查看: 1602|回复: 14
LA-G131P VCC_GT rail problem | short circuit SoC CPU i7-8th H & DrMOS
发表于 2023-5-13 03:10:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 阿塞拜疆 来自 阿塞拜疆
There is a customer complaint: but there is no image. Thecustomer himself did the cleaning and maintenance of the motherboard. then hecollected the computer and there was no vision
Visually inspected the motherboard once. I didn't see anybroken resistance or a damaged line.
Took the motherboard out of the case. There was anisolated label on the back of the motherboard.
Took it off. and I saw that anSMD capacitor belonging to the CPU VCC_GT line had fried. and it was shortcircuited.
Removed the short circuit capacitor. I started the motherboardstill the same situation. fans freeze fast and no display.
Said to myselfthat I need to examine it from the sky now. there was signal timing in theschematic of the motherboard.
Measured everything in order with the method. Iknow and the timing on the motherboard.
All VRM output on the motherboard wasintact. there was just no VCC_GT voltage.
There was an abnormally low value on the CPU VCC_GT line. 0.002 ohms.this was so abnormal.
Removed the DrMOS IC. there was still a short on theVCC_GT line
There was a high probability that the CPU was bad. Ordereda scrap motherboard on ebay.
Motherboard belongs to dell machine. had liquidcontact. Measured the CPU line, there was no short circuit. I changed the CPUat risk.
Took remeasures and the CPU line VCC_GT was normal. the averagevalue is 0.023 ohms
Everything is perfectly normal. I changed the CPU. Iconnected it to the power source and started.
Still no image and still no voltage VCC_GT
Let's think a little...
Why is there still no image? The current drawn from thepower supply is normal.
Meanwhile I reprogrammed the BIOS and EC. I edited theBIOS on the official site. I'm pretty sure it's the BIOS.
I connected post card from EC Debug line.  post code 63. this error code points to IntelHD graphics card[/al ...
本帖为优秀帖,如要查看隐藏内容,需使用100鑫豆兑换(鑫豆全部给作者)。写帖不易,请多支持。立即支付
购买记录
购买人数2价格购买时间
 会员330025100鑫豆2024-10-6 12:31
 会员8815080.5元2023-5-31 09:53
查看所有购买记录
参与人数 3下载分 +10 +2 收起 理由
天意wx + 3 给愿意分享经验的人加分!
新芯箱硬88 + 5
本文由 会员1244779 原创或被授权转载制作,其他机构或个人未经许可严禁转载。
发表于 2023-5-14 07:46:40 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
Nice work!
回复 支持 3 反对 0
发表于 2023-5-14 00:23:49 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
google translate
回复 支持 3 反对 0
发表于 2023-5-14 00:19:50 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
fixlover 发表于 2023-5-13 10:07
标题搞错了吧。图片里是 la-f541p,不是 LA-G131P 哦。
(it is not a LA-G131P. la-f541p in the picture. ...
I'm aware of that my friend
dell motherboard i bought from ebay for second hand CPU
回复 支持 3 反对 0
发表于 2023-5-13 17:15:29 | 只看该作者 来自: 广东 来自 广东
It should be that the pipe burned through and burned out the CPU
回复 支持 3 反对 0
发表于 2023-5-13 14:33:01 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
全英文,看不懂
google translate  详情 回复 发表于 2023-5-14 00:23
回复 支持 3 反对 0
发表于 2023-5-13 10:07:54 | 只看该作者 来自: 中国 来自 中国
(it is not a LA-G131P. la-f541p in the picture.)
I'm aware of that my friend dell motherboard i bought from ebay for second hand CPU  详情 回复 发表于 2023-5-14 00:19
回复 支持 3 反对 0
发表于 2023-5-14 07:47:22 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
Nice work!!
回复 支持 2 反对 0
发表于 2023-5-14 20:22:40 | 只看该作者 来自: 贵州贵阳 来自 贵州贵阳
太高科举看不明白
发表于 2023-5-14 19:42:04 来自迅维网APP | 只看该作者 来自: 四川成都 来自 四川成都
路过围观,全英文把我都看懵了
发表于 2023-5-14 18:13:23 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
不说句英语都不好意思回复,你这个很OK啊
发表于 2023-5-14 19:08:18 来自迅维网APP | 只看该作者 来自: 内蒙古 来自 内蒙古
路过学一下,太难了
发表于 2023-5-14 23:31:09 来自迅维网APP | 只看该作者 来自: 上海 来自 上海
支持老铁,老想去外高加三国玩一玩了,老铁接待不
发表于 2023-5-15 00:06:01 | 只看该作者 来自: 江西 来自 江西
路过,学习了
发表于 2023-5-15 08:55:05 来自迅维网APP | 只看该作者 来自: 广东揭阳 来自 广东揭阳
全英文,还好,能看懂了一点点意思!
