查看: 4555|回复: 19
Help me recover SSD EXRAM / KINGSPEC / CeaMere (Realtek RM1135+Hynix 3dv6)
发表于 2023-6-14 04:57:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 俄罗斯 来自 俄罗斯
On hand there is an EXRAM SSD (aka KINGSPEC P3, CeaMere - https://smarthdd.com/rus/database/P3-128/ZD0R3G50) with a broken firmware (the volume has become 1 MB).
Realtek_SSD_flash_id shows (there is another fully functional SSD):
Fw : ZD0R3G50
Size : 244198 MB [256.1 GB]
FwStr: [REALTEK_RL6643ZD0R3G50_p_tH3V6V5.18]
Bank04: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank06: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank08: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank10: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
The program itself for the firmware is (SSDMP_2.59.0.0_20220610), automatically detects the memory as Hynix H25BFT8B3B8R-BDJ (H3V6) (3DT), but when trying to flash it stops at step 8 -- Llf Init
That is, the necessary Llf files (bank_imem.ram, etc.) are missing.
I ask for help in finding Llf files to restore this SSD.
手头有一个固件损坏的 EXRAM SSD(又名 KINGSPEC P3,CeaMere - https://smarthdd.com/rus/database/P3-128/ZD0R3G50)(体积已变为 1 MB)。
Realtek_SSD_flash_id 显示(还有另一个功能齐全的 SSD):
固件:ZD0R3G50
大小:244198 MB [256.1 GB]
Bank04:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
Bank06:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
Bank08:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
Bank10:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
固件程序本身是 (SSDMP_2.59.0.0_20220610),自动检测内存为 Hynix H25BFT8B3B8R-BDJ (H3V6) (3DT),但在尝试闪存时它停止在第 8 步 -- Llf Init
也就是说,缺少必要的 Llf 文件(bank_imem.ram 等)。
我请求帮助寻找 Llf 文件来恢复这个 SSD。
发表于 2023-7-11 09:55:11 | 只看该作者 来自: 陕西西安 来自 陕西西安
来自俄国的朋友
发表于 2023-6-15 16:01:39 | 只看该作者 来自: 辽宁 来自 辽宁
没看明白想表达啥
发表于 2023-7-5 16:02:00 | 只看该作者 来自: 中国 来自 中国
Hynix 3dv6这个固件不公开,小钱也买不到
发表于 2023-8-10 04:34:17 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
Пытаюсь сейчас с помощью 1691126435-RM1135_HynixV6_4Lun_ZD1N3G5K_ZD0R3G5K_SSDMP2.58.0.0_20220701 восстановить свой диск, но пока результат тот же, остановка на шаге 8 -- Llf Init, и таймаут.
can you share the tool  详情 回复 发表于 2023-8-10 10:24
发表于 2023-8-10 10:24:32 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
sazdmitrij 发表于 2023-8-10 04:34
Пытаюсь сейчас с помощью 1691126435-RM1135_HynixV6_4Lun_ZD1N3G5K_ZD0R3G5K_SSDMP ...
Могу, держите - По ссылке из этого документа вы сможете скачать несколько версий SSDMP, для различных типов па  详情 回复 发表于 2023-8-13 07:58
发表于 2023-8-11 09:16:58 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
Try This the tool,..baru mendapatkan dari tetangga sebelah.semoga bermanfaat
https://www.chinafix.com/thread-1345594-1-1.html
Это тоже самое, один в один, что и 1691126435-RM1135_HynixV6_4Lun_ZD1N3G5K_ZD0R3G5K_SSDMP2.58.0.0_20220701  详情 回复 发表于 2023-8-13 08:00
发表于 2023-8-13 07:58:59 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
Могу, держите - SSDMP.txt (37 Bytes, 下载次数: 12)
need Partikel BICS3 and YX2T for my collection  详情 回复 发表于 2023-8-13 08:28
发表于 2023-8-13 08:00:26 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
https://www.chinafix.c ...
apakah maksud nya membutuhkan tutorial untuk memperbaiki ssd nya  详情 回复 发表于 2023-8-13 08:28
发表于 2023-8-13 08:28:00 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
sazdmitrij Posted on 2023-8-13 07:58
Могу, держите -
По ссылке из этого документа вы смож ...
