查看: 1692|回复: 8
[MACBOOK]
A1706开机输入密码进桌面就会出五国语言重启
发表于 2022-6-17 22:59:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 中国 来自 中国
A1706开机输入密码进桌面就会出五国语言重启,麻烦各位大神指点一下
macOS的问题报告:
panic(cpu 0 caller 0xffffff7faa0e54ca) [IGPU] sendHostToGucMessage Firmware communication error no action response!n @IGGuC.cpp3522
Panicked task 0xffffff869a0c2670 177 threads pid 0 kernel_task
Backtrace (CPU 0), panicked thread 0xffffff8b66106aa8, Frame  Return Address
0xffffffe06a06b920  0xffffff8011a83e2d
0xffffffe06a06b970  0xffffff8011be3cb6
0xffffffe06a06b9b0  0xffffff8011bd350d
0xffffffe06a06ba00  0xffffff8011a23a60
0xffffffe06a06ba20  0xffffff8011a841fd
0xffffffe06a06bb40  0xffffff8011a839b6
0xffffffe06a06bba0  0xffffff80123164bf
0xffffffe06a06bc90  0xffffff7faa0e54ca
0xffffffe06a06bcd0  0xffffff7faa05c94f
0xffffffe06a06bd00  0xffffff7faa05aa02
0xffffffe06a06bd40  0xffffff7faa05d126
0xffffffe06a06bda0  0xffffff7faa05dbf3
0xffffffe06a06bde0  0xffffff7faa05b1c6
0xffffffe06a06be20  0xffffff7faa0e510b
0xffffffe06a06be70  0xffffff7faa0592ec
0xffffffe06a06bed0  0xffffff8012247454
0xffffffe06a06bf20  0xffffff8012245d0e
0xffffffe06a06bf60  0xffffff8012245337
0xffffffe06a06bfa0  0xffffff8011a2318e
      Kernel Extensions in backtrace
         com.apple.driver.AppleIntelKBLGraphics(18.0.5)[607CA1F5-22D1-36F4-8A73-6C6E739C1245]@0xffffff7faa057000-0xffffff7faa115fff
            dependency com.apple.iokit.IOAcceleratorFamily2(462.8)[2ED59269-2A13-3F67-AB1A-212DB14FC5F2]@0xffffff7faa9a2000-0xffffff7faaa0cfff
            dependency com.apple.iokit.IOGraphicsFamily(594)[3ECB2385-311A-374E-9C0F-65639BA26A05]@0xffffff7faab3f000-0xffffff7faab6dfff
            dependency com.apple.iokit.IOPCIFamily(2.9)[A436E92C-DE10-3718-AEF4-ED2A788A466A]@0xffffff8014603000-0xffffff801462efff
            dependency com.apple.iokit.IOSurface(302.14)[1DA5DCF0-D472-33C0-90C9-2AB910EBC473]@0xffffff8014773000-0xffffff801478ffff
Process name corresponding to current thread (0xffffff8b66106aa8) kernel_task
Mac OS version
21E258
Kernel version
Darwin Kernel Version 21.4.0 Fri Mar 18 004505 PDT 2022; rootxnu-8020.101.4~15RELEASE_X86_64
Kernel UUID B6F8637B-0844-355F-8C82-60FA06149384
KernelCache slide 0x0000000011800000
KernelCache base  0xffffff8011a00000
Kernel slide      0x0000000011810000
Kernel text base  0xffffff8011a10000
__HIB  text base 0xffffff8011900000
System model name MacBookPro14,2 (Mac-CAD6701F7CEA0921)
System shutdown begun NO
Panic diags file available YES (0x0)
Hibernation exit count 0
System uptime in nanoseconds 47905384460
Last Sleep           absolute           base_tsc          base_nano
  Uptime   0x0000000b27622efa
  Sleep    0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake     0x0000000000000000 0x00000006486de7d5 0x0000000000000000
Compressor Info 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info
  Foreign  0xffffff80271a5000 - 0xffffff80271b3000
  Native   0xffffff803398d000 - 0xffffffa03398d000
