查看: 1406|回复: 5
Few short circuits in the motherboard and Fix
发表于 2020-10-25 04:35:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 巴西 来自 巴西
Hello to everyone
Model: Dell 3537
MB Code: LA-9981P
Problem of motherboard: Short circuit
1. First appeared on the motherboard this was the problem. SY8206D (+1.05VSP). Its pwm was burned and there was a hole in the pcb. Remove pwm.
I cleaned the burnt part. Replace SY8206D -> SY82068D
2. Power supply connected and short circuit. RTL8106E started to warm and remove ic.
3. Let's start the measurements now. +1.05VSP PL301 - 0.6 Ohm. This is not normal full short circuit.
That means the CPU is corrupt. When I put 1 voltage on that line, the chipset started to get hot.
4. There was also a short circuit in this line +3VALW_PCH. J513 (Jumper) - 0.4 Ohm.
I'm sure now the CPU is broken
5. Other short circuit GPU and VRAM-s.
GPU coil PL802 1.5 ohm.
VRAM coil PL1101 +1.35VGPUP - 0.8 ohm.
6. CPU, GPU and VRAM-s remove. All short circuits disappeared. Everything is normal.
This is an Intel U series processor. i5-4200U. An expensive CPU.
Intel's processors are always expensive.
I offered the client an i3-4005U CPU. Second hand. I did not change the GPU.
The customer accepted in that case. UMA only.
And I started trading...
Soldering was very successful. It is necessary to make new measurements. I have to be sure of everything.
Yes, everything is okay
Let's start the motherboard now
Good Day
补充内容 (2020-10-29 18:48):
Compal LA-9981P CPU short circuit
参与人数 5下载分 +22 +22 收起 理由
黄祺益 + 5 + 5 老司机!双击666+关注.....
♂ㄒ♀ + 5 + 5
梦花彼月 + 5 + 5 淡定的男人最成功,淡定的人生不寂寞
主角小子 + 5 + 5 老司机!双击666+关注.....
kerokrrl + 2 + 2 给愿意分享经验的人加分!
发表于 2020-10-28 03:42:23 | 只看该作者 来自: 北美地区 来自 北美地区
H55 发表于 2020-10-27 10:22
主板烧的东西太多了!你那不是正在打仗吗?
motherboard war
发表于 2020-10-27 01:34:31 来自: 欧洲和中东地区 来自 欧洲和中东地区
don't forget to support
支持 反对
3#
发表于 2020-10-27 09:51:36 | 只看该作者 来自: 台湾 来自 台湾
Broke a lot of things.Brother, but you don’t seem to use the diode gear to measure.I'm not used to watching.
发表于 2020-10-27 10:22:20 来自迅维网APP | 只看该作者 来自: 贵州 来自 贵州
发表于 2020-10-27 23:04:10 来自迅维网APP | 只看该作者 来自: 江西南昌 来自 江西南昌
yourareveryverygood
发表于 2020-10-28 03:40:19 来自: 北美地区 来自 北美地区
kerokrrl 发表于 2020-10-27 09:51
Broke a lot of things.Brother, but you don’t seem to use the diode gear to measure.I'm not used to  ...
I usually take measurements with om. gives healthier results
支持 反对
8#
发表于 2020-10-30 05:44:03 来自: 中国 来自 中国
You're great
Did it take a lot of time to fix this
支持 反对
9#
发表于 2021-2-7 22:43:29 | 只看该作者 来自: 广东佛山 来自 广东佛山
最后独显没有装上去?改成继成显卡了?