发表于 2023-8-13 08:28:53 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
sazdmitrij 发表于 2023-8-13 08:00
Это тоже самое, один в один, что и 1691126435-RM1135_HynixV6_4Lun_ZD1N3G5 ...
Я уже успешно восстанавливал SSD на контроллере RM1135. Но вот с Hynix 3dv6 не получается. Да, дайте своё руководство, м  详情 回复 发表于 2023-8-13 08:32
发表于 2023-8-13 08:32:10 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
Я уже успешно восстанавливал SSD на контроллере RM1135. Но вот с Hynix 3dv6 не получается. Да, дайте своё руководство, может поможет.
tunjukkan error atau failed nya seperti apa  详情 回复 发表于 2023-8-13 08:52
发表于 2023-8-13 08:52:00 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
sazdmitrij 发表于 2023-8-13 08:32
Я уже успешно восстанавливал SSD на контроллере RM1135. Но ...
发表于 2023-8-13 09:37:00 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
Timeout
try this tool https://www.ssdtool.cc/realtek/rm1135/rm1135_hynixv6_4lun_zd1n3g5k_zd0r3g5k_ssdmp2-58-0-0_20220701.html  详情 回复 发表于 2023-8-13 09:55
its wrong file bank_imem.ram (H3DV6)  详情 回复 发表于 2023-8-13 09:48
发表于 2023-8-13 09:48:10 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
发表于 2023-8-13 09:55:49 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
coba alat ini
RM1135_HynixV6_ZD1N3G5K_ZD0R3G5K.rar
12 MB, 下载次数: 59, 下载积分: 下载分 -2 分, 下载 1 次
Я писал выше, что это тоже самое что и у меня. Вы ранее давали ссылку на эту же утилиту https://www.chinafix.com/thread-1345594-1-1.h  详情 回复 发表于 2023-8-13 10:32
发表于 2023-8-13 10:32:10 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
Я писал выше, что это тоже самое что и у меня. Вы ранее давали ссылку на эту же утилиту https://www.chinafix.com/thread-1345594-1-1.html
kok beda dengan ssdmp saya  详情 回复 发表于 2023-8-13 10:51
发表于 2023-8-13 10:51:47 | 只看该作者 来自: 印度尼西亚 来自 印度尼西亚
sazdmitrij 发表于 2023-8-13 10:32
Я писал выше, что это тоже самое что и у меня. Вы ранее  ...
Просто я применил более позднюю версию ssdmp и сократил название файлов LLF. Это не на что не влияет. Вот скриншо  详情 回复 发表于 2023-8-13 21:56
发表于 2023-8-13 21:56:55 | 只看该作者 来自: 俄罗斯 来自 俄罗斯
Вот скриншоты с версией ssdmp как у вас:
Лог файл:
********[DUT 0] 13_20230813164516********
-- Step 00 -- Check Device Setting  -> Pass
-- Step 01 -- Check flash id  -> Pass
-- Step 02 -- Generate Config  -> Pass
-- Step 03 -- Clear DL Tag and setting in SPI  -> Pass
-- Step 04 -- Check Flash Type  -> Pass
-- Step 05 -- Check Device Setting  -> Pass
-- Step 06 -- Download banka1  -> Pass
-- Step 07 -- Load Configure File  -> Pass
-- Step 08 -- Download FC Table  -> Pass
-- Step 09 -- Llf Init -> Timeout
Fail        Test time: 246 s
Model name: Realtek_sata
Serial number: 5964804208131641100
Capacity: 256GB
Station: MP1
发表于 2023-9-8 21:42:18 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
他挺开心啊
