查看: 923|回复: 5
LA-E892P short SoC CPU
发表于 2023-5-5 04:46:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 阿塞拜疆 来自 阿塞拜疆
A laptop arrived at our service. complaint: no start onlaptop
I connected the power supply. and there was a short circuitin the mains voltage.
Because I noticed that the CPU gets hot when the mainvoltage comes on.
i checked with my thermal camera yes cpu is getting hot. Istarted to examine over the sky.
If the CPU is getting hot, it means one of itsmosfets is broken. I found a dual n channel mosfet with a short circuit
Dual n Channel MOSFET- was broken. and the upper mosfet init was short circuit.
I also measured the mosfet outside. short circuit. Ireplaced the mosfet with a new one. and the short circuit problem is gone
So far, so good. I connected the motherboard to the powersupply. was in standby mode. I started and I'm happy. I said multiple endings.motherboard started. I immediately connected the ram and panel. I started. noimage
I thought it might be due to BIOS issue or RAM. I wrote theBIOS on the official site and tried other working RAM. unfortunately nothing iswrong. When I measured all the coils the voltages were all active. sequentiallywith the motherboard's signal timing, all required signals were active.
VCC_GT voltage seems strange to me. 0.6V. Because VCC_GTvoltage should rise momentarily and then become low after the motherboardstarts up. The operating system time needs to be increased. of course, avoltage that changes according to the image on the motherboard
then i connected post card
[align=l ...
本帖为优秀帖,如要查看隐藏内容,需使用100鑫豆兑换(鑫豆全部给作者)。写帖不易,请多支持。立即支付
购买记录
购买人数2价格购买时间
 会员398800100鑫豆2023-12-7 13:31
 会员11686910.5元2023-5-18 15:08
查看所有购买记录
参与人数 5下载分 +13 +7 收起 理由
天意wx + 5 给愿意分享经验的人加分!
奏奏奏奏奏 + 5 + 5 GOOD
Linshengqiang + 1 + 1 给愿意分享经验的人加分!
u1489997 + 1
xw272021261 + 2 老司机!双击666+关注.....
本文由 会员1244779 原创或被授权转载制作,其他机构或个人未经许可严禁转载。
发表于 2023-5-6 13:45:27 | 只看该作者 来自: 江苏无锡 来自 江苏无锡
如果只是换了个mos管  有大概率会返修
发表于 2023-5-5 09:05:07 | 只看该作者 来自: 中国 来自 中国
awesome, thank for sharing
发表于 2023-5-5 10:10:01 | 只看该作者 来自: 山东济南 来自 山东济南
路过学习,感谢经验分享。
发表于 2023-6-29 16:20:02 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
楼主有微信吗    那边工资怎么样
发表于 2023-7-7 03:17:00 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
我市 发表于 2023-6-29 16:20
楼主有微信吗    那边工资怎么样
i use whatsapp