  Readonly 0xffffff8500659000 - 0xffffff8699ff2000
  Metadata 0xfffffffc543a1000 - 0xfffffffc74469000
  Bitmaps  0xfffffffc74469000 - 0xfffffffc77469000
last started kext at 39091254855 AudioAUUC        1.70 (addr 0xffffff7faa8a9000, size 12288)
loaded kexts
AudioAUUC        1.70
@filesystems.msdosfs        1.10
X86PlatformShim        1.0.0
AGPM        127
!APlatformEnabler        2.7.0d0
!AHIDALSService        1
@filesystems.autofs        3.0
!AUpstreamUserClient        3.6.9
!AHDAHardwareConfigDriver        340.2
!AHDA        340.2
AGDCBacklightControl        6.5.7
!A!IKBLGraphics        18.0.5
!ABacklight        180.5
!A!IPCHPMC        2.0.1
!AGFXHDA        140.3
!AMCCSControl        1.15
ACPI_SMC_PlatformPlugin        1.0.0
@UVCService        1
!AGraphicsDevicePolicy        6.5.7
!A!IKBLGraphicsFramebuffer        18.0.5
!AFIVRDriver        4.1.0
eficheck        1
!AEmbeddedOSSupportHost        1
@AGDCPluginDisplayMetrics        6.5.7
!AThunderboltIP        4.0.3
pmtelemetry        1
IOUserEthernet        1.0.1
usb.!UUserHCI        1
!AHV        1
!ADiskImages2        126.100.13
!A!ISlowAdaptiveClocking        4.0.0
!AFileSystemDriver        3.0.1
@filesystems.tmpfs        1
@filesystems.lifs        1
@filesystems.apfs        1934.101.3
@filesystems.hfs.kext        583.100.10
@BootCache        40
@!AFSCompression.!AFSCompressionTypeZlib        1.0.0
@!AFSCompression.!AFSCompressionTypeDataless        1.0.0d1
!ATopCaseHIDEventDriver        5440.11
AirPort.BrcmNIC        1400.1.1
@private.KextAudit        1.0
!AACPIButtons        6.1
!ASmartBatteryManager        161.0.0
!ARTC        2.0.1
!ASMBIOS        2.1
!AACPIEC        6.1
!AAPIC        1.7
@!ASystemPolicy        2.0.0
@nke.applicationfirewall        402
IOKitRegistryCompatibility        1
EndpointSecurity        1
@Dont_Steal_Mac_OS_X        7.0.0
@kec.!AEncryptedArchive        1
@kext.triggers        1.0
DspFuncLib        340.2
@kext.OSvKernDSPLib        529
!ABacklightExpert        1.1.0
!ASMBusPCI        1.0.14d1
!AHDA!C        340.2
IOHDA!F        340.2
IOAudio!F        340.2
@vecLib.kext        1.2.0
IONDRVSupport        594
!ASMBus!C        1.0.18d1
IOPlatformPluginLegacy        1.0.0
X86PlatformPlugin        1.0.0
IOPlatformPlugin!F        6.0.0d8
!AGraphicsControl        6.5.7
!A!ILpssUARTv1        3.0.60
!A!ILpssUARTCommon        3.0.60
!AOnboardSerial        1.0
IOSerial!F        11
IOAccelerator!F2        462.8
usb.IOUSBHostHIDDevice        1.2
!AThunderboltEDMSink        5.0.3
!AThunderboltDPOutAdapter        8.5.1
IO!BSerialManager        9.0.0
IO!BPacketLogger        9.0.0
IO!BHost!CUSBTransport        9.0.0
IO!BHost!CUARTTransport        9.0.0
IO!BHost!CTransport        9.0.0
IO!BHost!CPCIeTransport        9.0.0
IOAVB!F        1040.6
@plugin.IOgPTPPlugin        1040.3
IOEthernetAVB!C        1.1.0
CSR!BHost!CUSBTransport        9.0.0
Broadcom!BHost!CUSBTransport        9.0.0
