查看: 687|回复: 3
PS5 marking code ic
发表于 2022-9-25 05:21:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 阿塞拜疆 来自 阿塞拜疆
Hello to everyone
To be honest, I didn't know where to post the topic in the forum.
I'm reviewing a ps5 motherboard. There is an integrated on the motherboard, I have no idea what it is. I searched with many methods and couldn't find it.
发表于 2022-9-25 17:06:21 | 只看该作者 来自: 广西梧州 来自 广西梧州
No one can help you unless you provide a clear picture of the chip.
发表于 2022-9-25 20:40:02 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
pwm on the left.
the code on it looks clear
发表于 2022-9-26 15:46:01 | 只看该作者 来自: 欧洲 来自 欧洲
On some ps5 motherboards, this pwm is used instead of that pwm
