查看: 1028|回复: 7
Nvidia 3xxx series memory training
发表于 2022-8-26 20:24:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 北美地区 来自 北美地区
Could someone please help me dump the memory training status on Nvidia 3xxx series cards.. I've been getting a bunch in for repair but some can't seem to be diagnosed using mods/mats.. Mods crashs with 454 error.. I would really appreciate any help at all.. Thanks
发表于 2022-8-27 07:57:07 来自迅维网APP | 只看该作者 来自: 江苏 来自 江苏
I can, need to add my wechat account: weixiukongJian6
Okay.. Thank you so much.. I'm trying to create a account but need someone with a account to scan this code.. I've attached it...  详情 回复 发表于 2022-8-27 16:05
发表于 2022-8-27 16:05:07 来自迅维网APP | 只看该作者 来自: 北美地区 来自 北美地区
发表于 2022-8-27 18:54:20 | 只看该作者 来自: 北美地区 来自 北美地区
"Error 464"
发表于 2022-8-27 18:59:14 来自迅维网APP | 只看该作者 来自: 北美地区 来自 北美地区
Sorry correction in my original post I said error 454 I meant 464 here are some pics as well..
发表于 2022-8-27 20:54:26 来自迅维网APP | 只看该作者 来自: 北美地区 来自 北美地区
Okay so I'm making some progress.. In the previous posts I was using Mods version 455.127 which wasn't working at all for the 3080 that I'm currently trying to diagnose.. Now that I'm on a newer version it is now running but I'm still unable to identify which bank is having errors.. I've attached another pic. I've been looping test 178 and have noticed it passes some and fails some but the errors are at a unknown location.. If anyone has any advice on what to do I would appreciate it.. Thanks
发表于 2022-8-28 05:09:59 来自迅维网APP | 只看该作者 来自: 广东佛山 来自 广东佛山
把你输入的命令打出来,才好判断
Thank you for your response but what exactly do you mean? I can't get any usable result no matter which command I use..  详情 回复 发表于 2022-8-28 13:48
发表于 2022-8-28 13:48:07 | 只看该作者 来自: 北美地区 来自 北美地区
hg580000 发表于 2022-8-28 05:09
把你输入的命令打出来,才好判断
