This disk contains three files:A10MV24.BIN,README.TXT and AWDFLASH.EXE
1.The checksum of A10MV24.BIN is 7ADC(Hex) ;
2. How to use AWDFLASH.EXE utility:
This is a flash memory write/read utility.
IMPORTANT NOTE:
The AWDFLASH utility could not correctly run in windows (virtual 8086)
MS-DOS mode. It must be proceeded with the following steps:
1.Create a bootable system floppy diskette by typing "FORMAT A:/S"
from the dos prompt under DOS6.XX or WINDOWS9X environment.
2.Boot system with diskette.
3.Then run the AWDFLASH utility.
Usage:
AWDFLASH [BIOSfile1] [BIOSfile2] [/<sw>[/<sw>...]]
BIOSfile1: New BIOS Name For FLASH Programming
BIOSfile2: BIOS File For Backing-up the Original BIOS
<command> function definition:
cc: clear CMOS; cp: clear PnP;
cd: clear DMI.
/sn: No Original BIOS Backup. If this option is chosen:
Be sure your new BIOS is compatible with your MB. If not, the system
are damaged.
/sy: Backup Original BIOS to Disk File.
Examples:
AWDFLASH ****.BIN /py/sn/cd/cp
Warning:
Avoid power-off incidently in upgrading procedure, or system would fail
to reboot!
