楼主: vusalcrm
Palit RTX3080 PCI-e not detected
发表于 2022-2-28 23:21:27 | 只看该作者 来自: 欧洲 来自 欧洲
qinhecat 发表于 2022-2-28 19:35
1V8 - 313 ohm - diode -0.341
1V8 power's res is  abnormal,normally it will be 10~30k ohm or above. ...
I will give low voltage from outside and try.
发表于 2022-3-2 03:33:00 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
I removed one leg of the 1.8v coil
The value on the pwm side is high ohm (9-10kohm)
output was low. 340 ohms. I supplied voltage from outside. It would draw 0.02 current. but i didn't see anything warming up
I measured my 3080's 1.8v rail and it's 400 ohm in resistance and 341 ohm in diode... Maybe you don't have a problem here.  详情 回复 发表于 2022-3-2 19:18
发表于 2022-3-2 05:41:58 | 只看该作者 来自: 美国 来自 美国
if rst signal is OK, please be are the diode voltage to ground, (red test lead to groud about 0.3, black to ground should be infinity).
If I'm not wrong, are you asking to measure the PEX_RST_BUF signal in diode mode? showed no value.  详情 回复 发表于 2022-3-2 15:54
发表于 2022-3-2 15:54:06 | 只看该作者 来自: 欧洲 来自 欧洲
testpoint 发表于 2022-3-2 05:41
if rst signal is OK, please be are the diode voltage to ground, (red test lead to groud about 0.3, b ...
showed no value.
发表于 2022-3-2 19:18:12 | 只看该作者 来自: 美国 来自 美国
output was low ...
I watched a video on youtube. If the person measuring there had an ohm value of 300, it sounded like there was a short circuit. But I couldn't be completely sure. then that line is normal. PEX_R  详情 回复 发表于 2022-3-2 22:57
发表于 2022-3-2 21:32:08 | 只看该作者 来自: 广东汕头 来自 广东汕头
我英语不好,爱莫能助
发表于 2022-3-2 22:57:53 | 只看该作者 来自: 欧洲 来自 欧洲
Maybe you ...
PEX_RST_BUF
When I measure the reset signal in diode mode, it shows no value.
I also checked my 3090. 1.8 rail measures 230 ohm in reverse diode. I also checked PEX_RST_BUF*, it reads 293ohm in reverse diode. It sounds like your RST signal got desoldered on the GPU side. I wou  详情 回复 发表于 2022-3-3 10:08
发表于 2022-3-3 03:17:40 | 只看该作者 来自: 美国 来自 美国
showed no value ...
OK, GPU down, good luck
发表于 2022-3-3 10:08:53 来自迅维网APP | 只看该作者 来自: 美国 来自 美国
PEX_RST_BUF
It sounds like your RST signal got desoldered on the GPU side. I would reball the GPU if I were you. Good luck!
293ohm in reverse diode. - I did not fully understand this measure. Can you explain a little bit? maybe it doesn't belong to this topic, but i can't solve the logic of using diode mode with dmm. Is t  详情 回复 发表于 2022-3-12 19:13
then the values for the 1.8 line are normal there is no problem here I remeasured this time i connected the red probe to the GND I connected the black probe PEX_RST_BUF 0.657 later I connected  详情 回复 发表于 2022-3-3 15:38
if you dismount the GPU chip, just use the DMM to test the pin to determine the problem.  详情 回复 发表于 2022-3-3 12:16
发表于 2022-3-3 12:16:34 | 只看该作者 来自: 美国 来自 美国
Poko 发表于 2022-3-3 10:08
I also checked my 3090. 1.8 rail measures 230 ohm in reverse diode. I also checked PEX_RST_BUF*, i ...
发表于 2022-3-3 15:31:04 | 只看该作者 来自: 欧洲 来自 欧洲
I talk to the customer. According to what he said, welding works were being done in the neighborhood. then at this time i connected the video card to the computer and suddenly the video card stopped
发表于 2022-3-3 15:38:27 | 只看该作者 来自: 欧洲 来自 欧洲
I remeasured
0.657
later
I connected the red probe PEX_RST_BUF
black probe GND
10 kohm value showed
发表于 2022-3-12 19:13:10 | 只看该作者 来自: 欧洲 来自 欧洲
maybe it doesn't belong to this topic, but i can't solve the logic of using diode mode with dmm. Is the value 0.400mv a voltage value applied to the line there?
发表于 2022-3-12 19:57:03 | 只看该作者 来自: 广东潮州 来自 广东潮州
小莹虫 发表于 2022-2-27 09:24
你翻译给他说 鬼佬来迅维学校系统学习吧。别再瞎搞胡搞了!
看他样子不像瞎胡搞,技术应该有相当,他可能没有图纸,要来这边问人而已,在油管很多维修大神主播的,特别是俄国人的都是高手
发表于 2022-3-13 03:14:06 来自迅维网APP | 只看该作者 来自: 美国 来自 美国
This is what I meant.
https://www.chinafix.com/thread-1306241-1-1.html I would be very happy if you let me know your opinion.  详情 回复 发表于 2022-3-17 15:37
发表于 2022-3-17 15:36:35 | 只看该作者 来自: 欧洲和中东地区 来自 欧洲和中东地区
thank you for your comments
Most likely the gpu is bad. I returned the graphics card to the customer.
发表于 2022-3-17 15:37:27 | 只看该作者 来自: 欧洲和中东地区 来自 欧洲和中东地区
发表于 2022-3-21 13:25:39 来自迅维网APP | 只看该作者 来自: 香港 来自 香港
I have the same issue in my galax rtx 3070 lhr。all voltage is normal,All resistance values are normal, and the crystal oscillator is 27m.but mainboard can't detect the gpu device。rstbuf have 1.8 voltage。maybe is the 30 series new problem。
发表于 2022-3-22 03:26:34 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
a6464863 发表于 2022-3-21 13:25
I have the same issue in my galax rtx 3070 lhr。all voltage is normal,All resistance values are nor ...
the problem of that integrated is chronic. because a few friends also faced the same problem
