d81     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
000041370c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d61     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000413708 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d41     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000413704 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d21     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
0000413700 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0d01     0 0010 008 B024,B025,B026,B027,B028,B029,B030,B031
000079e57c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e578 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e574 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e570 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e56c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e568 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e564 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079e560 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079a55c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a558 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a554 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a550 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a54c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0861     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a548 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0841     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a544 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0821     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079a540 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0801     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079557c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
0000795578 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
0000795574 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
0000795570 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079556c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
0000795568 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
0000795564 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
0000795560 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     1 001e 015 B024,B025,B026,B027,B028,B029,B030,B031
000079155c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000791558 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000791554 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000791550 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
000079154c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000791548 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000791544 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000791540 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     0 001e 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd7c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07e1     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd78 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07c1     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd74 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07a1     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd70 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0781     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd6c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0761     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd68 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0741     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd64 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0721     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdfd60 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0701     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd5c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07e1     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd58 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07c1     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd54 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB07a1     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd50 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0781     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd4c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0761     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd48 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0741     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd44 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0721     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fdbd40 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0701     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d7c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ee1     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d78 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ec1     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d74 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ea1     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d70 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e81     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d6c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e61     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d68 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e41     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d64 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e21     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd4d60 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e01     1 003f 015 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d5c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ee1     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d58 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ec1     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d54 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ea1     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d50 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e81     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d4c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e61     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d48 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e41     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d44 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e21     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
0000fd0d40 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0e01     0 003f 001 B024,B025,B026,B027,B028,B029,B030,B031
00005cd63c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05e1     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd638 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05c1     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd634 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05a1     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd630 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0581     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd62c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0561     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd628 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0541     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd624 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0521     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005cd620 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0501     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c961c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05e1     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c9618 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05c1     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c9614 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB05a1     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c9610 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0581     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c960c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0561     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c9608 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0541     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c9604 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0521     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c9600 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0501     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c663c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ce1     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c6638 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0cc1     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c6634 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ca1     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c6630 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c81     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c662c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c61     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c6628 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c41     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c6624 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c21     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c6620 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c01     1 0017 01c B024,B025,B026,B027,B028,B029,B030,B031
00005c261c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ce1     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c2618 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0cc1     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c2614 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0ca1     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c2610 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c81     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c260c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c61     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c2608 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c41     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c2604 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c21     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
00005c2600 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0c01     0 0017 008 B024,B025,B026,B027,B028,B029,B030,B031
000055da9c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da98 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da94 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da90 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da8c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da88 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da84 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
000055da80 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
0000559abc 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01e1     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559ab8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01c1     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559ab4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB01a1     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559ab0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0181     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559aac 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0161     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559aa8 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0141     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559aa4 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0121     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000559aa0 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0101     0 0015 00a B024,B025,B026,B027,B028,B029,B030,B031
0000556a9c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08e1     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
0000556a98 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08c1     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
0000556a94 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB08a1     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
0000556a90 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB0881     1 0015 01e B024,B025,B026,B027,B028,B029,B030,B031
If you are getting failure for first MB of FB then try option -no_scan_out
Error Code = 00000001
发表于 2024-3-24 16:10:28 | 只看该作者 来自: 中国 来自 中国
应该是第三课
发表于 2024-3-24 16:22:22 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
谢谢指点我今天试试  详情 回复 发表于 2024-3-25 09:50
发表于 2024-3-24 17:55:25 | 只看该作者 来自: 海南五指山 来自 海南五指山
1 2 3 4 a1 a0 b1 b0
清楚了 谢谢指点 谢谢新知识 谢谢老师  详情 回复 发表于 2024-3-25 09:52
发表于 2024-3-24 18:54:23 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
这个。  小伙子。
谢谢老师指点我今天换这颗试试  详情 回复 发表于 2024-3-25 09:46
发表于 2024-3-24 19:24:03 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
第四个是B0
谢谢 今天试试修好了再给大家答案  详情 回复 发表于 2024-3-25 09:48
发表于 2024-3-25 08:54:24 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
3
发表于 2024-3-25 09:46:12 | 只看该作者 来自: 泰国 来自 泰国
H55 发表于 2024-3-24 18:54
这个。  小伙子。
谢谢老师指点我今天换这颗试试
发表于 2024-3-25 09:48:53 | 只看该作者 来自: 泰国 来自 泰国
谢谢 今天试试修好了再给大家答案
发表于 2024-3-25 09:50:33 | 只看该作者 来自: 泰国 来自 泰国
谢谢指点我今天试试
发表于 2024-3-25 09:52:42 | 只看该作者 来自: 泰国 来自 泰国
清楚了 谢谢指点 谢谢新知识 谢谢老师
发表于 2024-3-25 18:39:38 来自迅维网APP | 只看该作者 来自: 四川 来自 四川
兄弟这是捡钱了啊,第四个虚焊了吧
应该不是虚焊换了新的还是一样  详情 回复 发表于 2024-3-26 09:03
发表于 2024-3-25 18:50:41 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
加焊显存会返修,重植核心
谢谢 不知道是虚焊还是挂了  详情 回复 发表于 2024-3-26 09:09
发表于 2024-3-26 03:15:56 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
如果换了还是一样就是显卡挂了
是啊 换了新的还是一样,最后换了显卡好了,谢谢指点。  详情 回复 发表于 2024-3-26 09:06
发表于 2024-3-26 09:03:35 | 只看该作者 来自: 泰国 来自 泰国
老吴来了 发表于 2024-3-25 18:39
兄弟这是捡钱了啊,第四个虚焊了吧
应该不是虚焊换了新的还是一样
发表于 2024-3-26 09:06:28 | 只看该作者 来自: 泰国 来自 泰国
u1481419 发表于 2024-3-26 03:15
如果换了还是一样就是显卡挂了
发表于 2024-3-26 09:09:20 | 只看该作者 来自: 泰国 来自 泰国
panchang 发表于 2024-3-25 18:50
加焊显存会返修,重植核心
谢谢 不知道是虚焊还是挂了
发表于 2024-3-26 11:47:59 | 只看该作者 来自: 内蒙古 来自 内蒙古
显存B0出了问题,5楼正解