Broadcom!B20703USBTransport        9.0.0
!AIPAppender        1.0
@!AGPUWrangler        6.5.7
@!AGraphicsDeviceControl        6.5.7
IOGraphics!F        594
IOSlowAdaptiveClocking!F        1.0.0
usb.cdc.ecm        5.0.0
usb.cdc.ncm        5.0.0
usb.!UiBridge        1.0
usb.cdc        5.0.0
usb.networking        5.0.0
usb.!UHostCompositeDevice        1.2
!AThunderboltPCIDownAdapter        4.1.1
!AThunderboltDPInAdapter        8.5.1
!AThunderboltDPAdapter!F        8.5.1
!AHPM        3.4.4
!A!ILpssI2C!C        3.0.60
!AXsanScheme        3
!ABSDKextStarter        3
IOSurface        302.14
@filesystems.hfs.encodings.kext        1
!AActuatorDriver        5440.11
!AHIDKeyboard        228.1
!AMultitouchDriver        5440.11
!AInputDeviceSupport        5440.6
!AHS!BDriver        5440.11
IO!BHIDDriver        9.0.0
!AHSSPIHIDDriver        63
!AThunderboltNHI        7.2.81
IOThunderbolt!F        9.3.3
!AHSSPISupport        63
IO80211!FLegacy        1200.12.2b1
IOSkywalk!F        1.0
mDNSOffloadUserClient        1.0.1b8
corecapture        1.0.4
IONVMe!F        2.1.0
!A!ILpssSpi!C        3.0.60
!A!ILpssDmac        3.0.60
!A!ILpssI2C        3.0.60
!A!ILpssGspi        3.0.60
usb.!UXHCIPCI        1.2
usb.!UXHCI        1.2
usb.!UHostPacketFilter        1.0
IOUSB!F        900.4.2
!AEFINVRAM        2.1
!AEFIRuntime        2.1
IOSMBus!F        1.1
IOHID!F        2.0.0
IOTimeSync!F        1040.3
IONetworking!F        3.4
DiskImages        493.0.0
IO!B!F        9.0.0
IOReport!F        47
$quarantine        4
$sandbox        300.0
@kext.!AMatch        1.0.0d1
CoreAnalytics!F        1
!ASSE        1.0
!AKeyStore        2
!UTDM        533.100.11
IOUSBMass!SDriver        210.101.2
IOSCSIBlockCommandsDevice        456.100.7
IO!S!F        2.1
IOSCSIArchitectureModel!F        456.100.7
!AMobileFileIntegrity        1.0.5
$!AImage4        4.2.0
@kext.CoreTrust        1
!AFDEKeyStore        28.30
!AEffaceable!S        1.0
!ACredentialManager        1.0
KernelRelayHost        1
IOUSBHost!F        1.2
!UHostMergeProperties        1.2
usb.!UCommon        1.0
!ABusPower!C        1.0
!ASEPManager        1.0.1
IOSlaveProcessor        1
!AACPIPlatform        6.1
!ASMC        3.1.9
IOPCI!F        2.9
IOACPI!F        1.4
watchdog        1
@kec.pthread        1
@kec.Libm        1
@kec.corecrypto        12.0
发表于 2022-6-18 08:13:30 | 只看该作者 来自: 河北唐山 来自 河北唐山
o,no,我是个小小小白。、
你都不如发个桌面的照片,让大家看看都是哪五国在斗地主。
发表于 2022-6-18 08:17:16 | 只看该作者 来自: 浙江金华 来自 浙江金华
恢复或者重装
嗯,恢复过,重装过,试过几种重置,还是一样  详情 回复 发表于 2022-6-18 22:28
发表于 2022-6-18 22:28:25 | 只看该作者 来自: 中国 来自 中国
发表于 2022-6-18 22:30:22 | 只看该作者 来自: 中国 来自 中国
安全模式可以进去,正常模式会五国语言重启,这种跟CPU 和ME 有关吗
发表于 2022-7-21 10:09:34 | 只看该作者 来自: 广东广州 来自 广东广州
CPU问题 换U吧
发表于 2022-7-22 19:34:01 | 只看该作者 来自: 山东济南 来自 山东济南
换u试试吧 估计u挂了
发表于 2023-3-11 14:05:52 | 只看该作者 来自: 湖北 来自 湖北
看看触摸条亮不亮,把外设都拔了
再一看都2023年了哈哈哈  详情 回复 发表于 2023-3-11 14:06
发表于 2023-3-11 14:06:35 | 只看该作者 来自: 湖北 来自 湖北
百度bDXeP 发表于 2023-3-11 14:05
看看触摸条亮不亮,把外设都拔了
再一看都2023年了哈哈哈
