- 积分
- 8289
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2007-3-24
- 精华
3#
发表于 2007-8-10 11:19:13
只看该作者
来自: 江苏苏州 来自 江苏苏州
看一下这个摘要,文献我搞不到,人家要米。
Method for adjusting the input switch-point level of the MCH using a pull-up resistor on the CPU package
Disclosed is a method for adjusting the input switch-point (GTLRef) level of the memory controller hub (MCH) using a pull-up resistor on the central processing unit (CPU) package. Benefits include improved functionality and improved performance.
Background
When new process-generation CPUs are plugged into previous-generation motherboards, the optimal GTLRef level of the MCH with the new CPU may not match the level hard-wired into the motherboard. This problem is conventionally solved by asking motherboard suppliers to change the option for the resistors on the motherboard that sets the GTLRef level for the MCH. As a result, motherboard suppliers must requalify their motherboards.
Conventional motherboards set the GTLRef voltage for the CPU and MCH by placing resistor dividers on the motherboard to generate the appropriate voltage. Because future CPUs are required to plug into existing platforms, and the GTLRef level set in the past for previous CPUs may not be optimal for future platforms, a method is required that adjusts the GTLRef level of existing devices mounted on existing platforms already in the market to tune them to accept the latest CPUs (see Figure 1).
Description
The disclosed method adjusts the motherboard chipset’s input/output (I/O) GTLRef through the use of a resistor placed on the CPU’s package. A pull-up resistor, ... |
